Oil on tyres.... |
Fuck no!!! Get it off ASAP!!! |
50% |
[ 17 ] |
Meh a little will not matter |
41% |
[ 14 ] |
It MAkEs My TYres SticKY LOLZ |
8% |
[ 3 ] |
Total Votes : 34 |
kramdra |
kramdra World Chat Champion
MarJay |
MarJay But it's British!
Posted: 14:46 - 06 Aug 2020 Post subject: |
kramdra wrote: | We will see then. As I have been oiling my chain in this way since 2012, it must be about time some oil thows me down the road
Marjay, the childish use of caps does not change the fact you are wrong. Strong solvents, used repeatedley can damage the structure of a tyre, can cause invisible damage and could fail. Oil may reduce grip, but not with the amounts possible from chain fling. |
I'm not wrong. How can the brake cleaner attack the structure of the tyre when it barely touches the very top surface of the rubber before it evaporates away? A solvent that is not as volatile can indeed attack the rubber, but I'm not dipping the tyre in toluene.
Ironically it's possible that the oils that get on the tyre contain much less volatile solvents from the propellant in spray chain lube, to the friction modifiers and detergents that sit in engine oil.
Also, it's been established that you're quite happy for a tyre to effectively sit in a bath of oil and still ride on it, people have previously quoted you as such, so don't try to move the goalposts now. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
MarJay |
Posted: 14:50 - 06 Aug 2020 Post subject: |
kramdra wrote: |
It is not a constant 2" stripe around the tyre. As I said it gets worn off almost instantly. Only the chicken strip and sidewall has a visible stripe which is a thin layer of dirt, oil and soft rubber where a tiny amount is absorbed. To the touch it has grip, it is not a slimey goo. |
Does it get worn off though? Engine oil and chain lube is designed to cling to surfaces, and with the microscopic texture of the rubber being such that there are plenty of places for the oil to hide until the higher spots are worn off, it's entirely logical that oil could hang around for a long time, particularly if it were to get into a tread groove. You could well have a thin line of oil sitting on the side of a tread block that has no effect until the block is worn, and then you get oil permeating the surface of the tyre. This would NOT Happen with brake cleaner, as brake cleaner would boil off in 60 seconds or so.
The way to be sure you don't have any oil on your tyre is either clean it off with a more volatile more potent solvent, or don't get oil on your tyre in the first place.
Sometimes people get backed into a corner during a 'discussion' like this, and I feel like you're there. Can I just remind you that your position is effectively that the act of cleaning oil off of a tyre with brake cleaner is worse than leaving oil on the tyre. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
kramdra |
MarJay |
kramdra |
Posted: 19:20 - 06 Aug 2020 Post subject: |
And yet, brake cleaner is a hydrocarbon product
Carb cleaner and brake cleaner are very similar, depending on brand and mix. They evaporate at a similar rate. If you are cleaning jets you need to put them in a sealed pot to soak to be effective. Both are likely to contain acetone and xylene, neither of which do I want on my tyres.
Also worth noting this on the wikipedia page for brake cleaner.
"Rubber and some types of plastics are decomposed by brake cleaners by removing binding components. This has the consequence that the rubber will appear unchanged at first; however, it will become brittle, and after a few weeks to months cracks and fractures appear. "
I have not changed my stance. I do not deliberately bathe my tyres in oil, but if I find oil has been spilt I would have no problem riding the bike until they are clean. I have suggested how somone could safely remove the oil, if they were fussy about it.
Fork oil or other oils will be wiped off with a dry cloth. |
Kawasaki Jimbo |
kramdra |
MarJay |
MarJay |
Posted: 21:29 - 06 Aug 2020 Post subject: |
kramdra wrote: | And yet, brake cleaner is a hydrocarbon product |
In the same way that petrol is not the same as diesel, is not the same as paraffin, is not the same as chain lube is not the same as crude is not the same as engine oil...
