| dawid08 |
 dawid08 L Plate Warrior
 Posted: 18:34 - 06 Jan 2020 Post subject: battery |
hello i got question i tried charge my battery i heard something like battery starting boil but battery was cold. I was charging maybe 1 min.question is can i use this charger to my battery u can see them both on the picture.Thank you for your help.
https://ibb.co/dfw3mkR
https://ibb.co/hfkwLrh |
| Nobby the Bastard |
| dawid08 |
| Nobby the Bastard |
| dawid08 |
| Nobby the Bastard |
| GettinBetter |
 GettinBetter Crazy Courier
| Polarbear |
 Polarbear Super Spammer
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 23:06 - 06 Jan 2020 Post subject: |
12v 6Ah... that's a pretty small battery. What's it on?
Is it the correct size battery for the bike?
Does the bike have an electric start?
My immediate thought is that a battery that small, probably wont fare too well on a bike with an e-start that would tend to deep-cycle discharge it pretty hard on start-up. Good odds that electrolyte would be boiled by that and deteriorate, followed quickly by the plates that would tend to warp, and 'sulphate-up' as the electrolyte boils off, the electrolyte level dropping and 'silt' like kettle scale building up between the plates to create short circuits, as the plate to acid in contact area falls reducing what charge holding capacity the battery might gave even more.
So how old/tired is the battery?
What you heard that sounded like 'boiling' could be pretty much that, if battery old and tired, and of diminished charge holding, so small to start with, even a pretty moderate 'car' type battery charger, rated at say 4A could be banging in the juice fast enough to get it hot, even if new.. more so if new and not properly filled, even more if battery old and electrolyte level low (Or topped up with tap water with fluorine+chlorine from the water works in it!), and even more if battery old an knackered....
So what's it off and how old and what's the back story?
B-U-T other one is you DID take the fill-plugs out when you put it on charge didn't you? As has been mentioned when a brand new battery is put on charge the acid is electrolysed and makes hydrogen that bubbles out.. making a boiling noise... but also has to escape some how and the litte overflow 'vent' on the side IS not really enough... which is why in the instructions it says to remove the fill-plugs.... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Riejufixing |
 Riejufixing World Chat Champion
| Riejufixing |
| dawid08 |
| dawid08 |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 13:06 - 07 Jan 2020 Post subject: |
| Teflon-Mike wrote: | 12v 6Ah... that's a pretty small battery. What's it on?
Does the bike have an electric start? |
| dawid08 wrote: | the scooter im using is lexmoto fmx 125 battery is corret for this scooter.yes my scooter got electrical start. |
Oh Kay... that's one and a half questions answered.. what about the rest?
| Teflon-Mike wrote: | and how old and what's the back story? |
Reiaju pointed out its supposed to be a sealed gel battery, so there's no fill-plugs to pull when you charge, and it cant be topped up... b-u-t... it's still a lead acid battery, only the acid has been made into a jelly, it will still break down, and it can still 'boil' in a way. So how old is it, how knackered is it?
Fact its come off an e-start scoot does not suggest it will have fared well, as these tend to get treated like a kettle, and hammered on the starter heavily and often doing short stop-start journeys never getting properly charged by the engine; and little battery like that would get kerfkered tout sweet in use. Bunging a knackered battery on charge, it could likely sound like its boiling as almost 50W of power runs through whatever is left inside, arcing between warped playtes, boiling off residual acid jelly and trying to electrolyse whatever salts have been left between the plates in the sludge.....
So, again, HOW OLD is the battery? What's its History? And how kerfkered is it 'likely' to be? ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| dawid08 |
 Posted: 13:30 - 07 Jan 2020 Post subject: |
| Teflon-Mike wrote: | | Teflon-Mike wrote: | 12v 6Ah... that's a pretty small battery. What's it on?
So, again, HOW OLD is the battery? What's its History? And how kerfkered is it 'likely' to be? |
Battery got around 4-5 months I didn’t used scooter 1 month |
| Nobby the Bastard |
| Riejufixing |
| Nobby the Bastard |
| dawid08 |
| Nobby the Bastard |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 15:08 - 07 Jan 2020 Post subject: |
4-5 months old, is a measure of time, not how hard the battery may have been hammered and kerfkered in that time.
Assumption here has to be that it's probably rather tired and a bit kerfkered from lots of stop-start riding never properly charging the battery off the engine, and it 'may' not be too bad... 'may'....
As to whether you could charge it off a common a garden car charger... well you should be able to, b-u-t its a diddy mattery and I wouldn't want to leave it, unsupervised for more than maybe an hour.. or it could go pop.
Also begs question whether the boiling noise you heard came from the battery, or from a half toasted charger, or if charged in situ on the scooter, something else, like maybe the reg/rectifier getting toasted....
If the charger in question... don't use it.... that solves that one.
If battery in question.... get a new one; that answers that (unasked) question.
BUT overall, look at how you use the thing, and how much e-starting you do compared to full bore riding when the generator might be able to make a bit more electric than lamps and other equipment may be sucking.
Personally I recomend Bump-starting if the battery wont turn the engine over..... ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Ribenapigeon |
 Ribenapigeon Super Spammer
| Riejufixing |
| Ribenapigeon |
| Nobby the Bastard |
The last post was made 6 years, 264 days ago. Instead of replying here, would creating a new thread be more useful? |
