Ribenapigeon |
Ribenapigeon Super Spammer
JackButler |
JackButler Traffic Copper
doggone |
doggone World Chat Champion
wr6133 |
wr6133 World Chat Champion
Ribenapigeon |
Nobby the Bastard |
Ste |
Ste Not Work Safe
Posted: 13:22 - 04 Jan 2020 Post subject: |
New bike. |
Ribenapigeon |
Polarbear |
Polarbear Super Spammer
Posted: 13:47 - 04 Jan 2020 Post subject: |
I would say its certainly the cable/s.
You can lube it by taking off at the throttle end, making a plastic cup out of plasticine and filling with oil, allowing it to seep down the cable overnight.
Or you can buy a cable lubricator that uses aerosol oil to force the oil through, one of these.
https://i.ebayimg.com/images/g/LZsAAOSwpaFZyzfV/s-l400.jpg
Or, the best idea, replace the cables. ____________________ Triumph Trophy Launch Edition |
Nobby the Bastard |
Islander |
Islander World Chat Champion
F18 |
F18 Renault 5 Driver
pepperami |
pepperami Super Spammer
Ribenapigeon |
WD Forte |
WD Forte World Chat Champion
Robby |
Robby Dirty Old Man
Ribenapigeon |
Islander |
Posted: 22:59 - 06 Jan 2020 Post subject: |
Another possability is that the "close" cable could be broken.
Pattern throttle cables are cheap as chips. £20 the pair. Just order the fuckers because by the time you've got at the ends and fiddled them off to inspect/lube them, you won't want to be doing it again.
If cables are nylon lined or you're not sure and you need to lube them, use silicone spray. That won't upset anything. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Ribenapigeon |
Easy-X |
Easy-X Super Spammer
Posted: 13:18 - 08 Jan 2020 Post subject: |
Are you saying you don't think it's a mechanical issue? (e.g. gummed up cable.)
Slow return to idle hints at a lean condition ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Posted: 20:31 - 08 Jan 2020 Post subject: |
The throttle twistgrip itself is slow to close or the twistgrip closes as normal but the engine is slow to return to idle?
A 2013 XJ6 is carbed right not injected?
On a CV carb, the throttle twistgrip opens and closes a butterfly valve to regulate the amount of air that can enter the carb. That ought to happen just the same if it's running or not.
The actual throttle (as in the throttle valve inside the carb, not the twistgrip) is opened and closed by a difference in air pressure across a thin rubber diaphragm. If there is a hole in the diaphragm or an air leak in the inlet manifold, it can stick open at a fast idle, there is a spring to force it closed but it is comparatively weak.
So if the throttle (twistgrip) is working normally but the revs are slow to drop, first thing I'd check is for an air leak by spraying WD40 over the inlet rubbers with the bike at a steady idle. If it revs up, you have an air leak. The second thing I'd check is a visual inspection of the diaphragms for pinhole leaks/tears. This is a delicate job. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Ribenapigeon |
Islander |
Ribenapigeon |
The last post was made 4 years, 106 days ago. Instead of replying here, would creating a new thread be more useful? |
