Scotsrick Two Stroke Sniffer
Posted: 09:45 - 01 Dec 2019 Post subject: |
Absolutely nothing stopping it blowing both bulbs. Happens a lot in my experience so simple things first.
Then check the switches are working with your meter. Set to resistance and measure between the terminals, should be high resistance with the switch off and low resistance with the switch on.
Then check there's power to the switches, should be 12v at one terminal on each switch when the ignition is on. Black lead to earth (battery negative or any bit of bare metal) red to the terminal.
Then check there is 12v at one of the bulb holder terminals with the ignition on and the brake held on. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
1198 World Chat Champion
