Central Heating Advice
400bandit
PostPosted: 22:32 - 24 Jan 2020    Post subject: Central Heating Advice Reply with quote
Hi All,
I'm after some advice if there is anyone out there that can comment. I moved house nearly a year ago and have been blissfully ignorant in my understanding of how my heating system actually works...
House is a decent sized four bed detached which has an external oil boiler and on the roof, evacuated tubes (solar water heater).
In the house we have 2 thermostats, one upstairs and one down.
Before Christmas I bagged a Drayton Wiser smart heating controller and was hoping to use it in place of the two thermostats and to control hot water. Well after taking the existing controller off the wall I was left scratching my head, the wiring didn't match any of the examples in the Wiser instructions (was supposed to be a bit of a plug in and play scenario...) and seems far too simple to facilitate two thermostats and hot water.
What I'm starting to think is the hot water isn't at all controlled by the existing control unit and is not in any way connected to the boiler - I think it purely relies on the evacuated tubes and an immersion heater. Does this sound likely? Seems odd to me to go to the effort of putting in the evacuated tubes only to pick up the slack with an electric heating element?
Here are some pictures:
https://drive.google.com/uc?id=1AgYw28u6XwmQF_xdQANMhvH8IrT6rRHK
https://drive.google.com/uc?id=1AfOh0HbONfYud4dFckG1rrNKJbNMBYtt
https://drive.google.com/uc?id=1Acls38M6zylgGftCNtfViJeL28vTuk6j
Here's the brain box were the hot water from the evacuated tubes:
https://drive.google.com/uc?id=1AlVfWRui8TJK77sH_aaj7pNFTXNba9bn
Any help would be much appreciated!
Many Thanks,
Joe
duhawkz
PostPosted: 23:22 - 24 Jan 2020    Post subject: Reply with quote
If you have a problem, if no one else can help, and if you can find him....maybe you can hire The SinghPal."
PostPosted: 00:35 - 25 Jan 2020    Post subject: Reply with quote
Now I'm no expert but I did land up having to rewire my outdoor oil combi heating system and fix my boiler because no other fucker seemed to be able to work out how to make it work properly. Got fed up paying for boiler engineers to come out and scratch their heads, suck their teeth and start replacing random parts because they're "no good at electrics mate".
That centaur box is controlling CH only.
Do you have a combi boiler that does both CH and HW or is it just a heating boiler feeding a heat store (big polystyrene covered tank)? Check make and model.
I suspect what you have is a heat store/hot water tank which can be heated by the solar, boiler or immersion. In which case the centaur box will be triggering the CH pump via the 'stats (with a heat exchanger in the heat store). The HW will be on all the time being pre-fed hot water from the solar, and topping up with the immersion if the boiler isn't on.
Nearing the limit of my experience but I'd guess the boiler is only on when the CH is on (controlled by the white box). So when the CH is on, the HW is using the boiler, when it's off it's using a combination of the solar and topping up with the immersion. I suppose one way to check if that's what's happening is to turn the heating off (at the centaur box) and the hot tap on and see if the boiler fires up after a bit.
Combis are sometimes wired up so the HW is on all the time but I don't think you can use a combi with a pressurised HW system and heat store, they are usually mains pressure and cold-water fed.
Sister Sledge
PostPosted: 10:09 - 25 Jan 2020    Post subject: Reply with quote
This ^^
But: Who the F wired that Centaur in? It has DIY written all over it. Why did they run the mains tail out like that instead of running it under the plaster wall? The wire they used is second hand - a kink from a previous use can be seen in it. There are wire whiskers loose around the terminals inside.
I can't help but do think you might be up against a bit more than you're expecting!
CCM 404 DS
PostPosted: 10:52 - 25 Jan 2020    Post subject: Reply with quote
Sister Sledge wrote:
This ^^
True that. When I set about my combi boiler. The first thing I had to deal with was a 13 core cable going into the boiler, when a combi boiler only has 5 wires. They had taken the main supply into the boiler, back out to the switch then back to the boiler again. Neutrals fucking EVERYWHERE, dangerously so because some of them landed up live when the thing they were connected to was off. I just ripped the whole lot out and started again.
