Fizzer Thou |
Posted: 12:58 - 10 Aug 2020 Post subject: MoT Test Fail But No Paperwork Issued |
How many times have you had your bike MoT'd and a PASS certificate was issued?
And how many times have you had a bike FAIL and a failure certificate issued?
Ever since my very first bike MoT back in 1975 when I took my Honda CB125S to what was then 'Boyers of Bromley',that bike failed for the absence of a split pin for the rear brake torque arm.At that time,the old boy in a white coat issued me with the relevant fail document.I found an nail in the gutter,placed it through the hole in the bolt and represented it.The bike then had to be MoT'd again as back in those days there was not the same retest procedures as there are now.
Since then I have not had a bike of mine fail...ever.
Just the other day I wanted to tax (VED) one of my bikes for the first of August so I looked up the registration on the gov.uk website and was mortified that several of my bikes had been failed for minor reasons like drive chain 'excessively loose'.The fact that I have never had a bike fail for that reason made me look at the MoT history of several of my other bikes,only to find that the same had been done on them and then passed on the same day with the same mileage.
https://www.check-mot.service.gov.uk/
The only reason I can think of is that the MoT garage can be seen to fail a certain percentage of vehicles tested. ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
redeem ouzzer |
Riejufixing |
P. |
P. Red Rocket
Nobby the Bastard |
arry |
arry Super Spammer
Shaft |
Shaft World Chat Champion
Posted: 14:24 - 10 Aug 2020 Post subject: Re: MoT Test Fail But No Paperwork Issued |
Fizzer Thou wrote: | How many times have you had your bike MoT'd and a PASS certificate was issued?
The only reason I can think of is that the MoT garage can be seen to fail a certain percentage of vehicles tested. |
Contrary to popular belief, there is no failure target and anyone who tells you different is talking out of their hat - in fact, we are actively encouraged to pass anything we can, the phrase "if in doubt, advise and pass" comes up a lot.
The scenario you are talking about is known as PRS (Pass after Rectification at Station) where minor repairs can be carried out, then retested within in an hour of the end of the initial test.
This could apply to things like chain tension, headlamp aim adjustment, failed bulbs, or anything that's a relatively quick and easy fix.
The only repair you are specifically allowed to do during the test is headlamp aim, which is generally pretty easy on a car, but often less so on a bike, where adjusters could be buried inside fairings etc, so even that can become a PRS, simply because it isn't a swift tweak with a screwdriver.
The alternative is, we could just fail everything and leave you to fix it, then represent at a later point - lot of faffing about for all concerned and imagine how many threads there would be on here starting "B*&Tard MOT tester failed me for a blown bulb"
My question would be, did you get charged for adjustments? ____________________ Things get better with age; I'm close to being magnificent........
UncleFester |
xX-Alex-Xx |
Shaft |
UncleFester |
doggone |
doggone World Chat Champion
Shaft |
Posted: 21:34 - 10 Aug 2020 Post subject: |
UncleBFester wrote: | Shaft wrote: |
Well, I'm not going to get into an argument, but my pass rate is 100% - 1 fail, over 5 years. |
Maybe it's different in different counties and i'm not disputing what you say ( or arguing with you) just saying that my experience is different to yours. One is a bike MOT tester and the other does cars and light goods and one is in Bedfordshire and the other in Hertfordshire. |
My view is that this is a popular myth (proved by the fact that the OP and every reply here perpetuates it) which I also thought had some truth in it, until I became a tester.
When my course instructor made it very clear that a pass was always the preferred option, I questioned it and asked about the failure target that everyone knows about - I believe his response contained the phrase 'utter bollocks'.
You also have to keep in mind there are quality control systems in place, both ongoing at the testing station and spot checking by the DVSA (VOSA as was) which can involve unannounced visits, where they will check things like your QC paperwork and mystery shopping.
This has happened a few times at the testing station I am based at and not once has our bike pass rate (the other tester brings bikes in that have been serviced first, so he also knows they wont fail) or QC procedure been questioned or criticised. ____________________ Things get better with age; I'm close to being magnificent........
Fizzer Thou |
Arfa__ |
Arfa__ Traffic Copper
steve the grease |
Posted: 00:08 - 11 Aug 2020 Post subject: Re: MoT Test Fail But No Paperwork Issued |
My mate is a tester. " The man " like to see rectifications which can be done during the test, so a fail and pass in the same test, a classic example might be a headlight adjustment, it fails and so is adjusted as part of the test. This is noted down in the data the tester enters, when he signs the test off, but is a paperwork issue, so you shouldn't get worried about it. Adjusting a chain is outside the scope of rectifications done during the test ( too big a job) and would require logging off, doing the job as a garage job, then relogging on for retest. Or something like that .
Section B para 9 of testers handbook ( found online)
9. Where the vehicle fails the test and it is expected that the defect(s) can be rectified within one hour the Tester can elect to use the PRS facility (see Abbreviations and Definitions). Provided the Tester has completed the initial examination before any repairs are carried out and the vehicle has been retained and repaired at the VTS. If the defects are rectified within one hour of completion of the test the Tester must then enter the results on the MOT Testing Service and issue a VT30 in addition to a VT20. If the defects cannot be rectified, for any reason, within one hour then the vehicle must be failed and a VT30 issued. PRS is a partial re-examination for which no fee can be charged and during which the Tester cannot register any new tests. Note: A Pass result must not be recorded before the vehicle satisfies all the test requirements.
So a v30 fail and a v20 pass are issued. ____________________ All the above is my personal opinion, you can see my lips move, but I'm talking out of my arse.
I've been riding, and fixing , bikes for 50 years, in that time the more I learn, the less I am absolutely sure of..... |
MCN |
MCN Super Spammer
wr6133 |
wr6133 World Chat Champion
arry |
arry Super Spammer
wr6133 |
ThatDippyTwat |
FretGrinder |
FretGrinder World Chat Champion
Posted: 10:43 - 13 Aug 2020 Post subject: |
When it comes to MOT histories on vehicles that I'm looking to buy, things like headlight aim, tyre tread depth and disc or pad thickness are things that don't really bother me as they're things that are easily remedied.
It's the long list of things like oil leaks, corrosion and EML lights that are there for years and are then suddenly gone for the MOT, that has just passed with zero advisories, that concerns me, especially when the car is then put up for sale.
There's no chance that all the problems have been fixed prior to selling the car, it's more likely that it'll cost a fortune to fix, so they get rid of it, using the common "need a bigger car" or "moving abroad" excuses that seem to crop up a lot.
Those that hide the numberplate are a big giveaway to a nasty MOT history, too. ____________________ Yamaha MT-09
ಠ_ಠ |
The last post was made 3 years, 256 days ago. Instead of replying here, would creating a new thread be more useful? |
