Shim measuring question.
droog
PostPosted: 19:17 - 03 Aug 2020    Post subject: Shim measuring question. Reply with quote
Hello Smile
I'm just wondering how you guys record your shim measurements assuming you are using a digital micrometer that measures to the third decimal place (thousandths).
Do you bother factoring in the third decimal place into your final measurement or do you just go with whatever the first three figures are?
For example -
A shim that measures from between 1.971mm to 1.975mm on the micrometer would be rounded down and recorded as a 1.97mm shim.
A shim that measures from between 1.976mm to 1.979mm on the micrometer would be rounded up and recorded as a 1.98mm shim.
Or would you just ignore the third decimal and record this as a 1.97mm shim?
Cheers for any advice.
PostPosted: 19:23 - 03 Aug 2020    Post subject: Reply with quote
Shims are thicker than 2mm.. I bet the three numbers you are looking at are just the numbers behind the decimal point and so are in thousandths.
Triumph Sprint ST 1050
Campbell SOUP
PostPosted: 19:57 - 03 Aug 2020    Post subject: Reply with quote
The shims for my F4i turned out to be thinner than 2mm so it is possible!
In relation to the OP's question, it depends really how accurate you want to be. My bike has a valve clearance tolerance band of ±0.03mm, so I could aim for the nominal value using my 0.01mm micrometer and be confident it would be within the tolerance band.
Some shims would read at 1.97mm, but knowing that shims were available in 0.025mm steps I recorded them as 1.975mm shims. Being a bucket-over-shim arrangement it was quite unlikely there would be any wear and could just go off the laser-etched markings, but it never hurts to be sure!
droog
PostPosted: 20:21 - 03 Aug 2020    Post subject: Reply with quote
Thanks for the replies! Very Happy
Hi Campbell - yep - my bike is an F4i too so we are both working at 2mm and under. Very Happy
Yep - this is what I was thinking - I'm aiming to get the valve tolerance in the mid-range so hopefully there will be enough wiggle room on on either side of the plus/minus figure if the shim is slightly over/under the optimum thickness.
In which case It should be ok to rely on the first three figures (e.g. 1.97 in the case of my example) and not worry about the thousandths of a mm. Smile
Campbell SOUP
PostPosted: 20:40 - 03 Aug 2020    Post subject: Reply with quote
Yep, should be fine then!
To be really safe, once you've made your adjustments you can get your feeler gauge back out, and make sure that the minimum tolerance (backed up with micrometer measurement of the gauge) fits between camshaft and bucket, while the top tolerance doesn't. You won't know the exact measurement, but you'll know for sure you're within tolerance, and that's all that matters Smile Thumbs Up
droog
PostPosted: 20:47 - 03 Aug 2020    Post subject: Reply with quote
Cheers! - I'll definitely use that technique - Thanks for the advice Campbell! Smile
Campbell SOUP
PostPosted: 20:57 - 03 Aug 2020    Post subject: Reply with quote
Happy to help! Just been through the process myself, which took 3 weeks in the end after I a) put the camshafts back on incorrectly (misunderstanding the TDC mark on the crank) and b) ordered the wrong shims (bought bigger shims to loosen clearances... Rolling Eyes )
Many lessons have now been learned!
PostPosted: 21:12 - 03 Aug 2020    Post subject: Reply with quote
Some of us are used to having intake shims needing a gap of 0.015mm.....
droog
PostPosted: 08:19 - 04 Aug 2020    Post subject: Reply with quote
Yep - tolerance between 0.10mm and 0.15mm intake on a crosser like the KTM 450 Smile
droog
PostPosted: 08:30 - 04 Aug 2020    Post subject: Reply with quote
Yeah - easily done - this is my first go at this and I can see how that kiind of stuff can happen - I'm checking stuff at least two or three times over to make sure I haven't missed anything Very Happy
steve the grease
PostPosted: 10:30 - 04 Aug 2020    Post subject: Reply with quote
Generally in engineering metric measurements are given in Hundredths 1.11mm etc. In English/ the imperial system measurements are given in thousandths so 1.111"
There are 40 (39.37 actually) thousandths of an inch in a mm so a tenth of a mm is 4 thou (0.004") and a hundredth of a mm is 0.4 thou or less than half a thou. To measure to thousandths in metric is to go beyond the level of accuracy needed by most engineering applications and that humans achieve in a workshop, rather than laboratory, and therefore pointless.
droog
PostPosted: 10:39 - 04 Aug 2020    Post subject: Reply with quote
Cheers Steve - yeah - going to that level of tolerance is overkill in this scenario - I'm on a learning curve here - so getting the benefit of your knowledge and experience is much appreciated - thanks! Very Happy
PostPosted: 17:49 - 04 Aug 2020    Post subject: Reply with quote
If there is a +- tollerance is to allow for inaccuracies in the tools used. And to allow for wear between services and adjustment intervals.
Set to specification. (Not to the tolerances.)
droog
PostPosted: 20:03 - 04 Aug 2020    Post subject: Reply with quote
Thanks for the advice MCN Smile - I'm using the standard valve shim conversion formula to calculate the required shim size for those valves which are either out of spec or right on the limit - I'm attempting to get all the valves set at (or close to) the middle of the factory spec:
Intake plus/minus 0.17mm - 0.23mm : mid-spec is 0.20mm
Exhaust plus/minus 0.25mm - 0.31mm : mid spec is 0.28mm
droog
PostPosted: 20:04 - 06 Aug 2020    Post subject: Reply with quote
Hi Very Happy
Just wondering if anyone has a view on the following:
I've got a couple of tight out of spec exhaust valve clearances which requires a shim sized at 1.83mm if I want to achieve my ideal mid-spec valve clearance measurement of 0.28mm
(Exhaust clearance factory spec: 0.25mm – 0.31mm)
As mentioned above - shims are sized in increments of 0.05mm and in the absence of a 1.83mm shim these are my options:
Fit a 1.85mm shim and get a tighter clearance than I was hoping for but which is in spec. I calculate that the 1.85mm shim will result in a clearance of 0.26mm
Fit a 1.80mm shim, and get a looser clearance than I was hoping for that is on the absolute upper limit of spec. I calculate that the 1.80mm shim will result in a clearance of 0.31mm
Just wondering if I should go on the looser or tighter side on this.
Thanks for any replies. Very Happy
PostPosted: 20:21 - 06 Aug 2020    Post subject: Reply with quote
As they tighten over time go looser.
steve the grease
PostPosted: 20:30 - 06 Aug 2020    Post subject: Reply with quote
Yeah go looser, it's only a fraction. Tight clearances burn valve seats.
droog
PostPosted: 13:35 - 07 Aug 2020    Post subject: Reply with quote
Thanks for the replies Very Happy - yes - looser sounds the way to go - cheers Very Happy
Pete.
PostPosted: 15:49 - 07 Aug 2020    Post subject: Reply with quote
How do you measure that?
a.k.a 'Geri'
PostPosted: 18:34 - 07 Aug 2020    Post subject: Reply with quote
Yes I fucked up. Its .15. I've been waiting for someone to notice.
PostPosted: 19:16 - 07 Aug 2020    Post subject: Reply with quote
I noticed but was too afraid to call it out. 🤣
There is a gap of 4 years, 135 days between these two posts...
dunwichguy This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
PostPosted: 15:57 - 20 Dec 2024    Post subject: Reply with quote
Do you know anything about football or brainstorming.
The last post was made 1 year, 36 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 119.03 Kb
