Honda Varadero 125 v2. HT arcing
Energgy
PostPosted: 12:00 - 26 Oct 2020    Post subject: Honda Varadero 125 v2. HT arcing Reply with quote
Hi ,
I got a Honda xl125 v2 varadero (2002)
I've got a problem with the HT cable on front cylinder.
It will not work with the cap on the plug. But if i hold the cap just just above the plug it works fine.
I tried to swap the coils and it gives the same result.
Please help.
Riejufixing
PostPosted: 12:42 - 26 Oct 2020    Post subject: Reply with quote
Use a little water and meths. on a bit of rag to clean the plug, and dry it carefully.
The same for the plug cap, inside and outside (you will be better off unscrewing it from the cable, if it will come off).
Then try again.
jaffa90
PostPosted: 13:15 - 26 Oct 2020    Post subject: Reply with quote
It sounds to me like the spark plug has too much resistance. (faulty).
Energgy
PostPosted: 12:29 - 27 Oct 2020    Post subject: Reply with quote
Hi ,
Thank you for your advices.
I have swapped the spark plugs and it fixed the problem.
I will replace the spark plugs in the near future to make sure it won't happen again.
The last post was made 6 years, 18 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.74 - MySQL Queries: 14 - Page Size: 37.65 Kb
