| Author |
| buzzer1955 |
 buzzer1955 Nitrous Nuisance
| Back to top |
| arry |
 arry Super Spammer
 Posted: 11:44 - 12 Nov 2020 Post subject: |
Cool
Look forward to progress with interest. |
| Back to top |
| Keithy |
 Keithy Spanner Monkey
| Back to top |
| buzzer1955 |
| Back to top |
| P.addy |
 P.addy Red Rocket
 Posted: 22:07 - 14 Nov 2020 Post subject: |
Another one! Love these builds. |
| Back to top |
| buzzer1955 |
 Posted: 17:15 - 15 Nov 2020 Post subject: |
Tried to remove the cush rubbers today as I am going to have the wheels powder coated... the rubbers were good, so I didn't want to destroy them. You can't knock them out as the drift just bounces off the rubber, and there is no way to get to the outer sleeve... So I made this puller, that has a split threaded cotter. its a bit fiddly, but they came out a treat, and I can re use them now
https://jtccc.files.wordpress.com/2020/11/cush-drive.jpg |
| Back to top |
| buzzer1955 |
 Posted: 11:10 - 16 Nov 2020 Post subject: |
Just preparing the frame and parts to take to the powder coaters... On the grab handle there were two small dents that I just know that if I left them they would bug me forever, so I TIG brazed them up and filed them down. there is something really satisfying about TIG brazing!
https://jtccc.files.wordpress.com/2020/11/dent-in-frame.jpg |
| Back to top |
| arry |
 arry Super Spammer
 Posted: 11:30 - 16 Nov 2020 Post subject: |
Top work Sounds like you're going to town  |
| Back to top |
| buzzer1955 |
| Back to top |
| buzzer1955 |
 Posted: 17:35 - 18 Nov 2020 Post subject: |
the engine is all apart, and I am pleased with its condition... no bore wear, and everything look good. the main reason to take it apart is to bead blast the cases... which of course means a complete strip. I am glad I did it anyway as people have pointed out the crank plugs come loose which damages the cases. While this one was not loose, it was not tight either can came out with a gentle twist of the screw driver... disaster waiting to happen! its locktited in place now...
https://jtccc.files.wordpress.com/2020/11/crank-plug-copy.jpg
[img]I hate bashing bearings out,and where possible try to make a puller of some sort… in the case of the swinging arm bearings it’s easy, just a stepped bush (it does destroy the inner seal..) and out they come. the step needs to clear the circlip though… some of the engine bearings are more difficult as you can’t get to the back… for this I made an expandable stepped puller, that expands into the bearing as a bolt rides up an internal taper. with this they come out easy…[/img]
https://jtccc.files.wordpress.com/2020/11/bwaring-removal-3-copy.jpg
https://jtccc.files.wordpress.com/2020/11/bearing-removal-2-copy.jpg
To get the bearings out I also heat the cases… I would like to use the oven as its a more even heat… but I can’t for two reasons.. the first is the cases are too big… and secondly she gets upset, particularly as its a new oven! So over the halogen heater it is… keeping an eye on the temperature… I also like to mark EVERYTHING, so it can go back where it came from, and in the same position. I am not keen on centre pops, instead I use a little diamond burr in the dremel… this will even mark bearings and means you can number stuff as well, and it does not cause stress raisers…
https://jtccc.files.wordpress.com/2020/11/bearing-removal-1-copy.jpg
Of course parting the cases means the primary gear has to come off… and they are VERY tight… you can forget anything but a really robust puller. here is one I mad a few years ago. with this it came off easily.
https://jtccc.files.wordpress.com/2018/01/puller-11.jpg
The frame and wheels have gone to the powder coaters... |
| Back to top |
| Fisty |
 Fisty Super Spammer
| Back to top |
| buzzer1955 |
 Posted: 19:33 - 21 Nov 2020 Post subject: |
here are the carbs, they are in remarkably good condition! I had some genuine new floats and needles so I used those in the build. I did bead blast the outsides, taking care to use silicone bungs in all the holes… they came out a treat!
