Battery or Stator?
CorriganJ
PostPosted: 09:52 - 18 Aug 2020    Post subject: Battery or Stator? Reply with quote
More endless problems with the Hyosung. It was a cheap bike but I'm going back to Japanese next time.
Anyway, during lockdown I didn't (couldn't) ride and since then its had trouble starting. Was perfect before fired up straight on the button. After lockdown sometimes it starts perfect on the dot. Sometimes I press ignition switch and nothing happens. Its not that the starter is struggling to turn, it just doesn't try. Maybe insufficent power to turn the starter motor? Then if I turn the ignition off and on then maybe it starts. I always managed to get it to work eventually, but it wasn't perfect on the dot like before.
Then the other day I rode 550km in a single day (torture on a 125). Did the trip no problem. Next day I go to start it up and nothing. Starter just chugs for ages but doesn't fire up. I try it again and again until it just does nothing (drained battery I guess).
Initially I didn't think it was the battery. I had just ridden 550km, it must be charged. I wondered if it was a clutch problem. It seemed the clutch wasn't fully disengaging so I wondered if this was preventing it from firing, either because of electrical systems preventing it, or because the clutch plates were sticking so it was like trying to start the bike in first gear, and it was just using all the energy trying to turn the wheels (a few days later the clutch cable did indeed snap and I have replaced it, but the starting problem persists).
Eventually I decided to bump start it as a last resort. I didn't think it would work because I was convinced it was the clutch not the battery, but it did start up, and I rode it around on a day trip to the mountains. Stop start was fine.
Next morning, doesn't work again. So now I'm in the situation where it is dead in the morning, I can bump it, ride around, turn the engine off and start it again warm, but if I leave it more than a few hours the battery goes dead and it needs jump starting again.
I expect the battery is dead and has lost the ability to hold charge, so my huge 550km trip either just was unable to charge it, or, conversely, maybe over charged it and damaged it? My other worry is that the battey is grounding out somewhere and draining power, but without a volt meter I can't test that.
Suggestions would be great. Might just drop the £25 on a new lead acid battery and be done with it.
1991 RD04
Tankie
PostPosted: 10:06 - 18 Aug 2020    Post subject: Reply with quote
First thing to do is to get a multi meter and check to see if the charging system is working, stop playing " pin the tail on the donkey ",
MCN
PostPosted: 10:50 - 18 Aug 2020    Post subject: Reply with quote
Y U No got Meter?
CorriganJ
PostPosted: 10:55 - 18 Aug 2020    Post subject: Reply with quote
MCN wrote:
Y U No got Meter?
Because I am of no fixed address currently... everything I own I have to carry on the bike, so if I buy a multi meter, I have to throw out either a frying pan or my soap.
1991 RD04
wr6133
PostPosted: 10:56 - 18 Aug 2020    Post subject: Reply with quote
Go on Spanish eBay and get similar to this https://www.ebay.co.uk/itm/LCD-Digital-Multimeter-Voltmeter-Ammeter-DC-AC-OHM-Current-Circuit-Buzzer-Tester/353173279979?epid=14018912118&hash=item523ac494eb:g:NAUAAOSwLNtfFo15
Though if the starter is cranking the engine it's not going to be a dead battery, well not till you hold the starter long enough to drain it.
jeffyjeff
PostPosted: 13:36 - 18 Aug 2020    Post subject: Reply with quote
CorriganJ wrote:
everything I own I have to carry on the bike.
Look at the headlight. Does it brighten up noticeably as you rev the engine off idle? If so, you can be reasonably confident the bike is charging and that your starting issues are caused by a knackered battery. But if the headlight beam stays weak across the rpm range, that would suggest a charging system problem. At that point, you will have to put a meter to the system in order to locate the problem; stator, wiring, or regulator/rectifier.
Robby
Dirty Old Man
PostPosted: 15:24 - 18 Aug 2020    Post subject: Reply with quote
Is the starter relay clicking, or just doing nothing at all when you press the button?
I agree that you need a meter, but it sounds like there are a few things going on here:
1. Sometimes not even trying to turn over on the starter.
2. Sometimes turning over, but not catching.
3. Sometimes nothing, but starts with a bump and then behaves.
As ever, if it isn't charging then reg/rec is the most likely culprit. They're just shit. Worth also sticking the battery on a proper plug-in charger, seeing as it would need about 8 hours of riding to fully charge a flat battery.
I'm wondering if there is also a problem in the ignition switch and its wiring, starter relay, or the big bundle of wires that go around the headstock. Have a good look at that wiring bundle for evidence of chafing.
CorriganJ
PostPosted: 21:34 - 18 Aug 2020    Post subject: Reply with quote
This is what I wonder too... The bike is wierd. With the side stand down the starter will chug but it will never start (by design). So it feels to me like there is something more than a battery issue here. Something in the ECU telling it not to fire. I don't know how that would work. Maybe doesn't allow a spark? No idea. Eugh.
1991 RD04
Robby
Dirty Old Man
PostPosted: 11:17 - 19 Aug 2020    Post subject: Reply with quote
Well then it could be something as simple as a corroded/sticking clutch switch, if it has a complex bunch of safety switches to stop it starting (clutch, side stand, neutral, maybe brake). One of those sticking during a few weeks of sitting is possible.
growler
PostPosted: 10:45 - 20 Aug 2020    Post subject: Reply with quote
by pass the side stand switch and see if that makes a difference
quick and simple to do if no difference you need to check the stator as they are a known issue if it is the stator you need to change the reg/rec as well as they are also shit
Ps have a gv650 07 plate and had both go stator whilst in warranty and rec just out of warranty
DILLIGAF
The last post was made 6 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.13 - MySQL Queries: 14 - Page Size: 67.41 Kb
