What could be the issue ? |
Coil |
100% |
[ 1 ] |
Battery |
0% |
[ 0 ] |
Engine |
0% |
[ 0 ] |
electronics ? |
0% |
[ 0 ] |
Carburettor |
0% |
[ 0 ] |
Total Votes : 1 |
siedlikmaster |
siedlikmaster Derestricted Danger
Nobby the Bastard |
siedlikmaster |
Riejufixing |
Nobby the Bastard |
siedlikmaster |
jaffa90 |
jaffa90 World Chat Champion
Riejufixing |
- Super Spammer
siedlikmaster |
GettinBetter |
GettinBetter Crazy Courier
Riejufixing |
siedlikmaster |
- Super Spammer
Posted: 13:25 - 19 Mar 2020 Post subject: |
siedlikmaster wrote: | - wrote: | If it was coil/leads or plugs, I'd expect a misfire, not just a "bogging down".
If it's fine for a few minutes, the first thing I'd check is the tank breather to make sure the tank isn't vacuum locking. |
Today in the morning it started with choke for 3-5min and then died, like it didnt had enough fuel or something. So now maybe the card is blocked or the vacuum pecock went faulty or as you said the tank breather, but where would I find this tank breather ? Not sure if my one got one, but will check around it anyway.
Thanks. |
The breather is normally a hole in the filler cap. If fuel leaves, air must get in to replace it or it vacuum locks.
If it's carb, can you get to the float bowl drain screw? When it conks out, stop, pull out a Phillips screwdriver and pop the float drain. How much fuel comes out?
How fast does fuel flow if you pop the fuel inlet hose off the carb with the engine cold and off, so to not start a fire?
Could be blocked fuel filter in the tank or an inline one if fitted. Some carbs also have a tiny guaze filter over the fuel inlet which you can see when the hose is removed. Is it clear?
It may be filling the float bowl slowly, then as you burn fuel, it can't keep up so bogs down until you stop, leave it a while to fill up again.
Most float bowls contain enough fuel for a few minutes.
Is the fuel hose kinked or trapped? ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG. |
Polarbear |
Polarbear Super Spammer
Posted: 17:43 - 19 Mar 2020 Post subject: |
Needs more bogging down paper?
Sorry, well not really. ____________________ Triumph Trophy Launch Edition |
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 03:49 - 20 Mar 2020 Post subject: Re: new coil didnt help |
siedlikmaster wrote: | Riejufixing wrote: | Is there anything else you can easily check, like the valve clearance? |
Valve clearance, I would have to dissemble whole bike to get there. |
Err Oh-Kay... I think I see the problem here....
Valve clerances are are bit of routine maintenance, like an oil change, that should be checked and adjusted every two oil changes or so.
It's a bit 'hard' to get at and get the rocker cover off.... and iots scary ion there... it exposed oily bits!!!!
Soooooo
It's probably NEVER been done, 'cos you and every other monkey that's looked at the thing has had the same idea!!!
But... fault finding 101... do ALL the basic routine maintenence checks in the book, make sure everything is how it's supposed to be, and that whatever faults may be there are taken out by the normal routine maintenence the factory tell you to do... THEN start looking for anything unusual....
SO.. we have something a bit hard to service, you are deliberatel;y avoiding servicing... and tyhen wondering why it does something a bit odd... and looking at anything and anything RATHER than bite the bullet and tackle that routine, every 2ooo mile or so, anticipated maintenence.
Hint.... go buy the proper tappet tools. They cost aproximately £15 tosave much faffing about trying to grip the tappet square and chew it up with a pair of pliers or similar.. AND DO WHAT MAINTENANCE the book says should be done.
Stop trying to dodge it.
Otherwise, you and anyone that tries to help you is frankly pizzing in the wind on a road to no-where, searching for ever more obscure possibilities to help you look ANYWHERE but at what is the most likely cause' of the problem you report.
Your call.. but FFS go get them tappets done, and done properly. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
siedlikmaster |
Nobby the Bastard |
siedlikmaster |
Easy-X |
Easy-X Super Spammer
Posted: 00:42 - 22 Mar 2020 Post subject: Re: It could be Valve clerances then. |
Nobby the Bastard wrote: | siedlikmaster wrote: | Today I have check the fuel tank etc. clean the carbs etc.
When the bike is on the stand, with rear wheel not touching the ground its perfectly fine, it only bogs down under pressure.
So you could be right with the Valve clearances.
Will get the tappet tool, maybe from Amazon, so will get it tomorrow.
Anything else should I get ?
If its not the valve clearance, then maybe pistons ?
First will do the clearance, and if that will not help then will just go to the mechanic.
Thanks. |
What exactly do you possibly think could be wrong with the pistols?
Made of cheese? |
Maybe the rings are shot? Low compression, that sort of thing... do you have to be a bastard all the time? ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Riejufixing |
siedlikmaster |
Posted: 20:00 - 22 Mar 2020 Post subject: Re: It could be Valve clerances then. |
Riejufixing wrote: | siedlikmaster wrote: | Today I have check the fuel tank etc. clean the carbs etc.
When the bike is on the stand, with rear wheel not touching the ground its perfectly fine, it only bogs down under pressure. |
I'm beginning to think that I don't understand your description of the problem.
How does the above come about? You put it on its centre stand (?) and run it, it runs fine without the tyre touching the ground?
What happens when you ride it (something more descriptive than "bogging down" might be useful). Video? Sound recording? |
After messing with the valve clearance, I was only able to unscrew the intake one.
The intake clearance is as it should be now, maybe it was bit to tight before.
I have put the bike all together now, took it to the parking for a test ride.
So for the first hour the bike was like bogging down/backfiring on gear 2nd and higher ones.
But after riding it in town for 2 hours, the problem went kind of away.
It does not bog down/missfire anymore, but I can hear some kind of small backfire.
Maybe the fuel was bad or something or a bit of water ? Will install a fuel filter this week, and will check the out-take clearance as the bolt was stuck, maybe that will stop small backfire.
Thanks. |
siedlikmaster |
Posted: 19:38 - 03 Apr 2020 Post subject: Re: It could be Valve clerances then. |
I have found the time today and I fixed it properly. I have set the valve clearance with the right tool, Intake set at 0.10 and Exhaust set at 0.15. It does not hesitate/bogs down.
But the only issue now I got is at high RPMs, at 9K RPMs its like not getting any faster, where before I was able go to 10K RPMs without problem.
Top speed before I was able to archive is 60mph on one of the roads.
Where now max speed was 54mph on that road, maybe will have to set clearance a bit bigger. or mess with the carbs
Thanks guys for pointing that it was issue with VALVE CLEARANCE. |
The last post was made 4 years, 16 days ago. Instead of replying here, would creating a new thread be more useful? |
