Bendy stuff
Keithy
PostPosted: 00:29 - 06 Nov 2020    Post subject: Bendy stuff Reply with quote
So what am I supposed to be doing here?
Day out for a rip and basically I’m ok riding along bits I know but I’m not confident when it comes to bendy bits where I don’t know where the road is going to go. I have no idea how much lean I have and what is a safe way to learn.
I do 100+ miles and get the feeling I know what I’m doing and 400 yards from home and trying to go 270 on a roundabout and the throttle is on and off like a whore’s drawers.
Having near terminal ‘car brain’ the throttle response catches me out all the time, I struggle to manage it because it feels so on/off. So that a roundabout goes...
Approach
6th gear
70mph
‘Car brain’ - back off and coast
Throttle off
Zero progress
Cars up your bunghole
Throttle on
Lurch forward
Panic, kick down a couple of gears
...and another
Prepare to stop
Look for a gap
Pray you are in second
Accelerate into the gap
Off the throttle as it’s all going a bit quick
No progress
Back on it
Lurch forward, quickly
Everything is speeding up and you are on a feckin’ roundabout
Off the throttle
Zero progress
Back on it...
Lean looks a bit severe
Off the throttle...
FML it’s depressing.
So what do I need to do or practice?
davebike
PostPosted: 07:41 - 06 Nov 2020    Post subject: Reply with quote
read "roadcraft" you want the bike version or the IAM how to be a better rider
When we are out of lockdown take post test training IAM ROSPA Bikesafe or a pro instructor
Basic game plan is lose speed befor a bend either engine brake or brakes select gear for bend lean in and apply a little power when you can see the exit more power !
bikes like any rear wheel drive do not corner well off power
Dave
NC750Xdct + others at work !
davebike1@gmail.com
ThunderGuts
PostPosted: 07:49 - 06 Nov 2020    Post subject: Reply with quote
As above; we could spend all day with typed instructions but a day or even a half day with an instructor would provide more use than reams of typed responses on here.
Roadcraft is good and worthwhile, but an instructor will tell you when you're not doing something quite right, even when you think you are; it can be quite difficult to accurately assess everything you're doing yourself as you're riding.
Assuming you're going to carry on riding between now and any instruction (if you decide to get any), just try to be smooth and plan what you do. Don't fret about cars being held up by 10 seconds if that's what it takes for you to take junctions/bends/roundabouts that bit more slowly. Lurching around on the edge of (or over) your comfort zone isn't going to do your confidence any good and might result in worse.
TG.
arry
PostPosted: 08:41 - 06 Nov 2020    Post subject: Reply with quote
It's just noobie nerves is all - you'll get through it.
Focus on general principles and practice them in areas you feel safe and confident.
The chances are if you're on / off the throttle a lot in a roundabout, it's because you've let your gaze go down to the road right in front of you rather than being positioned on the bike correctly, with nice funky chicken loose elbows, and your head positioned out where your right hand mirror is and staring down the road as far as you can see in the direction you are wanting to go in. You'll be amazed how little things like looking through the corner make the corner far, far less scary.
wr6133
PostPosted: 09:45 - 06 Nov 2020    Post subject: Re: Bendy stuff Reply with quote
Keithy wrote:
Approach
6th gear
70mph
Throttle off
Zero progress
Throttle on
Lurch forward
...and another
Prepare to stop
Look for a gap
No progress
Back on it
Off the throttle
Zero progress
Back on it...
Off the throttle...
It comes with time don't over think it. Try to ride with some fast, experienced riders too. Monkey see, monkey do principle.
Twist of the wrist 2 on youtube is also worth watching for the basic principles, warning though it is so cheesey it makes Stilton appear mild.
Kawasaki Jimbo
PostPosted: 09:46 - 06 Nov 2020    Post subject: Reply with quote
Roundabouts are rarely truly round so don't necessarily expect to have constant lean and constant throttle there. A birds eye view via Google Earth can be informative if there's a local roundabout you keep 'getting wrong.'
Keep riding, it'll come.
ThunderGuts
PostPosted: 10:14 - 06 Nov 2020    Post subject: Reply with quote
Yes they're notorious for this and frequently transition curves are poor or non-existent (for those not familiar, this is where a bend is progressively introduced rather than on/off - modern fast roads and A roads will typically have these, whereas your back country lane following some old field boundary/stream will not). This means you find you have to sometimes make more exaggerated adjustments than you'd expect, although on a bike you can utilise your lane width to smooth it out a bit in a way that in a car is not so possible.
TG.
