Overheating Yamaha dt125r
jaffa90
PostPosted: 00:05 - 06 Aug 2020    Post subject: Reply with quote
Nobby the Bastard wrote:
jaffa90 wrote:
It could be the incorrect engine oil not suitable for wet clutches.
The only thing that I can thing of with oil fucking the clutch is it slipping due to additives.
What does the mightly mind of seedless90 think is making the clutch too grabby due to the oil?
Hey up Noddy, sounds like you have never heard of Viscous drag .
Next up is a fast idle / tickover.
jaffa90
PostPosted: 00:08 - 06 Aug 2020    Post subject: Reply with quote
Rjgk2012 wrote:
I just replaced the oil yesterday with Castrol 10w30, suitable for wet clutches, but the problem persists. After a bit of reading I'm thinking there's grooves in the clutch basket.
Could be but a too fast idle/tick over speed can make the bike jolt forwards.
Noddy is the man to ask about this?
Riejufixing
PostPosted: 00:19 - 06 Aug 2020    Post subject: Reply with quote
Well, get at it, and have a look. Have a gasket ready for the clutch cover (or something to make one out of). Keep the clutch plates the same way around and in the same order if you take them off so you can put them back as they were.
PostPosted: 00:28 - 06 Aug 2020    Post subject: Reply with quote
Viscous drag? With 10/30? In the middle of summer?
That shit is good for.an ambient temp of 30 degrees c
jaffa90
PostPosted: 00:42 - 06 Aug 2020    Post subject: Reply with quote
""""Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
iooi
PostPosted: 12:18 - 06 Aug 2020    Post subject: Reply with quote
Just changing the oil will not get rid of the problem.
Plates will be soaked/coated with the old oil. If that was the issue.
Rjgk2012
PostPosted: 12:40 - 06 Aug 2020    Post subject: Reply with quote
What would you recommend doing then? Will the plates soak up the new oil with a bit of time?
Rjgk2012
PostPosted: 12:41 - 06 Aug 2020    Post subject: Reply with quote
I've ordered a gasket and I'll have a look once it arrives, thanks for the help.
Rjgk2012
PostPosted: 12:45 - 06 Aug 2020    Post subject: Reply with quote
The idle speed is 1400 rpm, surely that's not too high?
Riejufixing
PostPosted: 12:52 - 06 Aug 2020    Post subject: Reply with quote
If it's "the wrong oil", I'd expect your clutch to slip, not drag.
Anyway, as you're going to be having a look, you will see what's what then. Photos when you do? Smile
Rjgk2012
PostPosted: 13:03 - 06 Aug 2020    Post subject: Reply with quote
Yeah I'll post some photos, I'm sure you'll be able to point out things I didn't notice.
PostPosted: 13:10 - 06 Aug 2020    Post subject: Reply with quote
I wonder if you will get abuse for saying that as well.
redeem ouzzer
PostPosted: 14:19 - 06 Aug 2020    Post subject: Reply with quote
Anyone not using ATF in a two stroke gearbox should be killed.
Be a REAL MAN!
Rjgk2012
PostPosted: 14:53 - 06 Aug 2020    Post subject: Reply with quote
Note taken.
The last post was made 3 years, 262 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.9 - MySQL Queries: 17 - Page Size: 85.52 Kb
