| jackass1019 |
 jackass1019 Derestricted Danger
| NJD |
 NJD World Chat Champion
 Posted: 22:11 - 07 Jun 2020 Post subject: |
Oxfords own video: https://www.youtube.com/watch?v=63FFphOGfjk
Easy to do, and doesn't take all that long; but taking some care and time to install them will prevent issues down the line (using good glue, cable management etc).
The left (clutch) side is the easiest as its just a case of cutting the old one off, or using a hair dryer to warm it up (melting the glue currently underneath it) to remove it if wanting to keep for whatever reason.
Remove all the old glue (various methods available) and make sure handlebar is as smooth as you can get it. I use gorilla glue (not the glue provided as it eventually melts); place on inside of grip and on bar and wiggle on and then clamp in place with cable ties.
The throttle side is a little trickier as it requires removing the throttle cable, and then the throttle grip from the throttle tube. Same again: glue the grip to the throttle tube (not tube to the bar). Set required throttle free play and clamp with cable ties.
Depending on what glue you use leave clamped in place for a few hours and then remove and ride.
As for the wiring its just a plug and play type of connectors, need to locate and attach the connectors to the battery. Remove ground (negative) then positive (+, red) afterwards; install positive first then negative last.
As I say use some cable ties to manage the excess wiring, or cable tie in place.
If not confident with above a bike shop shouldn't take more than half of an hour to install in labour costs, but giving it a go won't hurt. Take notice of throttle grip free play (read up in manual before doing anything) and battery installation and removal and you should be fine. Good chance to lube throttle cable while you're at it as well. ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
| Nobby the Bastard |
| stinkwheel |
 Posted: 08:20 - 08 Jun 2020 Post subject: |
Most grips aren't glued on. Easiest way to remove the old ones intact is to lift up one end enough to get the end of a compressed air blow gun under it, stick the nozzle in and blow to pop it off.
Next easiest way is to gently work a thin screwdriver in under it, slide the straw of a WD40 tin in next to it, give it a good squirt, remove the screwdriver and straw and start rotating the grip forwards until it's loose enough to slide off.
Always de-grease the bar surface ind inside the grip before fitting the new grip, regardless of how you decide to hold it on. I usually use spray brake cleaner.
Personally, I've never glued a grip on, and I've fitted many, both heated and standard. I use hairspray. Never fitted a "solid" grip though, like to ones you get on cruisers, they've always had some degree of elasticity. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jeffyjeff |
 jeffyjeff World Chat Champion
| Nobby the Bastard |
| jeffyjeff |
| Freddyfruitba... |
 Freddyfruitba... World Chat Champion
| ThunderGuts |
 ThunderGuts World Chat Champion
| Andy_Pagin |
 Andy_Pagin World Chat Champion
| Nobby the Bastard |
| TravisBickle |
 TravisBickle World Chat Champion
 Posted: 18:58 - 08 Jun 2020 Post subject: |
Never fitted them from scratch but shortly after I got my current bike I found the throttle grip kept moving round (obviously I was pinning it too hard ). As others have said Gorilla glue works best but use sparingly because it expands like 3 or 4 fold and is very strong anyway. I found it best to key the surface of both the handle bar and the inside of the grip by using sandpaper before applying the glue. Apply glue to one surface and damp the other surface with water as the curing process is activated by water/moisture. ____________________ 2024 BMW M1000XR
2021 Honda CMX500 Rebel S
2016 Triumph Tiger 1050 Sport |
| stinkwheel |
| TravisBickle |
| NJD |
The last post was made 6 years, 159 days ago. Instead of replying here, would creating a new thread be more useful? |
