Honda CB500 (2001) Front brake pads replacement
blackscorpion
PostPosted: 20:42 - 13 Mar 2020    Post subject: Honda CB500 (2001) Front brake pads replacement Reply with quote
I'm after advice here: I need to replace the front pads on my CB500. Once I remove the caliper, is it a straightforward task? Anyone tell me the procedure?
Cheers,
Sean.
"The light that burns twice as bright, burns half as long". ['Roy Batty', Blade Runner (1982, Warner Bros)]
PostPosted: 21:03 - 13 Mar 2020    Post subject: Reply with quote
Really easy. PROVIDING YOU DO NOT LOOSE THE LITTLE R-CLIP THING!
Wear gloves. brake dust is nasty.
They are held in with a pin which is in turn prevented from coming out by a little R-clip (which is a special shape fro that calliper). Take the clip out, remove the pin (you may need to push it through from the back with a small drift/nail whatever). pads will lift out.
Give it all a clean up with spray brake cleaner (I use an old toothbrush to get all the dust off).
Push the pistons back in, I can usually do it with my thumbs or you can gently lever them back in with an old screwdriver if you put the old pads back in. Fit the new pads (I put a very thin smear of copper grease on the back of the brake pads) making sure they engage in the metal anti-rattle clip properly. Insert the pin. Insert the clip. Done.
Put them back on, pump them back up to pressure. Check the fluid level. Check they work.
The last post was made 6 years, 215 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.11 - MySQL Queries: 14 - Page Size: 32.33 Kb
