Another Ducati 1000 build...
buzzer1955
PostPosted: 15:08 - 13 Jun 2020    Post subject: Another Ducati 1000 build... Reply with quote
June 2020. I normally build bikes over the winter months... but with Corvid -19 we are not going on any holidays or getting out much so my wife suggested I start my winter project early! I think she prefers me in the garage!
I bought this bike a few years ago... and over the winter 2018/19 I built it into this you see below... over the summer of 2019 I put quite a few miles on it... and actually loved the bike! it feels light and nimble, handles and brakes really well! I normally sell my bikes on, but this time I decided to keep it. A couple of things bugged me though... The tank I used was a compromise, it looks wrong to me, and although the carb conversion worked well... I felt the Monster 38mm Mikuni CV carbs held it back performance wise.
So its in for another rebuild/refresh... cosmetic only as I did the engine last time, and that is running well. I will be fitting some 41mm FCR carbs, a new tank (999) and making a new seat. And maybe change the exhaust...
this build will take some time... but I guess that depends on how corvid 19 affects daily life!
https://jtccc.files.wordpress.com/2020/06/ironbridge.jpg
https://jtccc.files.wordpress.com/2020/06/50000904478_c977d1e09c_o-copy.jpg
https://jtccc.files.wordpress.com/2020/06/50001487126_c31277cc6c_o.jpg
https://jtccc.files.wordpress.com/2020/06/50001680317_6b7c3a5700_o-copy.jpg
Here are a few pictures from the first rebuild...
https://jtccc.files.wordpress.com/2017/08/cases-cleaned.jpg
https://jtccc.files.wordpress.com/2017/08/multistrada-crank-cases-4.jpg
https://jtccc.files.wordpress.com/2017/08/multistrada-engine-build-1.jpg
https://jtccc.files.wordpress.com/2017/11/multistrada-heads-stripped-for-cleaning.jpg
https://jtccc.files.wordpress.com/2017/12/heads.jpg
https://jtccc.files.wordpress.com/2017/12/brake-callipers-1.jpg
https://jtccc.files.wordpress.com/2018/10/build-2110-8.jpg
https://jtccc.files.wordpress.com/2018/10/speedo-housing-4.jpg
https://jtccc.files.wordpress.com/2018/11/engine.jpg
https://jtccc.files.wordpress.com/2018/12/build-date-51218-2.jpg
https://jtccc.files.wordpress.com/2019/01/seat-1.jpg
https://jtccc.files.wordpress.com/2019/01/seat-2.jpg
https://jtccc.files.wordpress.com/2019/01/ssdf-6.png
PostPosted: 16:33 - 13 Jun 2020    Post subject: Reply with quote
Fresh from my "eBay's most miserable bike" thread it's heartening to know it is possible to improve and bike and not fuck it up Thumbs Up
buzzer1955
PostPosted: 11:46 - 27 Jun 2020    Post subject: Reply with quote
Been working on making the manifolds from scratch… it’s been quite difficult to get the shape and angles right, while maintaining approximately the same length.. there now though and I am pleased with the results. took a while to smooth the bore with the die grinder where I had penetrated with the TIG welds....
https://jtccc.files.wordpress.com/2020/06/50038494351_f308e79aa6_o-copy.jpg
https://jtccc.files.wordpress.com/2020/06/50047229803_87a54c3fda_o-copy.jpg
https://jtccc.files.wordpress.com/2020/06/50049431238_1dd4a0844c_o.jpg
sulphur
PostPosted: 23:27 - 27 Jun 2020    Post subject: Reply with quote
You sir, are a wizard.
buzzer1955
PostPosted: 15:42 - 28 Jun 2020    Post subject: Reply with quote
I wouldn't go that far Mr. Green
here is the subframe i have been making the last few days… I have deliberately kept it short as this will be a short single seat, which is the next job to do… I have used Rose Joints for no other reason than I just like the look of them!
