Who rides out in low temps
seeyalater
PostPosted: 12:14 - 01 Dec 2019    Post subject: Who rides out in low temps Reply with quote
Im new to passing my test, learned out in wet and rain so the weather doesnt phase me, but the low temps do.
I was hoping to ride today for the first proper outing on my new bike but its freezing, tomorrow is around 3-5 degrees here.
So how low do you guys avoid, i know it may vary on experience and need etc.
cheers
Kentol750
PostPosted: 12:35 - 01 Dec 2019    Post subject: Cold. Reply with quote
I pick my morning commute route along busier roads when it's dark and freezing. Once the sun is up and ground frost is fading I'm much happier to travel country roads.
Some bikes.
seeyalater
PostPosted: 12:55 - 01 Dec 2019    Post subject: Reply with quote
makes sense buddy. the route i was planning should be busy, but temps as low as 3degrees. curious about shaded corners.
I dont need to ride so its only a pleasure thing
PostPosted: 13:26 - 01 Dec 2019    Post subject: Reply with quote
Always the extra risk with ice in low lying and/or shaded corners. You can sometimes simply keep in the wheel tracks of our 4 wheeled friends but that is no cast iron guarantee of grip. Even the inbetween bit that often offers more grip in certain conditions can be a grit filled twitch fest.
You don't win any medals for riding in near to freezing temperatures but for me I did find it useful when there were times when a bike was my only way (liar...could've used buses..taxis...cadge a lift) to get where I needed.
Treat it like you do in the rain or down a muddy track. Loose on the bars, smooth on the brakes before the turn and a throttle just about pulling you through the corner...any twitching...ignore (actually you do get a medal if you can ignore your first twitch). Keep your head up and continually take in your surroundings, looking for patches of wet ...hillside side water...blocked grids and topless models from Gateshead.
seeyalater
PostPosted: 13:37 - 01 Dec 2019    Post subject: Reply with quote
thankyou great advice. Smile
PostPosted: 13:55 - 01 Dec 2019    Post subject: Reply with quote
It's some advice.
There are plenty of people here who have to ride through winter and if you hang around they may give some of the good stuff.
It's not always so much the actual temperature as I've ridden in minus whatevers... it's the moisture content. A bone dry road on a clear day posed no problem on my trip up the M6 but the windchill of -30 did. Visor fogging on the inside and even with double gloves I admitted defeat and turned back after a thaw out.
Few of us hardy northern scum would have a meetup during the winters.
Now I have a car (plus bikes) and the 'scumbags' rarely post on here. So I call that a win-win. Confused
PostPosted: 14:33 - 01 Dec 2019    Post subject: Reply with quote
I don't mind it cold and I don't mind it wet... riding through sleet is where I draw the line!
WreckTangle
PostPosted: 14:51 - 01 Dec 2019    Post subject: Reply with quote
Make sure as well you have some proper thick biking gloves. If it gets to cold (especially if you are travelling at speed, as you will be buffeted with high cold wind) , your fingers will go number, stop working and control of clutch and break will become harder.
My wife asked me to get her something that goes from 0-100 in under 5 seconds for her birthday. ......................I got her a bathroom scale.
seeyalater
PostPosted: 15:11 - 01 Dec 2019    Post subject: Reply with quote
Yes im a northerner, i dont mind wet etc, and so far only really been in bad cold, although training and test week was around 4 degrees and wet.
my hands are the only part to get cold, the gloves are ok but not full winter, i need to try a few as some offline were too tight so a shop visit is needed, do have heated grips but they wont warm my knuckles lol. (not even tested them yet)
might venture out tomorrow across lincolnshire, Tuesday is warmer so defo one of the 2.
Im Doncaster area based if anyone knows any good haunts
ThatDippyTwat
PostPosted: 16:06 - 01 Dec 2019    Post subject: Reply with quote
I was out today on the VFR for a couple of hours - ice on seat, frosty all over the place etc. TL;DR - It's fine, if you're careful.
Gloves. You want decent winter ones (Spada Enforcers, RST Ti Outlast etc) . Silks/inner gloves also help, especially if you're on a budget (£70+ for above gloves). If your hands are numb, you're going to have a bad time, even if you don't bin it. Ideally, you want a tiny airgap between your fingertips and the gloves. Too much and you lack control, but pushed up against them will transmit the cold far more quickly. Good winter gloves are bulky. Heated handgrips help, but only to a point. Heated gloves are great, but expensive (£150+) and you need to make sure your bikes electrical system is up to powering anything heated as well. Cheap Chinese/Korean 125's usually struggle, being built to a price.
Snow is fine if you're *smooth*. Much emphasis on smooth, dont get grabby on the throttle, clutch or brakes. Things you'll get away with in the dry will absolutely have you off in reduced grip situations. If there's ice/black ice on the road itself not just pavements and puddles? Get the car out, or take the fucking bus - You get to claim if the driver stuffs it into the hedge.
Leave a bigger gap - Not just because of your stopping distance, but also the muppet behind you. Lots of car drivers fail to comprehend how much grip is reduced, and how much stopping distance is increased.
seeyalater
PostPosted: 16:54 - 01 Dec 2019    Post subject: Reply with quote
Thankyou, looking up those gloves now
Hong Kong Phooey
PostPosted: 19:08 - 05 Dec 2019    Post subject: Reply with quote
Anything below 5c I don't bother these days, actually of late I've not used the cbr since mid November.
Before now I've ridden in snow and slush, by staying on main roads and riding in the patches of tarmac exposed by cars.
