sickpup |
sickpup Old Timer
Pete. |
Pete. Super Spammer
Posted: 16:22 - 25 May 2020 Post subject: |
My GS550 had a slightly bent valve and you could see the head tilt every time it seated. I had to change the valve though, I just imagined that after tens of thousands of cycles it would eventually let go at the neck.
BTW there's no such thing as 360 degrees and 2 teeth out on a wasted spark engine. It's either 2 teeth or not 2 teeth. ____________________ a.k.a 'Geri'
kramdra |
kramdra World Chat Champion
Pete. |
Pete. Super Spammer
Posted: 17:23 - 25 May 2020 Post subject: |
IIRC valves are closest to the piston at roughly 10 degrees before and 10 degrees after TDC. ____________________ a.k.a 'Geri'
kramdra |
Posted: 18:42 - 25 May 2020 Post subject: |
Ok last question for today
https://i.postimg.cc/vTb2mgy4/IMG-20200525-182459.jpg
To me these look and feel like cracks. Its common for cam bearing caps or camshafts to crack if tightened incorrectly? I remember the noise made by the cam bolts on my other engines as they were loosened off. A lot of stress there.
As only a couple of shims are 5-10 microns out, less than a blond one, should I leave it as is, or try to change the shims?
Bearing cap will be line bored to the head, its not a replaceable part so if its not servicable then the head/engine, will be scrap. |
sickpup |
sickpup Old Timer
Nobby the Bastard |
kramdra |
Posted: 20:15 - 25 May 2020 Post subject: |
Nobby the Bastard |
Posted: 20:18 - 25 May 2020 Post subject: |
For what? ____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Sprint ST 1050 |
kramdra |
Nobby the Bastard |
Pete. |
Pete. Super Spammer
Posted: 21:43 - 25 May 2020 Post subject: |
Most bikes of that ilk with their symmetrical cams will be at 10 and 2 o'clock on TDC on the firing stroke. Since the followers are on the base cam base circle it's safe to check the valves that way.
'Cracks' look like normal casting flash marks to me. Nowt to worry about, a feature of the investment casting process. ____________________ a.k.a 'Geri'
Hong Kong Phooey |
kramdra |
Fizzer Thou |
Posted: 23:32 - 26 May 2020 Post subject: |
That piece of metal that has been floating around inside the cam cover area looks like the top cam chain tensioner guide that is there to stop the chain flapping around
https://i.postimg.cc/B6pPW8qr/IMG-20200522-190333.jpg
Fowlers of Bristol appear to have them in stock (as well as the rear tensioner guide blade).Not parts very easily made.
https://www.fowlersparts.co.uk/parts/4831060/cbr600f1-2001-e/cam-chaintensioner
As for the cam chain tensioner blade that you are contemplating purchasing from Dave Silvers,all that they would do is to buy it from a main dealer like Fowlers of Bristol.Better to buy direct.
The beauty of having the cam chain at one side of the engine is that it is a lot easier to replace once you have removed the chain from the cam sprockets.On my 5JJ-R1 I can remove the chain from the crankshaft once the tensioner has been removed.It is then easily lifted out and the new one dropped down through the chain tunnel.
I would be replacing the cam chain at the mileage that the engine has done.Although an OEM chain is £78 from Fowlers.
It seems that exactly the same chain is available from the likes of Wemoto.The fact that it states that a rivet link is available suggests it can be done differently to how it can be done on my R1
https://www.wemoto.com/bikes/honda/cbr_600_f1/01/picture/cam_timing_chain_borgwarner
At least the shims are relatively cheap at around £5/shim
https://www.wemoto.com/bikes/honda/cbr_600_f1/01/picture/valve_shim_1.40_mm
Do not forget to replace the cam cover seal
https://www.fowlersparts.co.uk/parts/view/12391MBWJ20
It all adds up but it is a good idea to do it with the right parts.I would not think that it would be that worthwhile contemplating making your own shims to the sort of accuracy required for what you need. ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
kramdra |
Hong Kong Phooey |
Posted: 15:34 - 27 May 2020 Post subject: |
Fizzer, I've done this and the cam cover gasket is sturdy enough not to need replacing admittedly mine had only done 50k.
Kramdra, any oil resistant sealant works, just a dab around the areas you mentioned. I bought this about 10 years ago and it was fine 5 years later...
https://www.halfords.com/tools/garage-equipment/head-gasket-and-exhaust-repairs/loctite-si-5980-flange-sealant-599720.html
Used it again a few weeks back and it's still going strong
Not leaking a drop on the cbr nor my mates who dropped it. ____________________
kramdra |
Posted: 16:00 - 27 May 2020 Post subject: |
Thanks.
As I said earlier its about 12 years since Ive pissed inside a proper engine. Ive got the cam bolts out but it is not free and does not pull free. Before I grab my angle wedges and gently tap it out, is there anything I have missed?
The book mentions dowel pins, so it needs to come off straight.
https://i.postimg.cc/ZRhm8mxY/IMG-20200527-155530.jpg
Two remaining bolts are in blind holes.
Edit - seems stuck on a dowel pin in the center at no.1 end. It is now off. |
Hong Kong Phooey |
Posted: 16:42 - 27 May 2020 Post subject: |
Don't drop them shims
Make sure to torque it back up and follow the tightening pattern.
If you don't, you won't get the clearances you calculated for.
Recommend you buy shims they're case hardened for this application. ____________________
kramdra |
kramdra |
Pete. |
Pete. Super Spammer
Posted: 17:26 - 29 May 2020 Post subject: |
The 1.90 and 1.95 will be fine. They are only 1 thou under your target. Too loose is ok, it's too tight you want to avoid. ____________________ a.k.a 'Geri'
kramdra |
Posted: 00:07 - 30 May 2020 Post subject: |
Something I noticed at the start and ignored, the shims have a recessed step in the center where it sits on the valve. They all have it, so not improtant for the shims I shuffle round. The center step is smaller than a normal mic head, so I can expect my readings to all be a thou oversize.
I have cut the first shim.
https://i.postimg.cc/k5DP9B7n/IMG-20200529-224505.jpg |
Pete. |
Pete. Super Spammer
Posted: 06:36 - 30 May 2020 Post subject: |
They are not supposed to have a recessed step, so make sure you're measuring from the bottom of the recess when you take the thickness measurements. If your measuring tool didn't manage that first time round (which you say it didn't) then you're going to have to turn off the OTHER side of the shim or none of your measuring work so far will count.
You'll also need to make sure that the shims go back in with the recess against the valve otherwise your clearances will close up by the depth of the recess. actually, this might be a way to get over your 'too thin' shim problem.
If this were me I would re-fit all of the shims inverted and start all my measuring again. ____________________ a.k.a 'Geri'
Nobby the Bastard |
The last post was made 3 years, 333 days ago. Instead of replying here, would creating a new thread be more useful? |
