| Author |
| SirFallalot |
 SirFallalot Trackday Trickster
 Posted: 01:41 - 04 Oct 2020 Post subject: Decided to practice wet emergency stops today |
And guess what happened!
I have both the full A tests and a trip soon, coming back from a looong bikeless holiday I thought i should practice slow manoeuvres and the big stop beforehand while it's pissing down as I hadn't riden the 750 in rain...
Was doing it progressively, 20-0, 30-10, 40-20, 60-floor
I actually managed 2 60 to 20, but fell right off on the third lolz
Anyway, was reading some topics on straightening handlebars and whatnot. Saw some used ones on eBay for 25-30, better to get some used ones or do you usually have any luck straightening them?? Not sure if anything else out of whack, also broke the footpeg so was riding funny. At least I didn't break the odo like I always do on the 400, just the headlight. And shame, the exhaust was so shiny.
All in all l'm glad I ride cheap bikes and bought most of my gear on eBay  ____________________
Lexmoto Valiant 125; 94 CB400; 96 CB750F2; 81 CB750 (restoring, lol not gonna happen); 2001 ZX9R(It's about to go :c); 2012 R1200R; 2015 R1200RS |
| Back to top |
| Pete. |
 Pete. Super Spammer
 Posted: 07:36 - 04 Oct 2020 Post subject: |
Firstly, don't think of it as 'emergency stop' think of it as 'stopping under control'. All you have to do is come to a quicker than usual stop without skidding - from around 30mph - and if you are doing it in the wet then all you have to do is, well, stop. Practising at 60mph in the wet is a bit daft.
Bars are a piece of cake to bend back into shape so long as they are not kinked or flattened where they bent. Long piece of wood to align the wheels and a tape measure. Have someone hold the steering straight and the bike upright then use the tape to check one side against the other. Measure back from the bar end to somewhere at the back like the rear indicator then measure each side down to the front spindle. Bend the bars by hand and get the measurements the same within about 10mm. If they are only mildly bent then straightening them won't hurt. If you're talking like 30 degrees or more don't attempt it. ____________________ a.k.a 'Geri'
| Back to top |
| trevor saxe-coburg-gotha |
| Back to top |
| doggone |
 doggone World Chat Champion
 Posted: 08:08 - 04 Oct 2020 Post subject: |
It should stop your wheels locking up, that might not be why he fell off though
I have noticed it working reasonably well even at lowish speed on crappy stuff at the edge of the road for example |
| Back to top |
| stinkwheel |
 Posted: 09:58 - 04 Oct 2020 Post subject: |
Steel bars are less likely to suffer from internal stress fractures having been bent then straightened than alloy ones.
Check your steering lock-stops.
Watch this: https://youtu.be/HiOGAYOXN8U
I'm not so convinced about preloading the levers like he says but it's a very good explanation about the physics of braking and why a progressive squeeze is better than a grab. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Back to top |
| SirFallalot |
 Posted: 10:30 - 04 Oct 2020 Post subject: |
Thanks for the tips guys, yes it was definitely daft
It was that progressive braking that I was practicing. Also I'm as sore as the first day at the gym after years  ____________________
| Back to top |
| Bhud |
 Bhud World Chat Champion
| Back to top |
| MCN |
 MCN Super Spammer
| Back to top |
| SirFallalot |
 Posted: 18:20 - 04 Oct 2020 Post subject: |
Well not sure if abs would've helped much, maybe, probably, I have tried it in cars with varied results depending on road conditions (when I drive a new vehicle for a long journey, first thing I do is check braking).
This once I was testing, albeit at slower speeds, braking on pine leaf covered country lane. The abs took about twice as long to stop as controlled braking. I found this quite amusing.
Regarding my ooopsy, it was very very quick, I thought I was getting the hang of it, but must have been lingering on the limit because then it instantly slid off before I knew what was happening. I was quite surprised tbh, as when I did the same practice on my 400 I was able to feel it and recover.
I'm an avid Fortnine watcher too  ____________________
| Back to top |
| Bhud |
| Back to top |
| barrkel |
 barrkel World Chat Champion
 Posted: 00:13 - 05 Oct 2020 Post subject: |
Based on my aggressive year-round riding on slippery London streets on bikes with ABS, I'm certain you wouldn't have crashed with ABS, providing you were braking in a fairly straight line. With functioning ABS, on road which is simply wet and not covered in oil or ice or debris, absolutely 100% certain.
When I rode my many SH300s every day, I regularly exercised the ABS through aggressive riding and deliberately braking at the limit. You can feel the ABS pump pulsing through the levers on that bike when it kicks in, so I was well aware of it. I used it to ride faster in wet weather because I knew I could slow down rapidly while retaining control. I'd ride hard up to a stop line with a red light and brake hard, learning how much extra slippage I'd get under ABS.
