KLE 500 A3 1993 model electrical problem
Longato
PostPosted: 07:56 - 07 Feb 2020    Post subject: KLE 500 A3 1993 model electrical problem Reply with quote
I do live in Portugal and my KLE always had this intermitent electrical starting problem. The engine does not fire at first start. Sometimes I have to insist with the starter 3 or 4 times in order get the engine started. Other times it starts as it should. Once started the engine runs fine and has no shown of any problem. Sometimes when I stop in neutral and put the side stand down the engine stops like if it had gears engaged. I have bridged up the wires for the side stand. I am selling this motorbike and I can not get hold of the wiring diagram for this model in order to find out what is going on with the wiring in order to bypass some sensors. The ones I find on the internet are from 2005 onward. Even at my local kawasaki dealer shop, they do not have it. is there any one who can send me this diagram by email or a piciture with whatsup, please? I could buy from a shop but I have not found any one who would have it . The models from ER and GPZ are different. i do have another oKLE500 I bought for spares but it was so good that I rebuilt it and this one runs fine. I have interchanged many parts from one to the other and have not found the problem. I have replaced coils with cable, spark plugs, ighiter box, junction box, ignition switch, alternator, pulser coil, It seems to be related to the diodes from the side stand, neutral light, kill switch, voltage regulator, clutch etc... The ignition switch has a resister built into it, and I thought it was bad conection and opened it up to clean the contacts and found it. The batery is new and charging very well. Both ignitions switches have one resistor that drops the voltage to aprox 10-11 v to the igniter box. I have checed the timing for the engine and is spot on, Any help would be greatly appreciated Thanks
PostPosted: 09:28 - 07 Feb 2020    Post subject: Reply with quote
Check the wire running between the main fuse and the ignition switch for corrosion at either end. This is a very common fault with these bikes.
Also check the clutch switch is functioning correctly.
I started colouring this diagram then gave up.
Longato
PostPosted: 20:18 - 07 Feb 2020    Post subject: Reply with quote
Thank you stinkwheel for the help and also for kindly sending me the wiring diagram. This afternoon, I decided to remove the flywheel from both KLE500 and swoped as a complete set with the starter clutch atached to it. Bingo, it was the starter clutch that was not fully engaging from time to time. It has been like that for one and half year. The side stand confused me because sometimes it cuts the engine off if the side stand is down and neutral light is on. I even swaped the starter motor from each other. Thank you very much for your help.
The last post was made 6 years, 22 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.84 - MySQL Queries: 14 - Page Size: 36.36 Kb
