| kramdra |
 kramdra World Chat Champion
 Posted: 14:11 - 28 May 2020 Post subject: Fork oil |
I will be rebuilding my forks again with new genuine seals and bushes. I want maximum seal life with minimum maintence and do not care much if the handling is worse, as that is often more fun.
It seems to me that not all fork oil is the same, just like seals. I have tried several 10w oils without any noticable difference in handling, but some do appear to leak easier.
Some list a seal swell additive and others claim the lowest friction. My opinion is that seals require some friction to seal and mechanically wipe the oil from the tubes. Ive confirmed this by adding grease to old seals, the added friction wipes the tube clean, but it is a temporary measure, so I will avoid the low friction products.
My current seals also claimed 50% less friction, and as expected, that means they are shit
What brand oil to get, and what difference can I expect from a 15w or 20w oil?
Will this do what I want?
www.ebay.co.uk/itm/High-Performance-15W-15wt-Motorcycle-Fork-Oil-Suspension-Fluid-1-litre-1L/302462907923 |
| stinkwheel |
| Riejufixing |
 Riejufixing World Chat Champion
 Posted: 14:46 - 28 May 2020 Post subject: Re: Fork oil |
| kramdra wrote: | I will be rebuilding my forks again with new genuine seals and bushes. I want maximum seal life with minimum maintence and do not care much if the handling is worse, as that is often more fun.
£7.50 delivered if you order it from their website. Edit: £8.99 via eBay! .. Good ol' ebay.
I would not touch anything that makes the ride more "exciting" or that swells oil seals (?).
You don't want friction on oil seals, the oil film on the stanchions is there partly because you can't get it all wiped off by the seal's wiper, and partly so your oil seal does not wear out. If the seal's worn out, wrong, or damaged through wear or fitting, you may get seepage.
If you put more viscous oil in, the suspension will have more damping which may or may not be a good thing.
| Riejufixing |
 Posted: 14:50 - 28 May 2020 Post subject: |
| Hong Kong Phooey |
 Hong Kong Phooey World Chat Champion
| jeffyjeff |
 jeffyjeff World Chat Champion
| blurredman |
 blurredman World Chat Champion
 Posted: 06:47 - 29 May 2020 Post subject: |
ATF for me.. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 - 40k, 1989 MZ ETZ251 - 52k. |
| Confusion |
 Confusion Scooby Slapper
| Riejufixing |
| Pigeon |
 Pigeon World Chat Champion
The last post was made 6 years, 170 days ago. Instead of replying here, would creating a new thread be more useful? |
