Cloudy brake fluid reservoir
jlparsons
PostPosted: 10:57 - 15 Apr 2020    Post subject: Cloudy brake fluid reservoir Reply with quote
Hi folks, have noticed my brake fluid reservoir has a cloudy bit at the bottom which separates and sinks when the bike hasn't been moved a while. It then remixes when the brake is applied. Is this normal or does the fluid need replacing?
F800gt 12000 miles.
Riejufixing
PostPosted: 11:07 - 15 Apr 2020    Post subject: Reply with quote
I'd be inclined to change it, it could be water, or water in old/ incompatible fluid, or something else you don't want in there.
PostPosted: 12:41 - 15 Apr 2020    Post subject: Reply with quote
I'd change it. You may find you can suck out most of what's in the reservoir (just don't uncover the hole) then put fresh fluid in from a new bottle and start running it through (it'll usually go with gravity if you crack the bleed nipple).
If you attach a clear hose to the bleed nipple, you can usually see when the new stuff starts coming through, it's generally a slightly less yellow colour.
If there are lumps in the bottom of the reservoir, you may need to either flush it with a few changes of fluid or empty it totally and wipe it out. It may or may not need bleeding after that.
PostPosted: 16:13 - 15 Apr 2020    Post subject: Reply with quote
Is that not a sign of moisture in the fluid?
Whatever it is, time for a change as it's not exactly a huge financial hit to do even if you use a whole bottle flushing through the system.
Triumph Trophy Launch Edition
MCN
PostPosted: 19:27 - 15 Apr 2020    Post subject: Reply with quote
BMW put a little disc of open cell sponge in reservoir to prevent fluid aeration. I think it's due to bar vibration that agitates the fluid.
It's maybe the sponge you can see.
jaffa90
PostPosted: 01:22 - 16 Apr 2020    Post subject: Reply with quote
Over the years i`ve seen clear brake fluid and partly cloudy fluid but never seen floaters, all though not dangerous as yet i would be finding out what`s breaking up.
PostPosted: 08:27 - 16 Apr 2020    Post subject: Reply with quote
The brake fluid can crystalise after a time. Cloudiness is a precipitate which is an early stage of it forming a solid.
MCN
PostPosted: 10:50 - 16 Apr 2020    Post subject: Reply with quote
https://www.ukgser.com/forums/showthread.php/473560-Brake-reservoir-sponge/page2
If it has a sponge and it wasn't replaced after a while it can disintegrate.
That would be 'solids'. There's nothing much in brake fluid to solidify. Glycol-Ether.
Unless contaminated by something not glyco-ether.
Water, oil, grease, etc.
Should be replaced every two years as it will absorb atmospheric moisture which reduces it's boiling point and can encourage corrosion and freezing at very low temps.
PostPosted: 12:45 - 16 Apr 2020    Post subject: Reply with quote
What do you reckon this stuff is then?
It's in an old master cylinder reservoir out of my parts box. You can see brownish crystals above the "high tide" mark and a layer of varnisy sludge coating the inside of the reservoir. The fluid is a yellowy-brown. It was DOT4.
I'd suggest that while it was originally glyco-ether, a significant proportion of it is now something else. Probably hydrolysed to something else? (who'd have thunk it, exposing chemicals to extreme heat and pressure).
https://www.bikechatforums.com/download.php?id=103357
MCN
PostPosted: 20:32 - 16 Apr 2020    Post subject: Reply with quote
Could be bacteria growing in water feeding on the brake fluid.
https://www.researchgate.net/publication/303745627_Microbial_growth_in_brake_fluids
Glycol can discourage bacterial growth if the solution is high enough.
Bacterial growth in cooling heating systems is controlled by bacterial inhibitors glycol is one.
The crystals could be a component of the alloy the master cyl is made from. Leached out by something. Oxidation by bacterial by-product or something more sinister. (Couldn't be sinister as the brake would normally be on the right side.)
I hope you drained it, filtered it through an old set of Y-Fronts and poured it back in?
The last post was made 6 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.65 - MySQL Queries: 14 - Page Size: 65.54 Kb
