| Ed Howzer-Black |
 Ed Howzer-Black Derestricted Danger
 Posted: 12:52 - 05 Jan 2020 Post subject: Trickle / pulse battery charger question. |
Hi,
I bought one of these from eBay, described as having a trickle charge function.
https://www.amazon.co.uk/FOXSUR-Battery-Automotive-Maintainer-Motorcycle/dp/B07TGC3LHN/ref=sr_1_5?crid=1Z3L8DG8VEDBV&keywords=foxsur+battery+charger&qid=1578224519&sprefix=foxisur+battery+charger%2Caps%2C145&sr=8-5
Battery Type: All SLA batteries (Wet, MF, GEL, VRLA and Flooded), AGM (EFB), LiON
Input voltage: 100-240V AC, 50-60Hz
Rated output: 12V DC, maximum 5-6A.
Minimum starting voltage: 8.0V
Battery range: 4-100Ah
Thermal protection: 65'C +/- 5'C
It doesn't seem to have a trickle function but has a pulse function ( also called a repair function, that doesn't allow bubbles to form on the plates ).
in terms of battery longevity, can this be used regularly, in place of the trickle function ?
thanks |
| Polarbear |
 Polarbear Super Spammer
| mentalboy |
 mentalboy World Chat Champion
| Robby |
 Robby Dirty Old Man
| Ed Howzer-Black |
 Posted: 19:43 - 08 Jan 2020 Post subject: trickle / pulse charger question |
| mentalboy wrote: | The pulse function has nothing to do with the use as a maintenance charger, however, to answer your question, the blurb on your link states specifically that a battery can be left indefinitely on this charger and that it has a maintainer function - which pretty much describes a trickle charger.
Edit: Just to note that, if I recall correctly, trickle chargers maintain a constant charge whereas this charger has digital capacity to prevent overcharging. |
| Robby wrote: | Output looks a bit high. Usually motorcycle-specific chargers top out around 1A, and trickle charge/maintain at 0.2A. That is a car charger, for 50A batteries. |
Hi,
Thanks for the answers.
I know nothing except what i have googled.
i thought that trickle chargers used a very low amperage whereas this puts out about 3 on normal setting; no trickle setting.
; the manual says to use the pulse charger for motorcycle batteries as the normal output is too high for small batteries; so i assumed that the pulse charge worked at lower amps ( so maybe was comparable to a trickle) ???
From the responses, I think, it doesn't sound like it; i'll send it back.
thank you |
| pepperami |
 pepperami Super Spammer
| GettinBetter |
 GettinBetter Crazy Courier
The last post was made 6 years, 131 days ago. Instead of replying here, would creating a new thread be more useful? |
