Does a windscreen reduce wind noise significantly?
CorriganJ
PostPosted: 19:51 - 04 Aug 2020    Post subject: Does a windscreen reduce wind noise significantly? Reply with quote
On Sunday I rode 550km on a naked 125. During the whole trip I was battling with two things - low top speed, and wind noise. I'm not sure I want to do it again on a 125. I might be able to do my full test soon. If I could get on a bigger bike that would solve the speed problem, but make the wind problem even worse. Does a (functional) windscreen reduce wind noise enough to the point where I could spend 8 hours in the saddle and actually enjoy most of it? Thanks
martin734
PostPosted: 19:58 - 04 Aug 2020    Post subject: Reply with quote
It depends on the shape of the windscreen, the size of the windscreen and the position of the windscreen. A windscreen will create a bubble of calm air behind it, the size, shape and position of that bubble depends on the size, shape and position of the screen. The screen will also create turbulence that may increase wind noise, again, the amount and type of turbulence will depend on the size, shape and position of the screen. My advice is to buy a set of ear plugs. The soft foam ones that cost pennies work very well.
Current bike: ST1100 "Big Red"
PostPosted: 20:08 - 04 Aug 2020    Post subject: Reply with quote
If it's designed for the bike it's usually an improvement however some aftermarket screens can alter the air flow making noise and wind buffeting worse by deflecting it straight at your head.
If you get one, make sure it is adjustable and you might have to play around with it to get the optimal position.
I woud also go for a name brand. They will at least make sure it fits you bike properly.
Triumph Trophy Launch Edition
arry
PostPosted: 20:27 - 04 Aug 2020    Post subject: Re: Does a windscreen reduce wind noise significantly? Reply with quote
Are you wearing ear plugs? If you're not - then do.
Riejufixing
PostPosted: 21:21 - 04 Aug 2020    Post subject: Re: Does a windscreen reduce wind noise significantly? Reply with quote
CorriganJ wrote:
On Sunday I rode 550km on a naked 125 .... Does a (functional) windscreen reduce wind noise enough to the point where I could spend 8 hours in the saddle and actually enjoy most of it? Thanks
42+mph. Hm. Stops? Anyway, yes, as others say if you're getting wind noise, earplugs. I prefer the "mushroom" sort like these: 3M™ E-A-R™ UltraFit™ Earplugs like ar https://www.protecdirect.co.uk/Personal-Protective-Equipment-PPE-/Hearing-Protection/Corded-Banded-Earplugs/3M-E-A-R-Ultrafit-Earplugs~p~670406?utm_source=Protec&utm_medium=Froogle&utm_campaign=Shopping&gclid=EAIaIQobChMImbj5xq-C6wIVh-7tCh2OPAoJEAQYASABEgK0WvD_BwE
You don't have to use the cord (it is separate in the box they come in); you can snip the "stalks" shorter if you like. I find them much easier to use/clean than foam ones.
PostPosted: 21:30 - 04 Aug 2020    Post subject: Reply with quote
Another vote for earplugs, very nice on my last long trip Thumbs Up
IMHO windscreens are useful to stop your helmet being buffeted which can get pretty tiring.
mentalboy
PostPosted: 00:18 - 05 Aug 2020    Post subject: Reply with quote
Anything above 80 and a screen will massively reduce the strain on your arms and neck. At an indicated ton-fifty you only have to move your hand out of the shielded area to appreciate the protection afforded, not that I can recommend even straight-lining at those speeds with one hand only on the bars.
Earplugs and the best good fitting helmet you can afford. Thumbs Up
Make mine a Corona.
martin734
PostPosted: 00:22 - 05 Aug 2020    Post subject: Reply with quote
As he rides a 125, I very much doubt he will be doing 80 mph, let alone 150.
mentalboy
PostPosted: 00:25 - 05 Aug 2020    Post subject: Reply with quote
You didn't see the words 'If I could get on a bigger bike' in the OP's opening post?
Edit: And that isn't to say that a screen isn't beneficial below 80.
Make mine a Corona.
PostPosted: 08:37 - 05 Aug 2020    Post subject: Reply with quote
My 1500 Goldwing had the best fairing/screen ever. You could smoke a fag at motorway speeds. Cool
Wit an open face helmet obviously!
dynax
PostPosted: 08:41 - 05 Aug 2020    Post subject: Reply with quote
When i got my Xena i used to get buffetted quite a lot at 50+mph, but since getting the screen the buffetting has stopped altogether but i still get wind noise, but most of the time i am wearing earphones for the sat nav which cuts out most of it Thumbs Up
Mike.
Bikes: Xena, Bridget,Florence
https://www.youtube.com/channel/UCmihUc0xXxYbR4_0l-F1FzA/videos?view_as=subscriber
trevor saxe-coburg-gotha
PostPosted: 09:31 - 05 Aug 2020    Post subject: Re: Does a windscreen reduce wind noise significantly? Reply with quote
this - so fucking this
fuck screens; they'll do nothing compared to earplugs
these are the earplugs you want (they are silicon, soft and comfy to wear for hours - try trimming the long ends of if you like, that's not a problem; moisten them with goodly amount of olive oil, and maybe even do the same with your finger, to your ear, so that both the earplug and your inner ear are oily; the plug will make a seal easily, and cut out A LOT OF NOISE - as in, most of it):
https://www.amazon.co.uk/Silicone-Earplugs-Flexible-Swimming-Comfortable/dp/B07P1SPN8M/ref=sr_1_53?dchild=1&keywords=earplugs&link_code=qs&qid=1596616087&sourceid=Mozilla-search&sr=8-53&tag=firefox-uk-21
doggone
PostPosted: 10:22 - 05 Aug 2020    Post subject: Reply with quote
Years ago I put a taller screen on an XJ900 it was a complete abomination, causing far more wind to be directed at your head and a lot of buffeting too.
