| A100man |
 A100man World Chat Champion
 Posted: 12:09 - 19 Oct 2020 Post subject: Sloppy hole, new bush required? |
The gear lever on my XJ has a kind of rear set arrangement with a pivot shaft on the sprocket cover. I looks like the gear lever hole has ovaled a bit from long term thrusting.. The hole looks like it 'should' be 12mm ID.
anyone drilled one out and fitted a (new) bush?
Looks like I can get steel or bronze sintered or split in OD 14 or 16 mm
. the plan being to drill out with a pillar drill and press in with vice - thoughts? ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| Islander |
 Islander World Chat Champion
| stinkwheel |
 Posted: 13:41 - 19 Oct 2020 Post subject: |
I did it with the rear brake pivot on my VFR, worked wonders. I used a split glacier bush and a new trunnion.
I'm not entirely clear how the arrangement on yours works but it looks like there is a steel pivot shaft that screws into somewhere. Make sure that isn't worn too (they are cheap if it is). It's got a central groove for grease so I'd be tempted to use a solid bronze bushing.
You'd usually drill it to a hair under the final diameter then finish off the hole with a reaming tool (drills don't make round holes). You'll probably get away with it though. The final diameter would ideally be for an interference fit, so marginally smaller than the OD of the bushing. One way to achieve something close without a mill would be to drill it to the next drill size down then take the hole out to final diameter with a piece of emery cloth trapped in a slotted bit of tube in your drill (like a flap wheel).
If you go for a solid bush, heat fit it, don't press it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Riejufixing |
 Riejufixing World Chat Champion
| A100man |
 Posted: 16:12 - 19 Oct 2020 Post subject: |
Thanks all - can't be sure what it's made of looks like chrome plated steel but who knows..
.. new ones are NLA on CMSNL and I think all used ones will be as bad as I have. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
The last post was made 5 years, 357 days ago. Instead of replying here, would creating a new thread be more useful? |
