andym |
andym World Chat Champion
Posted: 17:20 - 12 Mar 2020 Post subject: Kicked out and barred from a PC shop |
I've only been using PC's for about 24 years, so obviously I haven't got a clue about them.... So maybe someone with a bit more knowledge can help me out a bit.
The guy in the shop said that I couldn't connect more than the CPU fan to the motherboard, all the rest needed to be connected with molex connectors.
I said I didn't want the fans spinning at 100%, and would rather they were controlled by the system, he said that they wouldn't be spinning at 100% because they have different amp ratings
As far as I'm aware, (and correct me if I'm wrong here), if you have a 12v fan that spins at 1200rpm (irregardless of amps), you connect that to a 12v power supply and it will spin up to 1200rpm and stay at that speed.... he said no it wouldn't and after about 20 minutes of disagreeing he told me to go elsewhere for the leads as he wasn't serving me |
MarJay |
MarJay But it's British!
colink98 |
colink98 Could Be A Chat Bot
Ste |
Ste Not Work Safe
UncleFester |
Posted: 19:14 - 12 Mar 2020 Post subject: |
Change PC shop and buy your shit off Ebuyer / Scan.
The bloke is clearly an idiot.
You might not want too many large fans drawing lots of current from the mainboard .... that's not daft but it's not a hard rule as long as you are within tolerance.
You can get seperate fan controllers if you want 14 x 140mm case fans running at whatever speeds.
And if you want all fans running flat out then use Molex directly off the PSU ( he does know most boards let you specify fan speeds anyway and most have an app in Windows for you to fiddle with.
But as long as you are not drawing more current than the board fan outputs are rated for then you'd be fine doing it you way - the right way.
Most decent PWM fans come with the correct leads for the board although you can get Molex to PWM convertor leads.
https://www.amazon.co.uk/s?i=aps&k=molex%20to%20pwm&ref=nb_sb_noss_1&url=search-alias%3Daps ____________________ Module 1 and 2 passed - October 2014. Happy owner of a 2017 Z1000SX, ex owner of a YBR125 / CB500 / VFR800. |
Ste |
Ste Not Work Safe
andym |
andym |
Ste |
Ste Not Work Safe
Posted: 19:48 - 12 Mar 2020 Post subject: |
It makes sense but I can see why the guy might have been reluctant to sell you those splitters.
If wanting to make a setup like that, you'd need to see how many amps the fan headers on the motherboard are rated for. because then you'll know if things will get melty.
The two fans on the radiator are running as extractor fans and blowing air out of the case? |
Ste |
Ste Not Work Safe
defblade |
defblade World Chat Champion
xX-Alex-Xx |
colink98 |
P. |
P. Red Rocket
Easy-X |
Easy-X Super Spammer
xX-Alex-Xx |
RhynoCZ |
RhynoCZ Super Spammer
Posted: 12:38 - 14 Mar 2020 Post subject: |
Yep, what defblade says, use a resistor on the red (+) wire going to the fan. Noctua even sells ''noise reduction adaptors'', that are exactly that. I used those for years, having all the case fans pretty much run at 80% of their capability, to get them inaudible, yet still moving air around. Nowadays, I run 140x140mm case fans, that are inaudible so I leave them at 100%.
I do however agree, that PWM fans are the way to go. Even then some of the motherboards can work with standard voltage regulation fans. OR even better, buy some of the big 120x120 or 140x140 fans, that spin at 1000 rpm, move crap loads of air, while being completely inaudible.
Experience time; if you have a low TDP computer or it sits at idle for most of the time, I would even have the PWM case fans to stop when there is no need for the airflow. That way you not only reduce the noise, but you also drastically reduce the dust collection inside the computer, on the filters. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
Ste |
Ste Not Work Safe
Posted: 14:00 - 14 Mar 2020 Post subject: |
andym |
GettinBetter |
GettinBetter Crazy Courier
The last post was made 4 years, 44 days ago. Instead of replying here, would creating a new thread be more useful? |
