| GSX_Rich |
 GSX_Rich L Plate Warrior
| Easy-X |
 Easy-X Super Spammer
| GSX_Rich |
| MCN |
 MCN Super Spammer
| Easy-X |
 Posted: 13:36 - 01 Oct 2020 Post subject: |
I always like to understand these systems when problems crop up, correct me if I'm wrong here...
If you really boot the rear brake the wheel might lose traction and lock up so Step 1 is sensing the wheel has suddenly stopped rotating. Something is happening to your system given the brake won't unlock till you've stopped so I'd guess the sensor and ECU are working in the sense the ECU is saying "do ABS!"
Step 2 the ABS isolates the braking system from the master.
Step 3 is to remove pressure from the system until the wheel starts rotating again (usually a passive reservoir in the ABS unit)
Step 4 is to add pressure back in via an electric pump until the wheel locks again
The whole thing cycles between 3 & 4 until the ECU decides the traction loss event is over.
Step 5 restore master cylinder control over braking system
Thinking on the OP's situation Steps 2 & 5 are definitely happening but brake pressure isn't being relieved in Step 3. Could be the brake piston(s) sticking a bit and relieving some pressure is having little effect or, once isolated, pressure isn't being siphoned from the braking system. This could just be a bit of crap blocking a channel in the ABS... no idea what you'd do about it though
BTW the front and rear systems are parallel so one won't affect the other. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| colink98 |
 colink98 Could Be A Chat Bot
| Easy-X |
| stevo123 |
 stevo123 Nitrous Nuisance
| Robby |
 Robby Dirty Old Man
| colink98 |
| steve the grease |
 steve the grease Crazy Courier
| GSX_Rich |
| MCN |
 MCN Super Spammer
| GSX_Rich |
| MarJay |
 MarJay But it's British!
| GSX_Rich |
| davebike |
 davebike World Chat Champion
 Posted: 07:47 - 05 Oct 2020 Post subject: |
Is the ABS setting i.e. the abs light comes on when you start the bike and goes off when you first reach 5/10mph ??
If not I say the rear sensor or ring have problems
If it setting I suspect teh rear ABS modulator (ther is two one for each wheel ) Two channel ABS ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| PotatoHead202... |
 PotatoHead202... Scooby Slapper
| GSX_Rich |
The last post was made 6 years ago. Instead of replying here, would creating a new thread be more useful? |
