Davedup1 |
Davedup1 L Plate Warrior
Pete. |
Pete. Super Spammer
Posted: 11:21 - 18 Oct 2020 Post subject: |
Combinations aren't usually registered as trikes.
If it's an add-on there might be nothing to do except remove it and sort any wiring or brakes. Look at the rear tyre, it might be square profile so you'd want to change it for a round one as per normal bikes. ____________________ a.k.a 'Geri'
Davedup1 |
Posted: 11:38 - 18 Oct 2020 Post subject: |
Just the spannering aspect. Also might need to tell the insurance.
Some combinations aren't all that suitable for riding solo. The more specialised the outfit, the less likely it will make a suitable solo. The better outfits will have huge leading link or hub centre front ends for example. Often the suspension will have been significantly beefed-up so you'll have way too much preload and damping. They are often geared lower than the road bikes too. I would change the tyres regardless of what's fitted, they will have odd wear patterns.
Also worth noting that a bike that's had a bigger sidecar on it for a long time can land up with the frame taking a set and being bananna-shaped ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Davedup1 |
pepperami |
pepperami Super Spammer
Riejufixing |
Nobby the Bastard |
Riejufixing |
yen_powell |
yen_powell World Chat Champion
Davedup1 |
The last post was made 3 years, 190 days ago. Instead of replying here, would creating a new thread be more useful? |
