Princessdarks... |
Princessdarks... L Plate Warrior
P. |
P. Red Rocket
Posted: 17:17 - 07 Aug 2020 Post subject: |
Fisty |
Fisty Super Spammer
P. |
P. Red Rocket
pepperami |
pepperami Super Spammer
Nobby the Bastard |
steve the grease |
jeffyjeff |
jeffyjeff World Chat Champion
Nobby the Bastard |
jeffyjeff |
steve the grease |
Nobby the Bastard |
Fisty |
Fisty Super Spammer
Fizzer Thou |
Posted: 22:02 - 09 Aug 2020 Post subject: |
Luckily,like the CB125S,the crankshaft is the roller bearing type and so does not need super clean oil like a plain bearing type crankshaft.The centrifugal device gets rid of the fine debris,as shown in the fiche
https://www.cmsnl.com/honda-cd125t-general-export-kph_model50479/partslist/0050.html#.XzBi87B7nIU
The part numbers are the same as for the UK so any Honda dealer would be able to source parts.Good idea to replace the cover gasket as well and to not use instant gasket
Many parts are interchangeable with the CD185 and the CD200T.I bought a wreck of a CD200T and rebuilt it with many new parts,but only as a project.Even after 38,000 miles there was only a small amount of solidified crud that had built up in the centrifugal oil device. ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
Princessdarks... |
Fisty |
Fisty Super Spammer
Princessdarks... |
Posted: 23:18 - 09 Aug 2020 Post subject: |
The rubber bit round the edge of the gauze screen has probably started coming apart, had it happen on a CB125T2.
David silver spares are my usual first go-to place for classic honda parts. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Fizzer Thou |
Posted: 12:22 - 10 Aug 2020 Post subject: |
I looked on the Dave Silver website and,although the CD125T is mentioned,as are the CD185T and the CD200T,those components are not showing.They are still available from stock at Fowlers of Bristol under the model of the CD250U,which just shows how many parts are interchangeable between models
https://www.fowlersparts.co.uk/parts/4859210/cd250uk-1989-e/oil-pump?noredir=1 ____________________ Just talk bikes.What else is there?
steve the grease |
Posted: 23:47 - 10 Aug 2020 Post subject: |
Fisty wrote: | steve the grease wrote: | The gauze cant really be considered a filter as such... is there to stop rocks , lumps of crap ( and anything else that has got in the engine via the dipstick hole) and balls of blue hylomar getting dragged into the oil pump and wrecking it. On cars the similar gauze is called a strainer.... |
A strainer is a type of filter. |
Well yes , but it is a very crude filter, filtering out stuff down to about a quarter of a millimeter, which is why I refered lightheartedly to 'rocks, lumps of crap' etc. If you have got crap .25mm circulating round your lubrication system, then you have got problems ( sand might be an example) - which is why I said the gauze isn't really a filter, on it's own it is not anywhere near enough to protect the lubrication system.
A paper filter might filter down to 10 microns which is 25 times smaller than .25mm. Bikes that don't have a paper filter , need some other mechanism for filtering out fine particles, much smaller than can get through the gauze, and a centfrifugal filer is often used , as indeed is the case with the bike being talked about here. ____________________ All the above is my personal opinion, you can see my lips move, but I'm talking out of my arse.
I've been riding, and fixing , bikes for 50 years, in that time the more I learn, the less I am absolutely sure of..... |
jeffyjeff |
steve the grease |
Posted: 21:57 - 11 Aug 2020 Post subject: |
jeffyjeff wrote: | steve the grease wrote: | Bikes that don't have a paper filter , need some other mechanism for filtering out fine particles, much smaller than can get through the gauze, and a centfrifugal filer is often used , as indeed is the case with the bike being talked about here. |
What about a YBR? Those poor little engines have a filter screen and nothing else! .25mm is probably the best filtering you are going to get, unless the screen begins to load up and the filtered debris take on the role of filtering media; but then flow and oil pressure drops off, and that's even worse. How do you counter that...frequent oil changes. Way more frequently than the factory 3,750 mile recommendation. That may be an inadequate countermeasure, but you do what you can. |
What about Rotary filter, part number 5VLE345100 as fitted to the YBR check out CSMNL, it does sound rather like a centrifugal filter. ____________________ All the above is my personal opinion, you can see my lips move, but I'm talking out of my arse.
jeffyjeff |
The last post was made 3 years, 258 days ago. Instead of replying here, would creating a new thread be more useful? |