https://jtccc.files.wordpress.com/2020/06/swubframe-1-copy.jpg
https://jtccc.files.wordpress.com/2020/06/subframe-2-copy.jpg
buzzer1955
PostPosted: 12:45 - 03 Jul 2020    Post subject: Reply with quote
Next the messy job of making a seat, well I actually made two as I couldn’t decide on shape! Its the one thing many people ask how I do it, so I have written a tutorial on it rather than post all of it here.
here is the link to my blog page
https://jtccc.wordpress.com/projects-2/tank-and-seat-manufacture/
So just a few pictures…
https://jtccc.files.wordpress.com/2020/07/50060943846_e056c815a3_c.jpg
https://jtccc.files.wordpress.com/2020/07/00d.jpg
https://jtccc.files.wordpress.com/2020/07/50062031576_cb5a13191b_o.jpg
https://jtccc.files.wordpress.com/2020/07/mockup-small.jpg
PostPosted: 13:11 - 03 Jul 2020    Post subject: Reply with quote
Hmm... if CAD now equals Cardboard Aided Design this must be Polystyrene Mold from Stacked Layers or...
PMSL Laughing
Fisty
PostPosted: 13:55 - 04 Jul 2020    Post subject: Reply with quote
I can fap to this.
Fatter and faster than Fret
buzzer1955
PostPosted: 18:13 - 15 Jul 2020    Post subject: Reply with quote
Today I made up some cables for the FCR’s. as they are split I have used a cable junction box, and made up the cables from scratch, including the brass nipples which I have soldered on.
here is a link to a video to see the action...
https://youtu.be/f0Xjr0e7Ukw
https://jtccc.files.wordpress.com/2020/07/nipples-2.jpg
https://jtccc.files.wordpress.com/2020/07/50097038632_07e13d1604_c.jpg
buzzer1955
PostPosted: 18:15 - 26 Jul 2020    Post subject: Reply with quote
Lockdown is good for progress! I have finished the frame modifications to clear the carbs, and finished the fabrication on the rear subframe so it's off to the powder coaters tomorrow.
I have also stripped the rear shocker so I can change the colour on the spring... not sure what to yet, but definitely not yellow! had to make a clamp as these are strong springs and I have the utmost respect when working with them under this much tension, hence the beefy plate and studs!
And here is the engine...
https://jtccc.files.wordpress.com/2020/07/frame-powder-copy.jpg
https://jtccc.files.wordpress.com/2020/07/spring-removal-copy.jpg
https://jtccc.files.wordpress.com/2020/07/engine-ready-copy.jpg
https://jtccc.files.wordpress.com/2020/07/engine-ready-2-copy.jpg
Poseidon
PostPosted: 18:36 - 26 Jul 2020    Post subject: Reply with quote
And here's me bitching about the fact I'll have to drop the engine out of my S4 to replace the timing pulleys and give it a lick of paint. Nice work man...
1977 Honda CG125
Fisty
PostPosted: 20:02 - 26 Jul 2020    Post subject: Reply with quote
I have a semi and a little dribble of precum.
buzzer1955
PostPosted: 13:10 - 27 Jul 2020    Post subject: Reply with quote
here, this might push you over the edge Mr. Green
https://jtccc.files.wordpress.com/2020/07/engine-ready-3-copy.jpg
PostPosted: 16:30 - 27 Jul 2020    Post subject: Reply with quote
This thread needs a NSFW tag Wink
buzzer1955
PostPosted: 10:12 - 31 Jul 2020    Post subject: Reply with quote
Mr. Green Mr. Green Mr. Green
One of the things I have always struggled to get done is plating... I have had some terrible jobs done in the past, and lost critical small parts to the bottom of someone's plating vat!
so about 4 years ago I bought a plating kit to do zinc... Have to say it's VERY good and I have used it time and time again! its a bit time consuming, but time is something I have, particularly at the moment...
