zzr600 stuttering problem
shea1980
PostPosted: 21:40 - 06 Oct 2020    Post subject: zzr600 stuttering problem Reply with quote
Guys my 1997 zzr600 has a problem,I have balanced the carbs cleaned the carbs(jets),New air filter plugs etc,But when the bike is below 4000rpm(while riding,fine when reving it at standstill) the bike stutters and and doesnt run right at all,but above 4000rpm it runs great,Also guys the tick over of the bike is fine also,Would anyone know what the problem might be?Thanks all
shea
jeffyjeff
PostPosted: 05:18 - 07 Oct 2020    Post subject: Reply with quote
If the bike did not exhibit these symptoms before you worked on it, you might have unintentionally caused the problem yourself. Carburetor jets are notoriously fickle, and you might have buggered one or more jets in cleaning, especially if you tried to ream the jet bore with a drill bit or a welding tip cleaner, etc. If that be the case, new jets are in order. The main jets take over to supply full power fueling at around 4000 rpm, so your issue could be related to the jet needles. Inspect the needles and main jets to ensure they are free if all debris, needles set to the same height in the carburetor slides. Make sure no slide is hanging up in its bore. Also, synchronize your carburetors at or near your normal cruising RPM.
Tankie
PostPosted: 05:31 - 07 Oct 2020    Post subject: Reply with quote
Did you check the plug gaps before installing?
Also check the caps were fitted correctly
redeem ouzzer
PostPosted: 16:00 - 07 Oct 2020    Post subject: Reply with quote
Stop talking bollocks. On a CV carb with an engine that revs to 14K the main jets are doing fuck all at 4k. 4k is on the crossover from the pilot bleed circuit to the needle. I'd be looking at the pilot jets, pilot circuit (including the air jets in the bellmouths) and the air bleed holes that are uncovered by the butterfly as the throttle opens from idle.
Be a REAL MAN!
oilyrag
PostPosted: 17:04 - 07 Oct 2020    Post subject: Reply with quote
Did it only start happening after your carb work? Does it improve if you put the choke on?
jeffyjeff
PostPosted: 19:50 - 07 Oct 2020    Post subject: Reply with quote
Calm down, bro. Maybe revved with the transmission in neutral, but under load with the butterflies wide open, I'm quite confident in the transition to main metering. It's all about airflow, not engine speed alone.
Jozzer
PostPosted: 23:06 - 10 Oct 2020    Post subject: Reply with quote
Is the airbox sealed properly ?...
Had the same issue with mine when I bought it (2003/E11) over time the pressure of the tank pushing down on the top of the airbox along with the heat generated from the motor causes the airbox to warp and gaps to open up allowing unwanted air in, fairly crucial on these due to the ram air system...
The first place to look would be along the bottom of the carbs where they meet the airbox, this can be seen from the side of the bike and any air being drawn in through here will cause the same symptoms you are describing, coughing and spluttering bellow about 4-4.5k then suddenly it'll clear and the bike tears off up the road like a scalded cat !...
I had to make a couple of braces to go inside the airbox so as to clamp it down against the carbs properly...
Don't make the same mistake I did and immediately start chasing a non existent carb issue, been there, done that...
The last post was made 6 years, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.35 - MySQL Queries: 14 - Page Size: 52.07 Kb
