carofmadness |
carofmadness Derestricted Danger
Posted: 16:25 - 29 May 2020 Post subject: Single cylinder tachometer |
Hi all, looking for some advice regarding a tachometer for a single cylinder bike. the bike does not have a mechanical tachometer drive and did not come with one from the factory.
The bike uses a points ignition system with wasted spark
I currently have a 60mm chrome speedo fitted to my bike and would like a tachometer to match as I like the look of 2 clocks on a cafe racer. While browsing the internet I came across a tachometer that matches my speedo and it was a good price, it said it is universal and works with most bikes so I purchased it. this is the same as the one that I ordered:
https://www.ebay.co.uk/itm/Warrior-Mini-60mm-Chrome-Tacho-Motorcycle-Bike-0-15-x-1000-RPM-Electronic/302333027399
When it arrived I looked at the installation instructions and it says that it is for 2 cylinder bikes so I don't believe it will work on my bike.
so my question is will it work or give me an incorrect reading? I don't want to fit it if it will read incorrectly because I would not be able to return it if it has been removed from the package.
If it will read incorrectly can I get an adapter to make it work?
something like this . . .? https://www.ebay.co.uk/itm/UNIVERSAL-TACH-ADAPTER-CONVERTER-COP-1-2-3-4-5-6-8-10-cyl-to-any-4-6-8-Tach/141979625888
I don't really want to purchase the above item as I am in the UK and shipping from America could bring customs charges. So does anyone know of something similar that I could use to convert the signal from the coil to what the tachometer will need to read correctly?
I did find an old post on the forum explaining a lot of this but it was for a car tachometer and just want somebody with a better understanding to tell me if it will work or not and to guide me in the right direction to get an adapter to make it work if one is needed. Here is the link to the forum post
https://www.bikechatforums.com/viewtopic.php?t=223779
Thanks in advance ____________________ 2018 Black Royal Enfield Continental GT 535 Single Cylinder (daily) : 1985 Honda CG125 (my first bike) : 2014 AJS Daytona 125 (my mums bike) |
Riejufixing |
jeffyjeff |
jeffyjeff World Chat Champion
WD Forte |
WD Forte World Chat Champion
steve the grease |
The Shaggy D.A. |
The Shaggy D.A. Super Spammer
carofmadness |
WD Forte |
Posted: 10:55 - 30 May 2020 Post subject: |
That tacho looks very like the £8 chinese one I fitted to my bullet.
The needle moved. Slowly and with no real degree of accuracy. Certainly coulodn't keep up with the motor, you'd have blown the engine and it would still have been climbing.
You don't really need one on a CG125 anyway. If you want the aesthetics of one, just but a cheap chinese unit and don't bother wiring it in, or prise the front off and fit a clock. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
wr6133 |
wr6133 World Chat Champion
Pete. |
Pete. Super Spammer
Posted: 11:40 - 30 May 2020 Post subject: |
A tacho is one of those novelty devices that you hanker after if you don't have one but never actually look at after the first few times.
Their most useful feature is that you can check which gear the rpm is a direct multiple of the road speed and use it to tell your speed should your speedo ever pack up. ____________________ a.k.a 'Geri'
carofmadness |
The Shaggy D.A. |
Posted: 12:43 - 30 May 2020 Post subject: |
I guess it doesn't matter if it works or not, then ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
The Shaggy D.A. |
Posted: 12:46 - 30 May 2020 Post subject: |
Thinking about it, it'll probably either read half the revs, the revs, or twice the revs. Could always print up a custom dial that works for the gauge, rather than getting the needle to read correct. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
WD Forte |
carofmadness |
The last post was made 3 years, 324 days ago. Instead of replying here, would creating a new thread be more useful? |
