Royal Enfield Bullet 500 '94 Trouble starting
piratebiker
PostPosted: 15:03 - 18 Mar 2020    Post subject: Royal Enfield Bullet 500 '94 Trouble starting Reply with quote
Was running fine, couldn't start it next day, eventually started but running but very lumpy, won't idle & backfires. Any help. Thanks.
PostPosted: 15:14 - 18 Mar 2020    Post subject: Reply with quote
Sounds like fuel starvation. You hearing the pump prime when you turn it on?
jaffa90
PostPosted: 16:17 - 18 Mar 2020    Post subject: Reply with quote
It does sound like fuel starvation,
Is it the carb version or fuel injection?
PostPosted: 16:20 - 18 Mar 2020    Post subject: Reply with quote
Fuel injection wouldn't hit until 2008. Could be timing's slipped, shit or water in the carb, dodgy coil/lead etc. Don't think it's early enough for the emergency start ignition position, which was very hit or miss on my ex's 350.
piratebiker
PostPosted: 18:14 - 18 Mar 2020    Post subject: Reply with quote
Carb.
PostPosted: 18:18 - 18 Mar 2020    Post subject: Reply with quote
How is it for compression?
Battery charged? (they don't run well on a very flat battery). Getting good deflection on the ammeter when you turn it over?
Ignition timing would probably be my next concern. Faulty condenser can also cause such issues.
No harm in cleaning the carb out although it's probably an electrical problem. The rubber type intake manifolds can split after a while which would help nothing.
PostPosted: 20:29 - 18 Mar 2020    Post subject: Reply with quote
Lol... I should try reading more Doh!
piratebiker
PostPosted: 09:16 - 20 Mar 2020    Post subject: Reply with quote
Stinkwheel solves it again, yep, on closer inspection the rubber connected to the engine is split. Where can i get one? Thanks man.
PostPosted: 10:32 - 20 Mar 2020    Post subject: Reply with quote
Get a proper mikuni one (the mikcarb is a licenced copy of a mikuni VM28).
Hitchcocks sell them.
https://accessories.hitchcocksmotorcycles.com/accessory-shop/carburettor-parts/1723
piratebiker
PostPosted: 15:47 - 26 Mar 2020    Post subject: Reply with quote
Thanks Stinkwheel, the new rubber manifold sorted it, runs like a dream again.
piratebiker
PostPosted: 18:17 - 27 Mar 2020    Post subject: Running a little rich Reply with quote
The plugs a bit black & sooty, running a bit rich? Is there an adjustment on the carb? Thanks.
PostPosted: 18:57 - 27 Mar 2020    Post subject: Reply with quote
What sort of carb? Mikcarb or Amal?
In either case, some how-to sheets here:
https://accessories.hitchcocksmotorcycles.com/Technical-Notes
piratebiker
PostPosted: 20:06 - 27 Mar 2020    Post subject: Reply with quote
Not sure,
PostPosted: 23:44 - 27 Mar 2020    Post subject: Reply with quote
That looks like a Mikcarb - a copy of the Mikuni VM28 which funnily enough I seem to have on my old DT Smile
Might want to report back with the main jet size and the needle's clip position.
Oh, and cable ties aren't a great way to secure hoses. I would suggest getting a jubilee clip or similar.
PostPosted: 23:51 - 27 Mar 2020    Post subject: Reply with quote
As above, standard mikcarb. They are generally pretty reliable.
A black plug CAN be running rich. It can also be burning oil.
There is a jetting guide for mikcarbs on this page:
https://accessories.hitchcocksmotorcycles.com/carburettor-parts
Tdibs
PostPosted: 12:19 - 28 Mar 2020    Post subject: Reply with quote
How snug is that boot on there with the cable tie? looks like its not quite home, possible leak?
PostPosted: 12:35 - 28 Mar 2020    Post subject: Reply with quote
In fairness, they run acceptably well with no air filter on at all. The "airbox" is effectively a big rectangular steel box often referred to as a "tea caddy" and the filter is a huge paper element affair. There is no real contribution to carburettion efficiency, it's purely there to stop small mammals and birds being sucked into the carburettor. If anything, an air leak there would make it run lean.
From the state of it though, I suppose a blocked air filter could be restricting air flow and make it run rich.
piratebiker
PostPosted: 11:23 - 29 Mar 2020    Post subject: Reply with quote
The boot is on tight, I'll check the air filter, thanks.
The last post was made 4 years, 28 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.59 - MySQL Queries: 17 - Page Size: 99.4 Kb