Here are the results for my latest build. the kit can do clear and yellow passivation, you can see the difference.
https://jtccc.files.wordpress.com/2020/07/50172531321_bb77149388_o-copy.jpg
https://jtccc.files.wordpress.com/2020/07/50172531291_c10db483f9_o-copy.jpg
Fisty
PostPosted: 12:44 - 02 Aug 2020    Post subject: Reply with quote
https://i.gifer.com/7vZB.gif
Fisty
PostPosted: 23:21 - 06 Aug 2020    Post subject: Reply with quote
Please sir, can I have some more?
buzzer1955
PostPosted: 09:43 - 07 Aug 2020    Post subject: Reply with quote
Sure... have a look on my blog Very Happy
www.jtccc.wordpress.com
Cool
buzzer1955
PostPosted: 17:26 - 08 Aug 2020    Post subject: Reply with quote
Now for the nice bit… putting it all back together! the frame came back from the powder coaters and as ever its a superb job! I know its a 50 mile round trip to this guy but his work is worth it, especially after the poor jobs I have had done in the past at local companies… Must be the easiest engine to put in a frame!
https://jtccc.files.wordpress.com/2020/08/50202179473_8ccc4e031f_o-copy.jpg
buzzer1955
PostPosted: 18:47 - 13 Aug 2020    Post subject: Reply with quote
More progress... no holiday, and no pressure to go out means more garage time... its a good job I have this project or I would be climbing the walls by now!
https://jtccc.files.wordpress.com/2020/08/50222557811_f8ec58c6dd_o-copy.jpg
https://jtccc.files.wordpress.com/2020/08/50222557716_fea8567cb1_o-copy.jpg
buzzer1955
PostPosted: 14:31 - 16 Aug 2020    Post subject: Reply with quote
One of the benefits of having a blast cabinet is the ability to clean parts up easily... But I have always struggled to get that nice shiny finish the professionals manage to get with glass bead. I went to the bead supplier a while ago and said that I was having problems, and he asked what pressure I was blasting at, to which I replied 120 PSI. he said that's your problem... its too high and you are shattering the glass beads and the broken beads are giving you a matt finish! he said to turn the pressure right down, and then up until you got the finish you want! its so much better, you can see the difference in the reservoir caps! it also gives a closed finish that dirty finger prints just wipe off, on the matt surface they are difficult to remove!
https://jtccc.files.wordpress.com/2019/12/bead-blaster-copy.jpg
https://jtccc.files.wordpress.com/2020/08/shot-2-copy.jpg
https://jtccc.files.wordpress.com/2020/08/shot-1-copy.jpg
buzzer1955
PostPosted: 13:04 - 19 Aug 2020    Post subject: Reply with quote
Back in its wheels now... Very Happy
https://jtccc.files.wordpress.com/2020/08/a-on-wheels-2.jpg
https://jtccc.files.wordpress.com/2020/08/a-on-wheels-1.jpg
https://jtccc.files.wordpress.com/2020/08/a-on-wheels-3-1.jpg
PostPosted: 17:30 - 19 Aug 2020    Post subject: Reply with quote
https://media.giphy.com/media/7mI0mLnprQCOs/giphy.gif
Fisty
PostPosted: 21:25 - 19 Aug 2020    Post subject: Reply with quote
https://i.imgur.com/Zch2AWw.gif
buzzer1955
PostPosted: 17:37 - 24 Aug 2020    Post subject: Reply with quote
been painting the tank and seat today... one of the tips I picked up many years ago is that when spraying small items, use a torch in your other hand and shine it from below... you can see where you are wetting out the paint... I love the way 2K lacquer glosses from the gun these days!
link to video here...
https://youtu.be/umG5TAFmm7A
https://jtccc.files.wordpress.com/2020/08/50263685151_052ca8e2ec_o-copy.jpg
https://jtccc.files.wordpress.com/2020/08/50263028703_a8f31c7ac6_o-copy.jpg
The last post was made 5 years, 284 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 138.27 Kb
