Freddyfruitba... |
Posted: 18:52 - 19 Feb 2020 Post subject: Running Windows XP/7 "within" Windows 10? |
I've recently - very reluctantly - "upgraded" from Windows 7 to Windows 10 on account of Microsoft withdrawing support. One of the joyful effects of this is that my formerly perfectly working scanner is now reduced to doorstop status due to non-availability of the appropriate driver.
Now I'm aware of Vuescan which is a last-ditch option but don't really want to go there. Is it possible for me to set up and open a virtual window or something running an older version of Windows, just for the purpose of scanning stuff? I'm not entirely certain what I'm asking so not sure what to google for, but does this sound plausible? ____________________ KC100->CB100N->CB250RS--------->DL650AL2->R1200RS->R1250RS |
Im-a-Ridah |
Im-a-Ridah World Chat Champion
doggone |
doggone World Chat Champion
UncleFester |
P. |
P. Red Rocket
P. |
P. Red Rocket
The Shaggy D.A. |
The Shaggy D.A. Super Spammer
Posted: 21:47 - 19 Feb 2020 Post subject: |
I used Vuescan when I moved from XP to Windows 7, worked well. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Easy-X |
Easy-X Super Spammer
Posted: 22:35 - 19 Feb 2020 Post subject: |
Most people "scan" by using their phone camera these days... #JustSayin'
Anyhoo, yes, you'd want either Oracle VirtualBox or VMware Workstation. The later isn't free but the former, while free, is owned by a bunch of c*nts
Both have pass-through USB support and don't rely on the driver of the host for communication.
You might want to see if there was a Windows 8 driver as 9/10 times that works under Win10. What's the make and model of scanner? ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
P. |
P. Red Rocket
Freddyfruitba... |
Posted: 12:24 - 20 Feb 2020 Post subject: |
Thanks for the responses and suggestions.
I think Stinkers is closest to the mark in that my needs for the scanner are driven by clients who I do work for, and its not for me to dictate to them how they want documents/contracts handling/signing.
That said, my overall need for a scanner is very much less than it used to be, so I'm not interested in dropping a lot of cash on a replacement scanner just because Microsoft has said so. FWIW I have a Kodak i30 with a sheet feeder - good luck to anyone who can find a Windows 10 driver for that (and indeed, to anyone who fancies scanning 30-page documents using a phone...). It wasn't a cheap device, and nor would a Win-10-compatible replacement.
The idea of installing an old version of Windows on an SSD for dual boot appeals - that might be the answer (though I only run a laptop these days, so the 2nd SSD would have to be external, via USB - not ideal). Current favoured solution is to resurrect an old laptop running XP and use that as a dedicated machine to the scanner, on the same network as my main laptop) ____________________ KC100->CB100N->CB250RS--------->DL650AL2->R1200RS->R1250RS |
UncleFester |
xX-Alex-Xx |
Easy-X |
Posted: 14:11 - 20 Feb 2020 Post subject: |
Your scanner will probably work with Linux. It has a basic driver listed.
If you are going to dual boot or boot something off a usb drive, I'd dual boot with a Linux build. It'll be up super fast and you won't need to worry about running something old and virusey on the same PC.
As I say, puppy linux is a good choice because it's designed to run from a pendrive or DVD. I'd use the ubuntu-based version. You'll get the entire operating system on a 4Gb USB stick. Handy to have because it can also get you out of bother if your operating system falls over or your hard drive shits itself because it'll boot entirely into the RAM. You don't even need a HDD fitted. I've had an HDD fail but have been able to boot into puppy, mount the busted drive and transfer data off it.
You CAN use plug and play USB devices through virtual box. I have windows 7 in a virtual box on my Debian PC so I can update the wifes garmin watch. It also mounts and autoruns the software built into my action camera. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
WD Forte |
WD Forte World Chat Champion
P. |
P. Red Rocket
Freddyfruitba... |
P. |
P. Red Rocket
The last post was made 4 years, 67 days ago. Instead of replying here, would creating a new thread be more useful? |
