JackButler |
JackButler Traffic Copper
Suntan Sid |
Posted: 10:57 - 23 Mar 2020 Post subject: |
To set a level for the bottom of your trench.
You do not say what sort of level you have so I’ll assume it’s a laser, (it would be easier if you had a dumpy level and a proper measuring staff).
First of all you don’t need to be deadly accurate, +/- 25mm will be more than acceptable.
Mark out the centre line of the trench on the ground, some string and pegs will do.
Set stakes in the ground, just outside the width of the trench, at the corners and at intermediate points along the trench.
Site your level at a point where you can see all the stakes.
Centre the bubble on the level.
Using the laser, point it at each stake and mark the level of the laser on each stake.
Assuming you know how far below ground the footing must be, start digging your trench at the lowest corner and work from there.
As long as the bottom of the trench is an equal distance down from the datum marks you made it will be level enough! ____________________ "Everybody needs money, that's why they call it money!" |
MCN |
MCN Super Spammer
Howling Terror |
Howling Terror Super Spammer
Posted: 13:57 - 23 Mar 2020 Post subject: |
One word.
Knackered.
People who aren't used to using a spade and shovel soon get knackered.
Most get blisters on inside of thumbs and across the palm.
Aching at base of back.
Do as doggone and Ste mentioned, oh and and keep your feet away from the mattock.
Spade and shovel I hear you ask?
Think of the spade as a knife and shovel as the spoon.
Shovel is kinder to the back too.
Combined they can be used in digging deep narrow holes.
Spent too long on the wrong end of spade n shovel.
Don't get me onto digging bars. When Andy hit the 11,000v cable and it blew off the end of a 2" diameter bar leaving Andy 10ft away on his arse...Impressive as he's a solid sort of fella.
Oh another word.
mini-digger.
____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
Suntan Sid |
Riejufixing |
Howling Terror |
MCN |
MCN Super Spammer
- Super Spammer
Ste |
Ste Not Work Safe
MCN |
MCN Super Spammer
Chuffin Nora |
Chuffin Nora World Chat Champion
Pete. |
Pete. Super Spammer
Islander |
Islander World Chat Champion
Posted: 20:13 - 30 Mar 2020 Post subject: |
Have you thought about what you're going to do with the spoil? By the time it's out and broken up, you'll end up with about 1.5 times the volume of the actual excavation...
It was the single biggest problem I had when I put land drains in here and I've got a 1 acre field and the shoreline for disposal.
Oh and hire a mini digger. They're dead easy to drive, are great fun and you can get a lot done in a fairly short space of time. Do it by hand and it'll take you a lot longer than you think and you'll suffer. |
- Super Spammer
- Super Spammer
Posted: 20:29 - 30 Mar 2020 Post subject: |
Pete. wrote: | - wrote: |
How wide and how deep? a 5M x 6M building will have 22M of trench to dig out. At 1M deep, and 1M wide, that's 22 cubic metres.
A cubic Metre of concrete weighs 2.5 ton, so you'll need 55 tons of concrete.
Best of luck doing that with a bucket and spade. |
Ahem - 5m x 6m footing at 1m x 1m square is 18 cubic metres of digging not 22 - unless you're going to dig the corners twice. |
That’s wrong too. The trenches will be 6M and 7M as the 5M and 6M walls will sit in the middle of them, not the outer edge. It was a quick guess to show it’s more than the OP realises. Let’s face it, they don’t need to be 1M wide, I was just using it to give an easy approximation.
18, 24 or 22CM3 it makes no odds, he’s not going to do that with a bucket and spade.
I find it startling that he’s going to all the effort to make the bottom of a trench dead level, when it doesn’t make the blind but if difference if he's Pouring in liquid concrete, yet he’s got no idea that he won’t be able to do this by hand.
Over planning the completely irrelevant, whilst not paying attention to the basics is the OP’s motto. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG.
Ste |
Ste Not Work Safe
Pete. |
Pete. Super Spammer
- Super Spammer
Diggs |
Diggs World Chat Champion
Posted: 04:00 - 31 Mar 2020 Post subject: |
Lots of nonsense here. If the building is to be 5x6m it is unlikely to need deep strip foundations and (presumably) a suspended floor. Most likely it will have a concrete floor which will be formed by a slab on compacted hardcore. OP will need to dig out to 400mm minimum to allow for 250mm plus 150mm concrete. Roughly speaking this will need two skips, and filling two skips by hand will kill the OP so I predict him hiring a man with a Bobcat sharpish... O.P. will have to import 10 cu.m of hardcore which will also kill him. Unless he can pump his concrete he will need to carry and mix 5 cu.m on site, which if he is still alive by that point will finish him off for good... Methinks the O.P. does not understand what is involved 🤔 ____________________ Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting...
- Super Spammer
Diggs |
Posted: 10:56 - 31 Mar 2020 Post subject: |
- wrote: |
Nobody yet has managed to explain why the fecking trench needs a perfectly level bottom surface |
Construction takes place using horizontal planes, therefore in order to achieve the required depth of foundation and not use too much concrete, it makes sense for the bottom of the trench to be horizontal also. The bottom doesn't need to be perfectly flat, but the more level it is overall, the cheaper the build. ____________________ Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting... |
The last post was made 4 years, 19 days ago. Instead of replying here, would creating a new thread be more useful? |