Although I wouldn't necessarily say it was DIY. I know for a fact my last one was put in by a boiler engineering company from Manchester a year before I moved in. The standard of the wiring was much poorer than above. None of the tension relief used on plugs or wall boxes and the outer sheathing had been cut back beyond the limits of the box and boiler plugs so they were had bundles of wires sticking out. A hiairy mess of copper wire jammed into the terminals with bits of the insulation caught in the screws.
i replaced the whole thing recently and it wasn't until later I found out from a neighbour that the old one was mostly fucked because it had frozen just after it was installed on account of the original installer not connecting or testing the frost-stat properly.
almostthere
PostPosted: 17:16 - 25 Jan 2020    Post subject: Reply with quote
wheres the pics of the cylinder? that solar install looks an abortion where does the discharge pipe go to you could potentialy have scalding water or steam discharging from it
where does the switched live from the timeclock go looks like it only controls the heating as it a single channel programmer
you are probably right about the immersion and solar controlling the hot water
Beer, It's the reason I get up every afternoon
www.mfairco.uk
400bandit
PostPosted: 22:12 - 25 Jan 2020    Post subject: Reply with quote
This ^^
I'm not surprised by much in this house anymore! It's only about 12 years old but is a classic self build - the actual build of the house is spot on but they clearly started to run out of money towards the end!
Most of the plastering looks like it was done by Stevie Wonder and the En Suite installation was an absolute abortion!
The Drayton Wiser set up is supposed to be a plug in and play but I'm just going to get a professional to come in and if nothing else, give what is currently there the once over!
mentalboy
PostPosted: 22:50 - 25 Jan 2020    Post subject: Reply with quote
Find a mature, toothless, experienced plumber if you can. The toothless ones make a much better sucking noise when giving you the estimate.
Make mine a Corona.
UncleFester
PostPosted: 09:32 - 26 Jan 2020    Post subject: Reply with quote
We have an old gas boiler system where the CH will only get hot water if you have the HW on.
If you put the CH on by itself, it relies on the temperature of the water that is already in the system as all it does is turn on the pump, not the boiler.
We had no end of bother getting a sparky to fit the HIVE system but our plumber managed it just fine.
Module 1 and 2 passed - October 2014. Happy owner of a 2017 Z1000SX, ex owner of a YBR125 / CB500 / VFR800.
PostPosted: 13:56 - 27 Jan 2020    Post subject: Reply with quote
My guess is that the water system (hot tank) only has one indirect heating circuit in it (cheaper) and that is used/fed by your evac tubes and as you say in winter they slack is picked up by the immersion.
I don't really see an issue with that but gas is approx 4p/kW and Electric about 15p, more even. so long term it's more expensive. Short term the cost of a dual circuit tank extra valves and controls etc.. might make you re-consider.
Pip pip.
PostPosted: 13:57 - 27 Jan 2020    Post subject: Reply with quote
3-way diverter valve ist kaput
PostPosted: 19:59 - 27 Jan 2020    Post subject: Reply with quote
You can have a hot water tank heated by a coiled tube from the CH (+ an immersion element 3kw or more.)
The HW can heat independent of the CH by a two-way switching valve (controlled by a CH/HW controller).
Either CH or HW or a mix of both.
I would fit TRVs on all but one small rad (to give the boiler a place to send heated water when the thermostat hasn't shut it off yet.)
TRVs are not too expensive and provide a room by room control.
The problem is that once all the wiring has been chased bubthe original sparky it's a job to work out what he's done. Unless you're up to speed in electrics and have a couple of specific testers to simplify troubleshooting.
Don't get electrocuted, scalded or set fire to the hoose in the meantime. And have the doors open ifbyou are phaphing about with gas. Although by law you can't touch gas.
UncleFester
PostPosted: 19:07 - 28 Jan 2020    Post subject: Reply with quote
Boyles Law or just Physics lol
PostPosted: 21:38 - 28 Jan 2020    Post subject: Reply with quote
Boils coz of fizzicks init.
The last post was made 4 years, 90 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.78 - MySQL Queries: 17 - Page Size: 90.92 Kb
