Painting your frame with a brush lol
buddy
PostPosted: 06:24 - 14 Jun 2020    Post subject: Painting your frame with a brush lol Reply with quote
Hey folks.
So im restoring my old xj600.
Now i cant really pull the engine out because the exhaust studs look pretty corroded so i am reluctant to touch them. So the engines staying in, and everythings getting painted round it in situe.
So... can i paint it with a brush lol?
Me immediete thoughts are, am i going to get loads of brush marks?
Will it be hard enough? Might just get chipped off rather quickly.
Im thinking of just using some hammerite or smething.
When this baby hits 88 miles per hour... you're gonna see some serious shit.
Pete.
PostPosted: 07:51 - 14 Jun 2020    Post subject: Reply with quote
You can paint with a brush lol but have some rag lol and thinners lol handy in case you get any on the engine.
Lol.
a.k.a 'Geri'
doggone
PostPosted: 08:07 - 14 Jun 2020    Post subject: Reply with quote
Modern paints seem to flow remarkably well so you might be surprised how well it works assuming you aren't a total novice brush painter.
jeffyjeff
PostPosted: 08:08 - 14 Jun 2020    Post subject: Reply with quote
Just as in painting with another application method, prep is the key. Your results, especially in the area of adhesion and chipping, are variable depending on the amount of effort you put into sanding, prepping, and priming. If the paint is mixed at the proper consistency, I doubt you will see the brush strokes. Good luck, and please post pix of your result.
PostPosted: 10:14 - 14 Jun 2020    Post subject: Reply with quote
People used to (and still do) brush paint paint bodywork to a high lusture.
Machine enamels are well suited to frame painting. As with all paint finishes, the end result is dependant on the time and effort devoted to prep, appropriately selected and thinned paint, the number and thickness of coats, the patience of the person painting and the quality of the brushes.
The latter is more important than most people allow for, you wont get a £500 finish with a 50p brush. You need a good quality one and you need to break it in.
EDIT: Also gloss red is the single worst paint finish it is possible to do in my experience. It's a total bastard. It uses a clear base with red pigment so it relies entirely on the pigment for colour density. It covers poorly and shows through any small defects from the preceeding coats. I'd recommend a tinted primer or you'll never get it to cover at all.
PostPosted: 10:22 - 14 Jun 2020    Post subject: Reply with quote
Cool, today I learnt that breaking in paint brushes is a thing.
"Brush the bristles back and forth against your hand to loosen them. Slap the brush on a hard surface and then spin it around by the handle to ensure that any loose bristles are freed. Dip the brush into your paint and then paint an X shape on some sheets of newspaper, going over it until all the paint on the brush is used. Examine the brush and cut off any misshaped bristles. The best quality natural bristle brushes may then be conditioned by soaking in linseed oil for a few hours. Remove excess oil with kitchen paper before use."
https://www.hamiltondecoratingtools.co.uk/knowledge-room/guides/professionals-secrets-for-preparing-and-using-paint-rollers-and-brushes/30
That's correct?
buddy
PostPosted: 10:48 - 14 Jun 2020    Post subject: Reply with quote
Paint brush it is then.
Just need to find the best quality paint so it dries nice and hard.
Is hammerite still any good? I hear a lot about "rustoleum" but that seems to be a yank thing....
PostPosted: 10:51 - 14 Jun 2020    Post subject: Reply with quote
I posted this some time ago, and recently came across the link again.
https://www.users.globalnet.co.uk/~pattle/nacc/arc0078.htm
pepperami
PostPosted: 11:05 - 14 Jun 2020    Post subject: Reply with quote
Mr Buddy.
I have been painting some stuff by hand just recently.
Because of lockdown, I’ve had had plenty of time to do the job at a nice slow pace.
I would also suggest that you get some small/artists brushes.
They will come in very handy for all those awkward little nooks & crannies that a bigger brush can’t get into.
PostPosted: 11:09 - 14 Jun 2020    Post subject: Reply with quote
Hammerite takes AGES to fully cure these days. Like weeks/months.
I lkike alkyd resin machine enamels for motorbike frames but other paints are available. Try looking for tractol (rougher, more robust) or tekaloid (fancier, more gloss).They use tractol for painting skips to give you an idea of how robust it is!
Here's an article on brush painting motorcycles.
https://www.da7c.co.uk/technical_torque_articles/brush_painting.htm
kramdra
PostPosted: 11:29 - 14 Jun 2020    Post subject: Reply with quote
Hammerite is rubbish, unless you want a hammer look. The old stuff was better but even that flaked off my lathe bench, which was prepared well, while a tin of poundland black does not. Also contains silicone, which is bad for reactions with acrylic paints. I would avoid alkyd/enamels too.
2k is the best paint, but cant be safely sprayed by DIYer. However many say it can be safely brushed, using an A2P3 respirator and well away from other people. Do your own research. Spraying 2k requires an air fed mask and a proper spray room.
Even so, Ive had very good results with 1k rattle cans. Mask the area, key with 600 grit, clean and spray. My forks have done a lot of miles and only have minor stone chips. Areas on the frame held up very well. I used poundland silver spray which I expected would be much worse.
Riejufixing
PostPosted: 12:22 - 14 Jun 2020    Post subject: Reply with quote
buddy wrote:
Paint brush it is then. Just need to find the best quality paint so it dries nice and hard. Is hammerite still any good? I hear a lot about "rustoleum" but that seems to be a yank thing....
Use a proper metal primer and a decent gloss over. I like Dulux Trade High Gloss, an alkyd resin, which flows really well and is tough, excellent stuff. I wouldn't use Hammerite smooth or hammered, although that's OK on small hard bits that don't flex.
