K157FMI Valve clearances
ThatDippyTwat
PostPosted: 15:59 - 03 Sep 2020    Post subject: K157FMI Valve clearances Reply with quote
Trying to do the valve clearances on the 125 as it's a touch tappy up top. It's a Keeway RKS125. Same motor as the Keeway RKV125. The manual https://www.manualslib.com/manual/922664/Keeway-Rkv125.html?page=129 says .03-.05 intake and exhaust.
Line up timing mark, and the exhaust isn't an issue, set to .05. The intake however, is not playing cricket. If someone knows these engines, is there a 2nd timing mark? Is this the correct mark? There are no letters beside it. What you see is what I see.
https://i.imgur.com/QXoTjnll.jpg
The manual specifies feck all about what marks there are at all, and I can't see another, but as I don't have some oddball socket (18mm, long, thin wall by the looks of it), I have to turn the motor over via the back wheel, so finesse is a tall order. I cannot get the feeler to slide, and the adjuster is flopping about like a mad thing. Gut says there must be something I'm missing, and that I'm trying to set it at the wrong position on the cycle. Any input appreciated, because this is doing my head in.
PostPosted: 16:24 - 03 Sep 2020    Post subject: Reply with quote
I'd just get the lobe on the cam to be facing 180 degrees from the lifter/rocker/valve (whichever it actually moves....)
Triumph Sprint ST 1050
PostPosted: 16:31 - 03 Sep 2020    Post subject: Reply with quote
0.03 what?
thou or mm?
0.03mm is about 1 thou so I reckon you may have added an extra zero.
0.03" is 30 thou and thassa bit large mate.
(Edited cos I ferked up and have now RTFM)
Many tappets, like mine are set around 0.1mm(abt 4 thou) IN and 0.12mm( abt 5 thou) EX
rough guide is to watch the inlet rocker/valve as you turn the wheel
after it closes, watch for the mark and stop turning when you get there
That'll be TDC on the compression stroke or TDCC
you can also stick summat down the plug hole to check
ThatDippyTwat
PostPosted: 18:01 - 03 Sep 2020    Post subject: Reply with quote
I haven't taken the cover off. It has inspection ports, so I can't see where the lobe is.
While it would probably make it a bit (lot) easier, I'm not convinced it's removable with the motor in the frame, as the top motor mount is also part of that cover. I'll see if I can see into the inspection cover with the tank etc fully off.
Watch valve actuate, turn to mark (Fairly long way), piston is at TDC (Torch down sparkplug hole), still cannot get blade between valve top and tappet. It will have to wait till the weekend before I attack it again.
jeffyjeff
PostPosted: 19:05 - 03 Sep 2020    Post subject: Re: K157FMI Valve clearances Reply with quote
Remove the spark plug and use a wood dowel or screwdriver to make sure that when the mark is lined up, your piston is at top dead center (TDC) (all the way up, closest to the spark plug hole).
At that point, the intake and exhaust valves should be unloaded, i.e. you should be able to wiggle the rocker arms a little bit. If one is tight, bar the engine around 360 degrees and try again. You need to make sure that the piston is at TDC of the compression stroke, not TDC of the exhaust stroke.
ThatDippyTwat
PostPosted: 19:33 - 03 Sep 2020    Post subject: Reply with quote
I'll have another look at the weekend. It can rot in the corner for the rest of tonight.
ThatDippyTwat
PostPosted: 10:37 - 05 Sep 2020    Post subject: Reply with quote
Ursa I am missing something entirely (which is a very real possibility), then I cannot get the gauge under on any part of the cycle. Even with the adjuster completely out of its hole (to confirm I am indeed not getting a gap). I lined up to the mark, confirmed it was TDC - No joy. I rotated it until it got TDC again, still no joy. If I'm doing or missing something silly, please point it out, this isn't your usual BCF "I'm doing it my way, fuck you" question and ignorance session. While I've adjusted valve clearance in the past, all of them had specific marks and instructions to follow, and were not a problem.
kramdra
PostPosted: 11:04 - 05 Sep 2020    Post subject: Reply with quote
It is a single cylinder 125, it only needs one timing mark. If it is a K157FMI then same engine as my Sinnis Stealth and very simple to do. Requires small hands to do the intake.
From what you say, it is probably worth removing the head to inspect the seat. Heads are cheap enough on these.
PostPosted: 13:23 - 05 Sep 2020    Post subject: Reply with quote
Timing marks? Am I being a bit thick here... I turn the engine over, the valves go in and out, I guess where the middle of "out" is and measure the gap Thinking
ThatDippyTwat
PostPosted: 14:47 - 05 Sep 2020    Post subject: Reply with quote
Swapped my feeler gauges for my work set. I can now get then in. Convinced the numbers given are wrong as it sounds like a bag of nails, but it does start (I killed it just as it fired). Reckon I'll go with standard K157FMI figures, (.08 and .13), and see what that does
PostPosted: 15:00 - 05 Sep 2020    Post subject: Reply with quote
Just looking at an old Keeway manual and they have it down as 0.07~0.09mm (in) and 0.08~0.10mm (out)
That's for a KW157FMI which AFAIK is very similar to the K157FMI.
ThatDippyTwat
PostPosted: 16:08 - 05 Sep 2020    Post subject: Reply with quote
Cheers dude. I'll play with those tomorrow. Put it away and broke out the alcohol instead. KW157FMI is exactly what the motor is. The only difference I can see vs a K157FMI is some sort of EGR/Emissions re-circulation fuckery.
ThatDippyTwat
PostPosted: 18:43 - 04 Jan 2021    Post subject: Reply with quote
Just so anyone checking this has an update, Official figures from the importer for the Euro 3, pre-EFI Keeyway RKS125 are .04-.08 intake, .04-.08 exhaust. They didn't specify, but I have to presume mm. I'll check it at the weekend.
I did set .08 intake, .13 exhaust, as you would on most GS derived motors, but it sounded tappy as all hell.
oilyrag
PostPosted: 19:50 - 04 Jan 2021    Post subject: Reply with quote
The manual you put up says
Basic Data Unit mm
Intake 0.03-0.05
Exhaust 0.03-0.05
ThatDippyTwat
PostPosted: 20:23 - 04 Jan 2021    Post subject: Reply with quote
Basic Data Unit mm
Intake 0.03-0.05
Exhaust 0.03-0.05
And according to the importer, that's wrong. I have the email here. They won't sell or give me a service manual.
steve the grease
PostPosted: 20:45 - 04 Jan 2021    Post subject: Reply with quote
As its a 4 stroke engine there are 2 rotations of the engine to complete a cycle. so there are 2 TDC's - compression and what some people call 'the rock'. So called because this is where the exh is just closing and the inlet is just opening ( so they appear to rock). Its important to set the tappets with the TDC on the compression stroke , when both followers are well onto the heel of the cam - Turn the engine over and observe the position of the T mark in relation to the valves opening and closing as you turn the engine over, then it should make sense.
oilyrag
PostPosted: 21:10 - 04 Jan 2021    Post subject: Reply with quote
Is that it? https://www.manualslib.com/manual/1076829/Keeway-2015-Rks-125-26.html?page=12#manual
The last post was made 5 years, 95 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 93.94 Kb
