2015 Cbr600rr
Skittleskawi
PostPosted: 00:46 - 12 Apr 2020    Post subject: 2015 Cbr600rr Reply with quote
How can I adjust the idle on a 2015 Cbr600rr??
Skittleskawi
PostPosted: 09:26 - 12 Apr 2020    Post subject: Reply with quote
It's fuel injected.... What's the problem?
Easy-X
PostPosted: 11:08 - 12 Apr 2020    Post subject: Reply with quote
You might be able to adjust the angle of the Throttle Position Sensor (TPS) but it's not quite the equivalent of twiddling a carb idle screw. Usually such things are set at the factory and that's that. Again, one has to ask why you want to raise the idle speed? It shouldn't be used to compensate for another problem...
For example, if it's running rough from cold I'd ask when's the last time the valve shims were checked (and then we'd get onto a whole new conversation.)
xX-Alex-Xx
PostPosted: 21:45 - 12 Apr 2020    Post subject: Reply with quote
Older CBRs had an idle adjustment screw by the left fairing. Not sure about the later models... Guessing they don’t have them as they’ll be fly by wire.
DILLIGAF
The last post was made 6 years, 150 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.59 - MySQL Queries: 14 - Page Size: 37.98 Kb