TaffyTDM
PostPosted: 10:55 - 06 Nov 2020    Post subject: Reply with quote
All as above, typed stuff isnt a patch on observations. What jumps out at me though is i wouldnt be in 6th if anticipating a roundabout, i would be probably holding 3rd or 4th depending on the gearing.
doggone
PostPosted: 11:07 - 06 Nov 2020    Post subject: Reply with quote
Much more important on a bike to go down through the gears well in advance of tight bends (and fun too).
You want/need to be balancing throttle against your angle of lean to progress smoothly on your chosen line.
It sounds impossibly complicated but with experience you don't even think about it.
Try to read up on counter steering and experiment in a safe quiet place.
i.e. push the bars on the inside of your turn forward and down to initiate a positive smooth lean and turn.
Getting this into your muscle memory early on will pay dividends in many situations later including lightning fast lane changes to avoid others not seeing you.
Keithy
PostPosted: 11:09 - 06 Nov 2020    Post subject: Reply with quote
During instruction I was told I should be block changing, so hold speed on approach as coming off the throttle means I’m slowing 150m before I should. So ‘plan to stop’ on approach but generally aiming for 2nd if I’m going 270 degrees. I’m just so jerky on the throttle.
My copy of roadcraft arrived before the bike did Thumbs Up
Just need to start reading it. Embarassed
Tdibs
PostPosted: 12:17 - 06 Nov 2020    Post subject: Reply with quote
You really just want to be setting the throttle when entering the roundabout. Even if you go a little slow, keeping it set and the whole maneuver smooth is most important, gently accelerate out the bend, you want to be aiming to not have to make adjustments during the turn.
You want to just be smoothly working down the gearbox while smoothly applying your brakes as you come to a stop. I would honestly say, the bloc shifting comes later when it does not become something you have to think about. If you go down each gear, using the engine braking to help you, you are less likely to get caught out with the on/off throttle.
Like anything though, it just takes time and practice! Dont overthink it too much.
What bike are you on?
PostPosted: 13:34 - 06 Nov 2020    Post subject: Reply with quote
There are certain bends where a car could approach, go round and exit all at 50mph. On a bike the same bend might be 50mph approach, 40 round the bend but 60 on the exit. Don't get hung up on riding/driving to someone else's pace (i.e. the tailgater behind) save that for the race track.
The ideal is brake into the approach and accelerate to get out with the minimum of coasting in between. What speed/gear you should be in for an unfamiliar bend is just something you have to build up to with experience. Rome wasn't built in a day and all that Smile
TaffyTDM
PostPosted: 11:58 - 07 Nov 2020    Post subject: Reply with quote
You will find that being in the correct gear for speed will mean you can roll off later and have a more settled and controlled approach whilst you scan and make your plan to stop/look to go call, and whether you are going to straighten the roundabout or not. There is a tendancy for car brain to change up to higher gears too soon, try using the full rev range and get used to working the engine more, it does seem alien at first.
In roadcraft terms - I - roundabout is coming, whats the traffic on approach, can i see the exit, lateral scans can i see whats coming. This will influence your Positioning, if you resisted the temptation already to be in 6th at S - 70 when not on a mway, you are probably in 3rd or 4th already, keep throttle on until you are roughly halfway closer to the hazard, roll off whilst you have another look depending on how much speed youve needed to scrub off select the appropriate G to drive the bike, not coast it, throigh the midpoint of the hazard before Accelerating away
PostPosted: 13:34 - 07 Nov 2020    Post subject: Reply with quote
A motorcycle throttle is an anlogue control, it's not just on or off, it should be in constant, smooth motion while you are cornering.
Try watching this, just remember he has a quickshifter so doesn't need to close the throttle for gearchanges.
https://youtu.be/QI96DsI0fPM
hellkat
PostPosted: 14:23 - 07 Nov 2020    Post subject: Reply with quote
Fuck.
Do you really think all that stuff in, like, a 5-10 second space Question
I'm certain I had moments like that - dropping from third to second gear to turn, and then stalling on the junction at Vauxhall Bridge springs to mind. Rolling Eyes
Nerve-wracking.
Even now, admittedly, if I am on bendies in the countryside, i'm fairly rubbish cos i don't ride much out of urban areas.
But when I do ... I'm proper rubbish Laughing
If it helps, all that stuff does eventually become unconscious.
PostPosted: 20:35 - 07 Nov 2020    Post subject: Re: Bendy stuff Reply with quote
But bear in mind "monkey try to keep up" can get messy Smile
Keithy
PostPosted: 21:26 - 07 Nov 2020    Post subject: Reply with quote
ER-6F
Too right, being post-diseasel beemer 2,500rpm seems hurried. So what are folks tootling around at, 5k, 7k?