PostPosted: 12:54 - 14 Jun 2020    Post subject: Reply with quote
Mask it very carefully and blast it with spray cans
By far the simplest.
Best done indoors to reduce dust and beasties sticking to the unhardened paint.
Build up thin coats of primer. Allow to dry tacky between coats.
When hard (next day), rub that down with flour grade wet or dry.
Then wash off with water. Rinse with distilled/RO/deionised water to avoid any chalky deposits as the water dries.
Build up thin coats of colour.
Allow to harden and rub down.
Finish with a couple of clear lacquer coats.
It will take about a week to fully harden unless you have a way to heat the shop and speed up evaporation.
Then a coat of polish.
PostPosted: 14:59 - 14 Jun 2020    Post subject: Reply with quote
I just painted the rocker cover and crank caps on teh FZ with smooth hammerite silver, by brush. My mistake may have been to use an old brush. I'm sure a newer finer bristled one would have done better. Any way it left annoying brush marks to I ended up getting a can of the spray stiff to go over the top.
BTW is hammerite good for anything these days? Used to be the 'go to' metal paint Confused
PostPosted: 18:41 - 14 Jun 2020    Post subject: Reply with quote
I think it's one of those "the original stuff was good, then they changed it." A combination of taking shortcuts to save money and new environmental regulations on harsh chemicals.
Robby
Dirty Old Man
PostPosted: 22:27 - 14 Jun 2020    Post subject: Reply with quote
If you want to do it right, get the engine out. The worst part of a frame for corrosion is down around the swingarm pivot and rear engine mount, on the inside. You won't be able to have a good look at it unless you have it stripped back to a bare frame.
If it's anything like some of the frames I have seen, that is when you learn metalwork and welding.
wr6133
PostPosted: 06:31 - 15 Jun 2020    Post subject: Reply with quote
You can get an ok finish without too much effort.
Below was hammerite applied with a (cheap) brush. Done with engine in frame. Was either 2 or 3 coats.
It looked decent from about 5' away. Up close didn't look bad but was clearly DIY painted. Buyer actually liked the black frame when I sold it, so couldn't have been that bad.
Only ever had to touch it up once after crashing. Finish was pretty tough (2014 Hammerite if that matters).
On reflection if I did it again I'd drop the motor. Had to take the plastics off and once that was done dropping the engine is a simple task.
https://live.staticflickr.com/65535/50007403123_7ee75b66a4_o.jpg
PostPosted: 07:01 - 15 Jun 2020    Post subject: Reply with quote
That chain is too slack and the frame looks twisted.
wr6133
PostPosted: 08:36 - 15 Jun 2020    Post subject: Reply with quote
Don't worry about that, key parts of the cooling system were held in place with Chemical Metal Laughing as I was selling, it seemed easier than actually fixing it.
kramdra
PostPosted: 11:13 - 15 Jun 2020    Post subject: Reply with quote
https://www.hse.gov.uk/pubns/guidance/mr4.pdf
Pdf details for safe brushing of 2k. Air fed mask not needed. I will probably get some and I will be using an A2P3 mask.
Hong Kong Phooey
PostPosted: 20:23 - 15 Jun 2020    Post subject: Reply with quote
Just a warning for anyone thinking of using 2k paint, exposure to the skin can lead to increased sensitivity when subsequently breathing in the vapours. Some people are more sensitive than others, and repeated exposure accumulates over time. This is an occupational hazard for car bodyshop workers but it's not unknown for home enthusiasts to be poisoned.
Also an organic particle mask may not be enough.
People who have been exposed to isocyanates sometimes don't show symptoms for years, and even when they do they don't necessarily make the link back to all those years ago when they took a seemingly small risk. This can manifest in more ways than just breathing issues.
https://multimedia.3m.com/mws/media/777847O/isocyanates-3m-techupdate.pdf
Once cured the risk is not completely diminished, welding or grinding 2k paint can aerate the particles once more.
PostPosted: 20:59 - 15 Jun 2020    Post subject: Reply with quote
You get a similar effect with epoxy resins. It's cumulative too. Some boat builders can't even sit in a canoe now, they'd have an anaphylactic reaction to it. I always tell people off if I see them handling epoxy without gloves. Especially because they invariably have to use acetone to get it off their skin which makes it even more readily absorbed and reacted to.
Robby
Dirty Old Man
PostPosted: 23:02 - 15 Jun 2020    Post subject: Reply with quote
stinkwheel wrote:
Some boat builders can't even sit in a canoe now, they'd have an anaphylactic reaction to it. .
Did you build this canoe?
Yes.
Will you sit in it?
Fuck no, I'll die.
Reassuring.
Tdibs
PostPosted: 23:46 - 15 Jun 2020    Post subject: Reply with quote
Honestly.... Its best to just deal with the header bolts come what may than keep putting them off. The stock divvy exhausts rot like crazy, a lot of the aftermarket headers then block the oil drain, so some you have to slack off headers for oil changes.
Re the paint. You can at least strip all but the engine, then mask it off pretty well with having the majority of the frame exposed. If you are going to that trouble, I would be use spray cans for sure, the frame is pretty exposed on the bike, it will always be noticeable.
Its worth the effort to go for power coat too tbh. I use black hammerite to touch up bits of the frame, but to do the whole thing in red.... its not going to be pretty.
buddy
PostPosted: 19:00 - 17 Jun 2020    Post subject: Reply with quote
I wasnt even aware you could get 2pk as a brush on.
When you say 2pk you mean a paint where you mix in a hardener right?
The last post was made 6 years, 148 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 133.72 Kb
