hellbound |
hellbound World Chat Champion
martin734 |
martin734 Spanner Monkey
hellbound |
Posted: 15:07 - 13 Jul 2020 Post subject: |
Is it getting a good spark?
Not the easiest bike to check this on I know but if this problem happened abruptly, it's hardly likely that all 4 carbs similtaneously and suddenly started malfunctioning.
90% of carburettion problems are electrical. I'd start with coil earths and move up from there. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
hellbound |
jaffa90 |
jaffa90 World Chat Champion
Campbell SOUP |
Campbell SOUP Two Stroke Sniffer
hellbound |
Hong Kong Phooey |
Posted: 10:21 - 16 Jul 2020 Post subject: |
If you spray brake cleaner or easy start in the intakes does it run?
I take it that it was running after all the bits were replaced as the bike needs to be running in order to balance the carbs.
Genuine fuel pump? Cheap crap off Ebay is cheap crap, works for a while then fails, confirmed by me, had to fork out for genuine.
When the tank was put back, it's easy to pinch the fuel supply hose. A little bit can drip through but when a lot of air flows it'll stall due to lack of fuel.
The carb rubbers are thick and hard to seat, if they're not on properly then it'll run rough.
When the carbs were cleaned, did he set the idle mixture screws again? From memory they should be three turns out.
The choke linkage can stick, fuel filters can clog, fuel might be contaminated if it's been stood, drain screws on bottom of carbs, dribble some in a jar shouldn't be a separation of water/fuel, or dirty bits in it.
Fuel pump points can stick, a quick tap on the lid usually sorts that.
All things I can think of, as it does sound fuelly. ____________________
Robby |
Robby Dirty Old Man
hellbound |
Hong Kong Phooey |
The last post was made 3 years, 258 days ago. Instead of replying here, would creating a new thread be more useful? |