The original smaller one went back on and your head still got steady blast but less hit your body.
So a small screen can help more than you think and it can complement the style of a naked bike.
You tend to just get used to it though.
Later I had a naked Bandit 1200 and never even considered a screen despite doing a lot of high speed touring on it.
arry
PostPosted: 10:50 - 05 Aug 2020    Post subject: Re: Does a windscreen reduce wind noise significantly? Reply with quote
It's no shock to me that most of the elderly bikers I know are deaf as a post whereas the elderly gents I know in work all hear fine.
I wish to feck that someone would have given me the advice to wear them earlier in my biking life. I have mild onset of tinnitus and I don't want it - at all - ever.
I had custom plugs made after about 2 years of riding and they were great. However, over time, my ears have obviously changed shape as their effect reduced drastically. It was only after I put ear-bud earphones in relatively recently for sat nav sake that I realised they were quieter than the moulded ones by a fair old way.
So I bought these on sale:
https://www.flareaudio.com/collections/earplugs-1/products/isolate-pro-titanium
They're the absolute business. In fact if anything they're probably a little TOO quiet. Comfortable, quiet as hell, cheap and relatively easy to put in (not as easy as moulded plugs mind).
Pigeon went and bought some on my recommendation and says same. I've also recommended them to another biker mate of mine with SERIOUS tinnitus problems from years of abuse and he's over the moon, too.
Just do it, and don't look back.
PostPosted: 11:49 - 05 Aug 2020    Post subject: Re: Does a windscreen reduce wind noise significantly? Reply with quote
I like that style but with a bit of string so you don't lose one. Bit like mittens for special ppl Laughing
Zen Dog
PostPosted: 11:52 - 05 Aug 2020    Post subject: Reply with quote
Just to reiterate the ear plugs thing, in addition to the reduced wind noise and saving your hearing, I also find wearing ear plugs makes me a lot less tired when riding long distances. Not sure why but it really makes a big difference for me.
CorriganJ
PostPosted: 12:35 - 05 Aug 2020    Post subject: Reply with quote
Already got earplugs - they make a huge difference so that is great. But it was a long day riding, probably 8 hours actually riding + more of resting, and by the end even with earplugs I was just fed up of the wind in my face. Especially because spanish highways are often raised up and get a lot of crosswind too.
martin734
PostPosted: 13:21 - 05 Aug 2020    Post subject: Reply with quote
I have the perfect solution for you, it is called a car. Rolling Eyes
Zen Dog
PostPosted: 14:39 - 05 Aug 2020    Post subject: Reply with quote
Ok, so to answer your specific question. Yes, a screen/fairing CAN significantly reduce wind noise, and many do. As a general rule, the bigger the better. But there are no guarantees, I've seen factory fitted screens cause terrible buffeting sometimes.
The other option which hasn't been mentioned, is fitting a whisper kit to your lid. It's basically just some little bits and pieces that seal the helmet better when it's on your head. I had one for my old Shoei helmet and it made a surprisingly big difference. Whether you can get one for your lid I don't know obviously, but it wasn't too expensive so probably worth a look.
weasley
PostPosted: 15:09 - 05 Aug 2020    Post subject: Reply with quote
Or there are those little deflectors that sit atop a smaller screen that get some good reviews.
https://pierce-images.imgix.net/images/4/3/5/3/43534e8e66c3e40b7168f50a6562aa148b47af09_6873H_1.jpg?h=629&auto=format&q=50&fit=crop&w=629
c_dug
PostPosted: 16:26 - 05 Aug 2020    Post subject: Reply with quote
I recently spent a bit of time riding a K1300GT with an electric adjustable screen. It was interesting moving it up and down whilst sat at motorway speeds.
The "perfect" height changes for every given speed so all of the below would be different at 90 compared to 70 or 50.
Too high a screen and you get a pocket of low pressure air which seems to suck your whole body towards the screen. Very quiet but not very comfortable, feels like a weight on your arms.
A bit lower and you get buffeted as the "dirty" wind coming off the top of the screen whips over the top of the helmet. Very noisy, very uncomfortable.
A bit lower again and for me this was perfect, a little bit of wind noise and some wind hitting at ~armpit sort of height. Enough to take the pressure off your arms but still mostly sheltered from the wind.
Any lower and you'd get more wind hitting your body, not necessarily much more noise, but less weather protection.
PostPosted: 17:29 - 05 Aug 2020    Post subject: Re: Does a windscreen reduce wind noise significantly? Reply with quote
yeah i have seen em with string - wouldn't work so well for me cos i keep em in a 35mm film pot thingy (remember 'em?), with a bit of olive oil in it (the string would go wet w/ oil)
bikerlady20 This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
arry
PostPosted: 11:34 - 14 Aug 2020    Post subject: Re: Does a windscreen reduce wind noise significantly? Reply with quote
bikerlady20 wrote:
Very interesting to know! As I am rather a newby when it comes to bike riding, this is very helpful and I'll definitely get my hands on some earplugs!!
These are what I've bought recently and I can really recommend - in fact I have recommended to two biker friends and both of them have been impressed with the results, too:
T1Cybernetic
PostPosted: 11:49 - 14 Aug 2020    Post subject: Reply with quote
I've had a few screens and on bikes over time and non have done a great job for me Sad
At 6'3 I've always got my head over the screen and directly inside the rushing air flow Very Happy
If i tuck down right behind the screen they work great but that position is not going to work for me!
Ear plugs are great for cutting down on noise though Thumbs Up They work all the time.
Signature removed by popular demand...
The last post was made 5 years, 308 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 2.44 - MySQL Queries: 13 - Page Size: 141.65 Kb
