| Author |
| ThatDippyTwat |
| Back to top |
| redeem ouzzer |
| Back to top |
| jaffa90 |
 jaffa90 World Chat Champion
| Back to top |
| ThatDippyTwat |
| Back to top |
| Tankie |
 Tankie Crazy Courier
| Back to top |
| redeem ouzzer |
| Back to top |
| ThatDippyTwat |
| Back to top |
| Bhud |
 Bhud World Chat Champion
| Back to top |
| jaffa90 |
| Back to top |
| ThatDippyTwat |
| Back to top |
| jaffa90 |
| Back to top |
| ThatDippyTwat |
| Back to top |
| Bhud |
 Posted: 20:25 - 22 Feb 2020 Post subject: |
If the revs aren't dropping quickly once the bike is warmed up, I'd suspect either a dirty throttle cable or return spring, or a vacuum leak (I know you checked this with the brake cleaner, but maybe check again). If it's not one of those things, then the carbs could be out of balance. I once wasted lots of time on out-of-balance carbs. The carbs were, in theory, clean and balanced, yet the bike would hang high when warm. I took the carbs off again and again, and set them all to open as equally as I could, on the bench. It made no difference. Then I discovered that a couple of the screws holding the bank of carbs together were loose. This was enough to produce a slight twisting motion so that one would move before the others, when they were put back on the bike and activated by the throttle cable. |
| Back to top |
| ThatDippyTwat |
| Back to top |
| mentalboy |
 mentalboy World Chat Champion
| Back to top |
| ThatDippyTwat |
| Back to top |
| A100man |
 A100man World Chat Champion
 Posted: 09:57 - 23 Feb 2020 Post subject: |
| ThatDippyTwat wrote: |
However, a few people have suggested the valve clearances may be tight. Reason being she won't drop revs as quickly as she should, even when warm.
I agree with 'a few people' could also be a combination of things. inc a blockage in pilot circuit. ____________________ Now: A100, GT250A, XJ598, FZ750
| Back to top |
| MCN |
 MCN Super Spammer
| Back to top |
| ThatDippyTwat |
 Posted: 13:33 - 23 Feb 2020 Post subject: |
No offence, but I'm well aware how to use a choke. You can't touch the throttle on startup, or it just wont start. When it does start, it will idle about 1500-2K for a few seconds. So far, that's what I expect, that or a minor variation of, is what I've experienced on any carb bike I've ever owned or ridden.
It then jumps to 4-5K without you doing anything whatsoever, not touching the choke or throttle, and wont let you back off the choke until its properly warm. 4-5K on choke is not normal for any bike I've ever ridden, irrespective of motor layout or number of cylinders. Warmup takes 10 mins or so. You can touch the throttle after 2 or 3, but it bogs like a demon even without load. If you try to ride it in any shape or form before you can drop the choke off altogether and idle at just over 1K, it'll bog and die. I'll get a vid later on if I get time.
Idea are gratefully recieved, but I'm not an idiot, despite what the forum name says. I'm trying not to be wordy and do a Teffers post, but I'm also trying not to miss out details that may or may not be important. If I'm cocking up, then tell me where, and why I can/can't/must do X, Y or Z. ____________________ '98 VFR800 (touring) - '12 VFR800 Crosrunner (Commuting) - '01 KDX220 (Big Green Antisocial Machine) |
| Back to top |
| wr6133 |
 wr6133 World Chat Champion
| Back to top |
| sickpup |
 sickpup Old Timer
| Back to top |
| MCN |
 MCN Super Spammer
 Posted: 16:17 - 26 Feb 2020 Post subject: |
Idea are gratefully recieved, but I'm not an idiot, despite what the forum name says. I'm trying not to be wordy and do a Teffers post, but I'm also trying not to miss out details that may or may not be important. If I'm cocking up, then tell me where, and why I can/can't/must do X, Y or Z. |
Have you checked the choke cable for damage/kinks/crimped?
The choke is probably easier to 'engage/apply as the cable pulls through the sheath. If the cable is broken inside or trapped then it won't be easy to fine control the choke towards off position.
The engine should increase RPM without touching anything.
That is why you need choke to make up fuel mixture lost to condensation on cold inlet passages.
As the engine warms then all of the choke enriched mixture reaches the combustion chamber.
So the more fuel more RPMs.
Then the choke lever can be moved to of gradually.
I thought you know how to work a choke? 🤔  ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Back to top |
The last post was made 5 years, 354 days ago. Instead of replying here, would creating a new thread be more useful? |