The most dramatic incident that I recall had me effectively drifting somewhat diagonally, with partial traction on both front and rear, while emergency braking for a hazard (I no longer recall what it was). I still had control over steering and I did not crash or drop the bike.
I'd never buy a bike for commuting that doesn't have ABS. Commuting means riding all year around (so, all weathers) and filtering during rush hour. I could do it on a non-ABS bike, but I'd be a lot slower when the weather is wet. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| Back to top |
| c_dug |
 c_dug Super Spammer
| Back to top |
| Serendipity |
 Serendipity World Chat Champion
 Posted: 08:55 - 05 Oct 2020 Post subject: |
I value ABS for exactly that. Filtering in the wet along slippery white lines. The majority of front wheel lock-ups that I've provoked have been panic grabs as a car changes lane without looking. Eating tarmac because someone manoeuvred without due care is shit and anything that can help prevent that is good.
I've saved quite a few front wheel lock-ups on bigger non-ABS bikes, but smaller bikes seem to fold and go down in milliseconds. Not sure if that's additional gyroscopic assistance from a heavier, still spinning rear wheel on the bigger bikes, or just better brakes that release quicker. I binned my old RXS100 a couple of times in the wet. My reactions are pretty good, but there was no saving it either time. It was down and sliding in an instant. ____________________ 2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation |
| Back to top |
| Bhud |
 Posted: 08:59 - 05 Oct 2020 Post subject: |
| Quote: |
| Bhud wrote: | I hope our posts on BCF are as useful to him and others as ever. There's nothing quite as satisfying as having your own ideas, knowledge and experiences repackaged and presented by a tall, smiling Canadian |
Curious what you're referring to here? |
Everything. What drew my attention to it was after I wrote a long and detailed analysis of what killed Harley Davidson, on Mark Hinchcliffe's Motorbike Writer website, in the form of a text comment. I made a number of points, the central one being that Reagan's tariffs ensured the slow demise of that company by relieving it of the need to adapt or give way to a competitive new manufacturer that would have been willing to adapt.
About a week later Ryan came up with a video regurgitating the same points, in a flashy semi-pro audio visual presentation. It got lots of reviews and praise, but, knowing exactly what I had written, based on my belief in the value of allowing businesses to fail, I didn't feel it was original. My own thoughts about economics and business have come out of a lot of specific reading, and they took time for me to forment. Curious, I checked his other videos and I found the same pattern èverywhere. He did a video on "darksiding" which was just a more polished pastiche of a video made about a month earlier by an engineer type, and so on. I could probably our emergency brake the guy in my sleep, but I expect he will have watched advanced motorcycle instruction videos and picked out the salient points to repackage in his own video, which makes him an "expert".
As for the role in BCF in all this, it's a huge archive open to anyone with an internet connection. You've got maybe 5 people talking about what had for breakfast, a new bike-related thread every couple of days, yet 77546674 people online at any given time lol. They're reading and some are just going to repackage what they read. |
| Back to top |
| Ste |
 Ste Not Work Safe
| Back to top |
| Bhud |
 Posted: 10:41 - 05 Oct 2020 Post subject: |
| Ste wrote: | What you're saying is Mark Hinchcliffe is a Dirty Bertie AND his Motorbike Writer website is a Dirty Bertie? |
Well, it's hard to say yes or no for certain, but ideas seem to migrate to Youtube from a variety of known typed/written sources on the internet, and I would say Motorbikewriter and BCF are 2 of those, yes.
Bugs me a bit, though, when the wheel comes completely around and Youtube becomes the new centrestage. It's exactly like the Bike Shed and similar things. Those people started butchering old classic bikes, right? How did they ever get them to sort of run in the first place? It wasn't from Haynes or from people they knew - it was from reading posts in the Workshop subsection of this forum most of the time. If your dad's a hedge fund manager and you're 21 year old NGO worker who lives in Notting Hill, you don't know anybody but Mr Google. Now those same people are commissioning professional videos that say there was no custom bike scene until they created it in the UK in about 2014, AND that dad taught them to build bikes in their back garden at the age of 8-ish, funnily enough (I've actually seen those videos). Pure lies. The rabbit-hole goes deep with narcissists. |
| Back to top |
| PotatoHead202... |
 PotatoHead202... Scooby Slapper
| Back to top |
| SirFallalot |
| Back to top |
| SirFallalot |
 Posted: 00:12 - 15 Oct 2020 Post subject: |
Also I managed to get parts for the bike by Friday and was braking hard by Saturday morning
It was in a straight line, barkell you are right, abs probably would've saved it, but I had expected to be able to save it myself, such as is possible at slower speeds, before things went sideways. At least now I know exactly how much I can brake at 60 in the wet i just hope I don't forget ____________________
| Back to top |
| Pete. |
 Pete. Super Spammer
| Back to top |
The last post was made 6 years, 11 days ago. Instead of replying here, would creating a new thread be more useful? |
