Paul allan |
Paul allan L Plate Warrior
Easy-X |
Easy-X Super Spammer
Bhud |
Bhud World Chat Champion
Paul allan |
Paul allan |
Easy-X |
Paul allan |
Bhud |
Paul allan |
MattE |
MattE Borekit Bruiser
Robby |
Robby Dirty Old Man
Posted: 22:05 - 27 May 2020 Post subject: |
To just stop it leaking, giving the float bowl (bottom bit) of each carb a sharp tap with the handle of a screwdriver will probably do the job. The problem is down to a sticky float and/or shit on the needle valve. Tapping the float bowl frees off a sticky float. Fresh petrol moving through a needle valve cleans it.
After 5 years, particularly on a bike like that, it should have a proper going over before back on the road. It's a serious amount of work just to check everything, some reasonable expensive jobs are highly recommend (full brake strip and clean) and some things are going need to be replaced just because of age (probably brake lines). Tyres are probably ancient too.
If all you want to do is get it running and MOTed, then sorting out the fuel leak and giving it a ride will help with a lot of things. Petrol cleans carbs well, particularly when assisted by a bit of heat, motion and vibration from riding the bike.
If you want to ride it more than that, it should have a proper going over. The bits that fail in a really dangerous way (brakes, tyres, chain, suspension) will also fail when they're under the most load and you need them most (braking hard, at speed).
To do all the work that I would do to a bike like that to put it back on the road would cost more than the value of the bike if you're paying a mechanic. Then another £200-500 in parts. |
Bhud |
Posted: 22:46 - 27 May 2020 Post subject: |
Good luck getting your carb issues sorted out.
With regard to comments about servicing the whole bike, I think that's something you also need to seriously consider. When otherwise good bikes are left standing they turn into projects. Going by what was needed on my GT550 last year (a good bike which had just been left standing), where I did all the work myself and didn't use a mechanic, the parts outlay for recommissioning well exceeded the value of the bike, and you should be prepared for this.
Example parts budget:
New front and rear tyres: £200-£300
New brake lines: £60-£100
New rear shock: £100-£250
New brake pads: £40-£100
New brake seals and/or pistons: £20-£80
New brake fluid: £5
Forks overhaul (dealing with scoring/rust spots, stiction issues, etc.) requiring new fork oil, seals and bushes: £50-£80
Budget for random seals gone bad (e.g. gear shift) and springing a leak: £30
Bearings (various, depending on need): £30-£60
All new fuel line and vacuum rubber hoses: £10-£20
New chain and sprockets if necessary: £100
Tank rust remover and cure and other treatment as necessary: £30
New battery: £30
Carb repair kit x 4: £40-£50
Budget for carb parts gone bad from disuse (e.g. diaphragms) or damage in servicing: £50-£80
Spark plugs: £20
Oil filter: £5
Air filter: £10
Oil replace: £20-£25
There could be a lot of other stuff needed, besides the items on this list, just on account of having been left standing. |
The last post was made 3 years, 334 days ago. Instead of replying here, would creating a new thread be more useful? |