I can envisage the cbr only getting our once or twice before Feb, mainly to stop it getting very grumpy, as it misfires a bit if left for months without fresh fuel.
I'm getting old and can't be arsed, bikes are for fun and naughty commuting for me these days.
seeyalater
PostPosted: 20:33 - 05 Dec 2019    Post subject: Reply with quote
weather isnt great for a while now, the odd day at 8 or 8 degrees. was ok today just a bit windy. had 2 short runs last 2 days but thats it until next week if we get an ok day and im not busy
thx1138
PostPosted: 23:38 - 05 Dec 2019    Post subject: Reply with quote
I crashed, well I fell over in a layby cos of mud, cos I was too cold and inattentive to deal with an easy hazard, in Jan this year. It was about 1 or 2 degrees, but I'd ridden too far and too long without stopping for a warm up and a break.
But yeah, often do ride in cold, but try and keep the distances shorter, and keep an eye on forecasts.
linuxyeti
PostPosted: 23:58 - 05 Dec 2019    Post subject: Re: Who rides out in low temps Reply with quote
cheers
I'll let you know, when it gets cold.. So far, it's not been cold enough for muffs, or thermal lining in the jacket.
by the way, 3-5 degrees, is not cold, mild yes, cold, no. You dn't really start to feel the cold at 70mph, until the outside temp is -8 degress or below, even then, it's not until -10 that is genuinely cold, then I may put the muffs on, and the thermal lining in the jacket. Getting close to 2 years since the muffs were last used
Kawasaki Jimbo
PostPosted: 00:09 - 06 Dec 2019    Post subject: Reply with quote
Laughing You're trying too hard to impress. It's not working.
seeyalater
PostPosted: 08:55 - 06 Dec 2019    Post subject: Re: Who rides out in low temps Reply with quote
cheers
frank castle of the bike world lol. i only get a cold right index finger, new gloves not amazing but were only £40 so cant moan.
the cold i dont mind, ice i dont want to even try and tackle.
chickenstrip
PostPosted: 09:34 - 06 Dec 2019    Post subject: Reply with quote
Shackleton was a pussy.
Personally, I put the liner in my jacket when the temperature approaches -273C.
trevor saxe-coburg-gotha
PostPosted: 10:27 - 06 Dec 2019    Post subject: Re: Who rides out in low temps Reply with quote
cheers
Let's assume bone-dry roads and no frost for a fair few days. I don't really ride that much different than I normally do, although yes, the fact that my tyres won't be as warm does mean I'm a bit more cautious when cornering. If I'm going to be doing much more than 50 miles, I'll be wanting regular breaks to warm up - even 5 degrees is enough to piss me off after a while (I don't have any gadgets so just have to layer up).
If it's wet, and / or been frosty over night, it's a different story. I'll be tentative and trying to softer on the brakes and softer coming off them. In fact, I'll be trying to use them less in general.
Hawkeye1250FA
PostPosted: 10:44 - 06 Dec 2019    Post subject: Reply with quote
Good tyres designed for cold weather - everyone has their own opinions from their own experience, I prefer PR3s or PR4s.
Silk inner gloves for any type of hardy thick winter gloves
Handlebar muffs, yes they look shite but are amazing for low temp riding
Heated grips - dead easy to install and work ace - especially with muffs
Agree with above comment - around 50-60 miles Id want to have a coffee / warmup break.
chickenstrip
PostPosted: 10:56 - 06 Dec 2019    Post subject: Reply with quote
PR2s were enlightenment for me, and then on to PR4s. I'm sure there are others just as good too, but I'd never ridden on anything so confidence inspiring in cold, wet conditions until I first tried these (won my first set of 2s from a bike magazine Mr. Green ). Never tried anything else since.
barrkel
I don't ride if it's below zero unless it's bone dry. Normally that's in places like alpine passes in spring, where the roads are cleared and the sun heats the road surface enough to dry them out.
The roads around here are usually salted when it's below freezing, and the salt sucks moisture out of the air, so the roads stay wet. That salty muck is then sucked off the road by your tyres and deposited on your radiator, swingarm, shocks, etc., accelerating corrosion. Not weather for a bike you value highly.
ABS and traction control helps in this weather. The main thing to avoid is jerk (sudden changes in acceleration); smoothly and gradually all the things. If you want to accelerate hard (e.g. to overtake), pull out then accelerate in a straight line, or get up to speed then drift out and back in again, don't combine large changes in direction and speed.
Evil Hans
PostPosted: 13:32 - 06 Dec 2019    Post subject: Re: Who rides out in low temps Reply with quote
Eh? Doesn't reduce you to stages?
Oh .... you mean faze.
Yeah, my commute is mostly Motorway and A road so it's not usually a problem. The worst thing is the fine mucky salty spray. Wipe it off with your glove* before it dries / freezes. And avoid the lumpy bits when it snows.
* If only there was an automated alternative!
seeyalater
PostPosted: 11:41 - 08 Dec 2019    Post subject: Re: Who rides out in low temps Reply with quote
I take pics for a living hence my grammer being shite. lol.
above advice great, overtaking tips and tyres. thanks
seeyalater
PostPosted: 11:45 - 08 Dec 2019    Post subject: Reply with quote
just checked the tyres, Pilot Road 4, did think i was taking corners better than on the triumph i trained on. just thought it was different bike feeling. only been out in wet/damp roads but noticed i took bends with a bit more confidence.
The last post was made 5 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 141.44 Kb
