Few questions about my GPZ500S
Carl157
PostPosted: 14:34 - 15 Apr 2020    Post subject: Few questions about my GPZ500S Reply with quote
Hello Everyone,
I’m new to this forum and relatively new to biking after passing my A2 July last year. I’ve had my 96’ GPZ500S around 8 months now. I’m new to old bikes but so far its been a good first Big bike. I have a couple of questions for anyone who may be able to help:
1) Is there any particular water coolant you would use for this bike?
2) I always leave the fuel tap in the ON’ position when I’m not riding, should I switch it to ‘OFF’ when not in use to avoid flooding the carbs?
Thanks for your help
Carl
PostPosted: 14:55 - 15 Apr 2020    Post subject: Reply with quote
You should use water and antifreeze mixed according to the directions on the antifreeze. It's almost certainly got ethylene glycol based coolant in so use that type. If you have particularly hard water in your area (look in the kettle, is it full of scale? If so, you have hard water), you should use distilled/de-ionised water. If your water is soft (clean, shiny kettle), I'd just use tap water.
The fuel tap is a vacuum one, if it is working correctly, it should turn itself off when the engine is not running. Been ages since I had a GPZ500 but does it even HAVE an off position? I thought there was on, reserve and prime (which is the same as on but doesn't turn off when the engine is off).
The ice that builds up inside a freezer and the water you drain off condensing tumble driers are both suitable to use as distilled water.
Carl157
PostPosted: 15:57 - 15 Apr 2020    Post subject: Reply with quote
Ok, I’ll give that a try.
Thanks
The last post was made 5 years, 182 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.91 - MySQL Queries: 16 - Page Size: 37.13 Kb
