Hetzer |
Hetzer Super Spammer
kramdra |
kramdra World Chat Champion
Hetzer |
gbrand42 |
gbrand42 Could Be A Chat Bot
Posted: 10:02 - 08 Aug 2020 Post subject: |
While its in warranty I would imagine it should be done as per the official schedule. After that I see no reason not to stretch the interval between checks. One of my old bikes should have been done every 16,000 miles which I stretched to 30,000 miles and even then the adjustment required was minimal, and I can't think it would have done any harm if I had just left it. ____________________ Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European |
Hetzer |
spottedtango |
spottedtango Trackday Trickster
MarJay |
MarJay But it's British!
doggone |
doggone World Chat Champion
MarJay |
Kawasaki Jimbo |
Posted: 11:34 - 08 Aug 2020 Post subject: |
I know a very respectable independent bike shop who won't do valve checks unless there are reasons to think they are out. I'm not sure how they regard the first scheduled check though. I was pleased at first but having read a little bit on the matter I wonder if major damage is done by the time symptoms are felt. In fact I was thinking of doing the check myself because I have two weeks off (it would take me that long ). The bike did have a first valve check but that was at least 35k ago. Bucket and shim.
Aren't bikes usually out of warranty by the time the valve check is scheduled? |
Easy-X |
Easy-X Super Spammer
Posted: 12:06 - 08 Aug 2020 Post subject: |
Worth checking? Certainly, IMHO. Okay, so you may have fairings and a tank to remove but it's not a fantastically hard job just boring. Now once you've checked whether it's worth the effort to swap out shims or get someone else to do the work is a separate conversation.
Not vital if the gaps are too big - just a slight loss of compression - but too tight = engine wear. For some bikes that could be the difference between a long life and immortality ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Bhud |
Bhud World Chat Champion
Easy-X |
Posted: 15:29 - 08 Aug 2020 Post subject: |
I think the point is that, beyond the initial service, the likelihood of massive deviation from spec of valve gaps and shims is almost so low to not worth worrying about. And the keyword is "almost"
Depends how you feel about conscientiousness. If you have to find all the secrets in Super Mario or Zelda checking valve gaps is right up there. If you have better things to do in life then more power to you... as long as those "better things" are tangible and not just procrastination ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Bhud |
Robby |
Robby Dirty Old Man
Posted: 16:27 - 08 Aug 2020 Post subject: |
Car don't need it because cars have had hydraulic lifters for decades. So have Harleys. Hydraulics lifters are self-adjusting. They work well in car engines and Harley engines, where the hydraulic tappet itself can be a fairly large part and move fairly slowly.
They work less well at high revs, and when you try to make them small enough to pack 16 or 20 of them on to a cylinder head.
Considering that few bikes do more than 40k miles over their lifetime, and a valve clearance check on anything with buckets and shims is done every 16k or so, it isn't a big enough problem to fix. 2 or 3 valve checks over the lifetime of the bike. More frequent on things with rocker arms, but also about a third of the workshop time to check and adjust them.
If the clearance is too tight, it means you don't have enough space between the camshaft, tappet assembly, and valve stem. The problems range from wiping the oil off the camshaft to holding a valve open all the time.
If the clearance is too big, it means you have too much space in there. Less of a problem for reliability, but it means the valve isn't opening fully so you don't get all of the fuel/air mix in that you could, or all of the exhaust out.
Whilst there are tendencies for shimmed bikes to close up over time and for rocker arm/locknut bikes to open up, this isn't a rule to live by. The valve clearance adjustments are accounting for wear in several places on several different materials.
Chances are, you'll be fine. It is unusual for valves to get so tight or loose that they cause a problem. It is one of those home-mechanic jobs where I feel that, overall, more damage gets caused by cocking up a valve check than would have been caused by just leaving it alone.
What bike? |
Hetzer |
Posted: 18:33 - 08 Aug 2020 Post subject: |
Thanks Rob, very informative.
2014 BMW S1000R ____________________ "There's the horizon! Ride hard, ride fast and cut down all who stand in your way!" |
Hetzer |
jeffyjeff |
jeffyjeff World Chat Champion
Pete. |
Pete. Super Spammer
jeffyjeff |
spottedtango |
Pete. |
Pete. Super Spammer
Posted: 22:51 - 08 Aug 2020 Post subject: |
In fairness, you wouldn't expect someone to be asking if it's wise to neglect demos valve clearances. ____________________ a.k.a 'Geri'
jeffyjeff |
Robby |
Robby Dirty Old Man
ThatDippyTwat |
The last post was made 3 years, 254 days ago. Instead of replying here, would creating a new thread be more useful? |