Need I go on? I aim (aim, just to reiterate) to not get ANY hydrocarbon product on my tyres which does include brake cleaner. However, knowing what I know about the properties of brake cleaner, that is definitely my preferred option due to it's volatility. It would not have time to penetrate the rubber, and if it did have some sort of hardening effect (unlikely in the 60 seconds it takes to evaporate) it would only affect less than a micron thickness of rubber which could probably be wiped off with a cloth.
You have to compare like with like, and Brake cleaner is NOTHING like engine oil, despite them both being made from carbon and hydrogen atoms. Take Ethanol, it's structurally very different from Methanol. Drink one (diluted, I'm annoyed that I feel I have to say that) and you'll get drunk. Drink the other even diluted and you could go blind. I don't see why I'm having to explain this.
Just to let you know, I studied organic chemistry at University, so I do happen to know a little bit about hydrocarbons. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
kramdra |
This post is not being displayed because it has a low rating (Flame). Unhide this post / all posts.
notbike |
notbike Formerly known as notabikeranymore
Posted: 22:27 - 06 Aug 2020 Post subject: |
Nobby the Bastard |
MarJay |
Posted: 22:33 - 06 Aug 2020 Post subject: |
kramdra wrote: | Yet using brake cleaner on tyres is unnessasary, and known to cause damage to rubber, you still use it. Your reasoning that it evaporates before it does any damage is very flawed, and worth noting that vapour will also do damage, it does not need to be liquid, and yes those vapours will stay in the porus structure if the rubber surface. That is far worse than a bit of oil.
You mention microns but clearly you do not know how small they are. The porus surface of a tyre likely has a roughness of 100 microns deep or more, all of which that is in contact with it will be affected. Some will be absorbed quite a bit deeper and I would suggest upto 2000 microns with 60 seconds of contact. That is 2mm, if you were confused.
I was not asked for evidence, I was asked my opinion of why I consider engine oil ok and the other is not, for which my experience that forms my opinion is perfectly valid to reply.
You are a failure. |
You've just written that to sound like you know what you're talking about. It's pretty much all nonsense.
If the rubber of a tyre is porous, then oil can be absorbed by it. Whereas a hydrocarbon as volatile as brake cleaner would still reach it's vapour point if inside the porous structure of the tyre and then escape the way it got in. Oil doesn't vaporise at the temperatures reached inside a tyre, so it just stays there.
This isn't complex chemistry or anything, the brake cleaner is designed to be as unreactive and as volatile as possible and still provide a cleaning action. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
kramdra |
notbike |
Posted: 23:22 - 06 Aug 2020 Post subject: |
MarJay |
Pigeon |
Pigeon World Chat Champion
Robby |
Robby Dirty Old Man
Nobby the Bastard |
Fisty |
Fisty Super Spammer
mentalboy |
mentalboy World Chat Champion
kolu |
kolu Nova Slayer
Kawasaki Jimbo |
Posted: 20:04 - 09 Aug 2020 Post subject: |
kolu wrote: | I'm honestly confused by all this. I almost always end up with a bits of oil on my rear tyre after I clean with paraffin, wipe/spin (on paddock stand, all the way to 6th gear and 10k rpm, must be about 120mph equivalent or whatever - yes, I know it's not safe) |
OMG why would you do that, you (probably) 3-fingered loon. I feel faint. Spin it by hand while holding a rag around the lower rung.
kolu wrote: | and then with 80w-90 (toothbrush, just gentle layer against rust, nothing more) and wipe excess again. It's like tiny streaks, should I get it off the tyre every time? |
I think you need to read smartaland's 'How do I get chain lube on my tires every. Single. Time?' thread.
"Bits of oil" are probably inevitable but you've missed kramdra's posts (there and earlier) where he literally drenches the chain and then rides regardless, "safe" in the knowledge that the great excess of oil knowingly flung onto the tyre is worn off once he hits the road, and forgetting that once he's on the road it's too late. Having denied there's any effect he then rates tyres on their resistance to oil slippage, bizarrely. |
kolu |
kolu Nova Slayer
The last post was made 3 years, 259 days ago. Instead of replying here, would creating a new thread be more useful? |
