| sparkywilliam... |
 sparkywilliam... Scooby Slapper
| Boris the spider |
 Boris the spider Nearly there...
| sparkywilliam... |
 Posted: 20:34 - 24 Jun 2014 Post subject: **update** |
Figured out what it is....
I put a wet towel draped over the tank then after 30 mins/hr fuel pump primes fine,bike starts and everythings ok.
Found this out by googling it and seems a problem pump when the weather becomes hot,weather its expansion of fuel or the pump itself i don't know but i've taken the base plate out of the bottom of the tank and pulled out the float and fuel pump assembly.
The fuel pump has the part no's:
hyundai
1100-00780-B
2527
07011010
i've seen the following pump below which has been recommended before by other users:
https://www.ebay.co.uk/itm/New-Intank-30mm-Fuel-Pump-for-Yamaha-YBR-125-YBR125-2007-2014-/281366902476?pt=UK_Motorcycle_Parts_13&hash=item4182c636ccå
but wondered if anyone out there had a good working one and perhaps one that was from a later bike? ____________________ Previously CG125,YBR125 Now GSF600 Bandit |
| Mark65 |
 Mark65 World Chat Champion
| sparkywilliam... |
| Mark65 |
| sparkywilliam... |
There is a gap of 5 years, 265 days between these two posts... |
| member1351 |
 member1351 L Plate Warrior
| Riejufixing |
 Riejufixing World Chat Champion
 Posted: 13:06 - 07 Apr 2020 Post subject: |
No idea, but there's an ebay item which very closely mathces the URL above:
2014: https://www.ebay.co.uk/itm/New-Intank-30mm-Fuel-Pump-for-Yamaha-YBR-125-YBR125-2007-2014-/281366902476?pt=UK_Motorcycle_Parts_13&hash=item4182c636cc%EF%BF%BD
2020: https://www.ebay.co.uk/itm/New-Intank-30mm-Fuel-Pump-for-Yamaha-YBR-125-YBR125-YBR-125-2007-2015/281800454087?hash=item419c9dafc7:g:AHEAAOSwZjJU4YvF
£26.25 all in. Who knows, not me, that's just a guess. |
| WD Forte |
 WD Forte World Chat Champion
| member1351 |
 Posted: 13:49 - 07 Apr 2020 Post subject: |
| Riejufixing wrote: | No idea, but there's an ebay item which very closely mathces the URL above:
Thanks mate. I am very tempted to get one of these. Although it is not a 2 mins job to change the fuel pump! Want to avoid going through this process again if the replacement just does what the original part have done! |
| member1351 |
| WD Forte |
 Posted: 14:00 - 07 Apr 2020 Post subject: |
Not a ybr owner so cant speak from experience
but ethanol 85 proof and good guarantee and feedback may help
choose a seller
Fowlers will flog you a pukka one but it will probably be spendy
Just had quick look at foulups parts
how does £261 suit you?
Non in stock mind you, you'd have to order it ____________________ bikers smell of wee |
| member1351 |
 Posted: 14:05 - 07 Apr 2020 Post subject: |
| WD Forte wrote: | Not a ybr owner so cant speak from experience
choose a seller
Non in stock mind you, you'd have to order it |
I see.
£261 will be way above economical to spend on the bike of this age. I may just opt for a simple Fuel Pump replacement. If it doesn't fix the issue then will have to live with it! |
The last post was made 6 years, 160 days ago. Instead of replying here, would creating a new thread be more useful? |
