| MattE |
 MattE Borekit Bruiser
| jaffa90 |
 jaffa90 World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 05:24 - 02 Jun 2020 Post subject: |
If you've cleaned the carbs as you describe then I guess the filter is the only option. Dunno why you should have sand in the fuel tank in Buckinghamshire.
BTW I think that model was only called a Katana in America. We call it a teapot
There was a UK Katana but that was a proper man's bike. ____________________ a.k.a 'Geri'
| jeffyjeff |
 jeffyjeff World Chat Champion
| redeem ouzzer |
 redeem ouzzer World Chat Champion
| A100man |
 A100man World Chat Champion
 Posted: 11:11 - 02 Jun 2020 Post subject: |
The problem I have had with more than one set of Mikuni CVs is the o-ring that fits around the brass float valve seat - the one you see when you unscrew the seat. Make sure you fitted the correct item in this position. I think also they are an imperial size. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| MattE |
| MattE |
| jeffyjeff |
| temeluchus |
| Shaft |
 Shaft World Chat Champion
| MattE |
| MattE |
| MattE |
| A100man |
 Posted: 22:06 - 03 Jun 2020 Post subject: |
| MattRides wrote: | Is this o ring supposed to go on the end of this float needle or have I misunderstood? |
No. The needle faces directly into the brass part of the valve. The brass part is held in place by a small screw and a clamp. If you undo the screw/clamp you can pull out the brass part (chamber) from the carb body. Around the brass part is an o ring. this is the part that goes hard and lets by.
The o ring in your picture looks like part of teh pilot/mixture screw assembly.
This is a bit over the top but might be helpful..
https://www.xjbikes.com/forums/threads/in-the-church-of-clean.14692/#post-120724 ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Pete. |
 Pete. Super Spammer
| A100man |
 Posted: 18:26 - 04 Jun 2020 Post subject: |
| Pete. wrote: |
A bit? Talk about chest-puffing. |
'tis murican.. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| MattE |
| Pete. |
 Pete. Super Spammer
The last post was made 6 years, 162 days ago. Instead of replying here, would creating a new thread be more useful? |
