| XT65 |
 XT65 Borekit Bruiser
| jaffa90 |
 jaffa90 World Chat Champion
| stinkwheel |
 Posted: 22:49 - 02 Dec 2019 Post subject: |
You can use a JIS on a phillips but not the other way round.
In fact, they are better for phillips heads, less tendancy to cam-out because of the more acute angle on the sides of the driving faces, they sit more flat against the grooves in the screw head and are less likely to pop-up as they are turned.
The point on a phillips is too long for it to seat fully into the head of a JIS.
Try tapping the screwdriver into the screw, the percussion can loosen any corrosion between the head and the piece and try turning both ways in the presence of penetrating oil.
A little heat never hurts if the piece will tolerate it. A couple of heat and cooling cycles, applying penetrating oil when it's hot can also help. You can pour hot water onto a more delicate piece or use a hairdrier if you're worried about damaging it with a heat gun/blowlamp. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Shaft |
 Shaft World Chat Champion
| XT65 |
| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
| Easy-X |
 Easy-X Super Spammer
| sickpup |
 sickpup Old Timer
| stinkwheel |
| sickpup |
 sickpup Old Timer
| stinkwheel |
 Posted: 14:17 - 03 Dec 2019 Post subject: |
To be fair, it's starting to sound like a total clusterfuck in the name of standardisation (I'm thinking BA threads).
"DIN 5260-2 : SCREW DRIVERS FOR SCREWS WITH CROSS RECESS; GO-RING GAUGES FOR THE TESTING OF SCREWDRIVER POINTS"
Not sure where the screw standard is but the presence of dimples on some not others implies there are two sorts. That said, I've seen posidrives with dimples too, mostly on door hinges, not sure what that's about.
Again, people used to grind down the tips of phillips screwdrivers to fit JIS heads when you simply couldn't get drivers for them and the tip doesn't really do anything useful other than poke holes in your pockets/toolbag so I can see why they would have changed it.
I was always under the impression that phillips screw heads are designed to cam-out the bit for machine assembly and JIS are designed NOT to cam out the bit for accurate tightening. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Polarbear |
 Polarbear Super Spammer
| XT65 |
 Posted: 17:54 - 03 Dec 2019 Post subject: |
Tat's what I understood as well. It's also one of the reasons Pozi drive was created because they don't cam out.
Confirmed here and also states a supplier of old JIS standard screwdrivers.
https://rtstools.com/jis-vs-phillips-screwdrivers-and-where-to-buy-a-jis-screwdriver/[/quote]
Yes,torque specific...That’s how I understand it as well... I do have a set of JIS screwdrivers,not sure how accurate they are thought..And to top it off after some heat and careful use of the impact driver and a couple of hours I finally broke the grip.
The bite that did it?......A PH 001 !?!..
Thanks for the conversation, it’s an interesting topic (the missus thinks we’re all mad.
A screw is either one of TWO THINGS!...hhh bless ‘er!) |
| Hong Kong Phooey |
 Hong Kong Phooey World Chat Champion
The last post was made 6 years, 310 days ago. Instead of replying here, would creating a new thread be more useful? |
