Hong Kong Phooey |
Posted: 15:45 - 16 Mar 2020 Post subject: |
sickpup wrote: | Hong Kong Phooey wrote: | Ok, I'll bite. To what degree do Brembo machine in this uneven wear on brand new discs?
I did also state that warped discs might not be the only cause.
Flushes out what exactly?
https://www.thetriumphforum.com/threads/abs-bleeding-breaks.14130/
Not just US. I believe if you can get it, it's old stock. Probably marked not for road use too. |
In order.
I have no idea.
Brake fluid. Your link actually states that the brakes can be bled without the software. Think of it this way when the bike is switched off the brakes still work. Obviously on a Harley the brakes never work
The blue stuff is/was only non-compliant to DOT standards due to the dye, it was still DOT 4. |
My point being he has no idea of the history, blue old fluid is probably just blue old stock fluid and should be replaced in entirety. No idea if he'd even ridden it until about the 4th reply.
He has no idea if air is, or has ever been in the ABS module, so it's wise to bleed it fully, properly.
BTW he's already done the master cylinder.
OP, what is the disc thickness and runout? ____________________
jaffa90 |
jaffa90 World Chat Champion
sickpup |
sickpup Old Timer
Hong Kong Phooey |
steve the grease |
Nobby the Bastard |
Gazz |
Gazz World Chat Champion
Posted: 18:59 - 20 Mar 2020 Post subject: |
Been back out at the bike today after trying something that was suggested on another forum:
Which was; took the n/s caliper off and hung up on the o/s fairing so that the curve in the brake line ( which bends over the wheel) was straightened out. Left it a couple of days with the brake lever cable tied. And went back and bled the brakes today with caliper in the air.
And........
Still the same story.
First pull comes back to lever, subsequent pulls firm's it up. Leave it for a few seconds and it's back to the lever.
Check the hoses for any signs of wear or anything but nothing looks untoward.
The only thing I can think of is perhaps buying another lever with a straighter arm on it but that's not exactly fixing the issue. |
cresad |
cresad Nova Slayer
Gazz |
cresad |
cresad Nova Slayer
sickpup |
sickpup Old Timer
The last post was made 4 years, 38 days ago. Instead of replying here, would creating a new thread be more useful? |