Gibbon a chance I will, just hope I don’t make a howler.
hellkat
PostPosted: 22:55 - 07 Nov 2020    Post subject: Reply with quote
Pffft, lucky if i make 4.5 Laughing
But then ... HD, after all Wub Puke Wub
PostPosted: 23:40 - 07 Nov 2020    Post subject: Reply with quote
I take this corner at 'vroommmmm' and that corner at 'VROOMMMMMMMM' (no rev counter on the Rebel!)
Bhud
PostPosted: 00:03 - 08 Nov 2020    Post subject: Reply with quote
High rpm, if not stuck in traffic, or in heavy traffic in town, or filtering past a line of traffic.
Pete.
PostPosted: 08:30 - 08 Nov 2020    Post subject: Re: Bendy stuff Reply with quote
Get time under your belt. But in the meantime:
Don't carry weight on your arms, it exaggerates steering input and unsettles you when you have to turn. Bend your elbows and lean forward a bit when turning. Turns suddenly become much easier, even more so if you lean forwards AND slightly into the turn.
Look at where you want to go, not where your bike's pointed. Avoids target fixation. If you look at the kerb - the kerb is where you're heading for.
Turning requires being leaned over but once leaned over only your speed coupled with turn rate keeps you up. If your bike is falling into the turn you have to tighten up the turn or increase speed to stop the fall. Novices don't like the 'speeding up' option so they turn tighter, which then stands the bike up a bit and straightens their path so now they are going wide on the roundabout and have to lean more again to tighten the turn and all this causes the '50 pence' effect when navigating roundabouts.
The way to avoid it is to get your braking done before you turn then use the throttle to accelerate yourself gently round. Being on the power slightly will keep the bike settled and you'll be ready for the roll-out. If you're still lurching on and off the throttle - use one gear higher. If you're STILL struggling, use a bit of power and the back brake but gently and only when speeds are low. Applying a little rear brake will tighten the turn. Letting off will open the turn.
a.k.a 'Geri'
ThatDippyTwat
PostPosted: 09:02 - 08 Nov 2020    Post subject: Reply with quote
Time, practice.
At least you know it's not quite right, and you're looking to sort that, usually noobies think they're Rossi and are at the top of Mt Stupid on the Dunning-Kruger curve. Don't overthink it, don't hard-force it and go wildly out of your comfort zone. It'll come.
If it helps, I'll rag the absolute snot out of small light bikes (Crossers, Motards, smaller 250-ish road bikes etc), but I baby my lardy viffer around as I learned and have most experience on tall, light bikes that need to be manhandled to get the best out of them. We all have areas we can improve on.
trevor saxe-coburg-gotha
PostPosted: 09:53 - 08 Nov 2020    Post subject: Re: Bendy stuff Reply with quote
Approach
6th gear
70mph
Throttle off
Zero progress
Throttle on
Lurch forward
...and another
Prepare to stop
Look for a gap
No progress
Back on it
Off the throttle
Zero progress
Back on it...
Off the throttle...
Go out early in the morning or late at night when traffic is light or non-existent. A lot of the difficulties here are due to the pressure (real and imagined) from other road users.
This isn't the best time of year - nor history. But obvious as it'll sound, you'll find that empty roads are loads easier to negotiate than busy ones. And you can build up from there.
kolu
PostPosted: 10:56 - 08 Nov 2020    Post subject: Reply with quote
Keithy wrote:
ER-6F
between 1/3-2/3 of your redline is usually the most responsive and also linear range of your engine behaviour. I would guess about 4k-6k would be nice. at lower revs it will be "snatchy" and weird. I remember from my training on ER-5 that it was basically useless under 3k - choppy, sound like fart, no pull... rev it! in any case it is like 1/4 of your diesel, you need the revs if you don't have the displacement.
when I'm in the twisties and want fun, I'm usually around 6-8k on SV650, when cruising in city 3k is plenty.
PostPosted: 13:23 - 08 Nov 2020    Post subject: Reply with quote
The main thing is: you're not driving a car Wink With 4 wheels you can pick any speed and adjust it with brakes and throttle at any time round a bend - you could stop dead if you wanted and it wouldn't matter (guy behind might have another opinion of course!)
The upside of the bike though is when you get a corner right it feels like something beautiful. And outside of a race track that's not something you get with a car Smile
The last post was made 4 years, 339 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 137.13 Kb