https://jtccc.files.wordpress.com/2020/11/carbs-1-copy.jpg |
| Back to top |
| buzzer1955 |
 Posted: 18:24 - 24 Nov 2020 Post subject: |
while the engine and frame are away I have turned my attention to overhauling the front forks… they were not leaking but I thought I would treat them to some new seals and dust covers…. looks like someone has recently changed just one side by the state of the oil...
https://jtccc.files.wordpress.com/2020/11/50641964062_f1219741b7_o-1.jpg |
| Back to top |
| buzzer1955 |
 Posted: 19:09 - 25 Nov 2020 Post subject: |
the engine cases are back from the vapour blasters… what a superb job! attention to detail is what its all about and they came back prefect… I will definitly use this guy again… the finish is as good as I have ever seen… https://spvapourblasting.co.uk/ I know these cases are painted from original but the pain always flakes off, so I have decided to leave them bear, and use ACF 50 on them to keep them looking nice… this will probably be a low miles, fair weather bike for me…
the engine build begins… I got the cases nice and hot and pressed the bearings in, and then checked the crank and gearbox shafts end float as I wont be using a gasket as Ducati have now discontinued them and use Threebond in place … I had already ordered a few shims by measuring the old gasket (14 thou) and taking that off the shims that are in there… when the shims come in a few days I will build it properly…
https://jtccc.files.wordpress.com/2020/11/cases-5.jpg
https://jtccc.files.wordpress.com/2020/11/cases-4-copy.jpg |
| Back to top |
| buzzer1955 |
 Posted: 18:44 - 28 Nov 2020 Post subject: |
todays job has been cleaning out the oilways in the barrels after being vapour blasted... To do this properly and get every last bead of media out I removed and replaced the core plugs... they are cheap to buy. There was a surprising amount of crud behind them... Made a couple of stepped punches so I could drift them in nice and square.
Checked the bores for wear, there simply isn't any! Ground the valves in with some fine paste (how old is that tin of grinding paste 😅) and checked I had a continuous seal with a sharpie pen. Gave the guides a quick clean with the burnishing hone which just removes carbon,
Finally, a good wash in petrol the tray and a check in the bottom for any blasting media. My mate who builds automatic gearboxes gave me the tip on the stainless steel trays... you really can see any debris in the bottom!
https://jtccc.files.wordpress.com/2020/11/head-and-barrel-colarge.jpg |
| Back to top |
| buzzer1955 |
 Posted: 19:37 - 30 Nov 2020 Post subject: |
Waiting for the engine spares at the moment, so filled some time doing some bead blasting on bits and pieces… one of the best bits of kit I have is a blast cabinet… It used to live outside at the back of the garage because I could never seal it from escaping media as obviously the air tries to inflate the cabinet… with machines about abrasive dust is a no no… Then I hit on the idea of a centrifugal type filter, which offers no resistance to the air going through it. I made the filter out of an Ikea plastic box and some sink drain pipe, it vents outside…. the principle is as the air is made to twist and turn, the partials of dust and media centrifuge out and drop to the bottom of the chambers… so the first chamber gets the most, the second less and so on. there is hardly anything on the drive and nothing in the workshop. its difficult to get this level of restoration to a part without it… Bead also gives that nice sheen to alloy parts and they don’t pick up dirty finger prints. its very good at resisting oxidation as well, particularly with a coat of ACF-50… here is the fuel tap.
I used to make a BIG mistake with bead blasting… I could never get a really nice finish except with brand new media… I moaned at the supplier once and he asked me what pressure I blasted at… high as I can I told him.. there is your problem then! you are shattering the glass beads and turning them into sharp dust, hence you get a dull surface! So I went home, filled my cabinet with new bead and got my wife to turn up the pressure as I cleaned a part… soon as it went shiny, that was the best pressure!
https://jtccc.files.wordpress.com/2020/11/50665840162_409233c074_o.jpg
here is the difference old bead high pressure, new bead low pressure!
https://jtccc.files.wordpress.com/2017/12/bead-blast-comparrison.jpg
here is a before and after on some weber carbs I rebuilt...
https://jtccc.files.wordpress.com/2014/02/dcoe-carb-before.jpg
https://jtccc.files.wordpress.com/2014/02/dcoe-carb-after.jpg
here is how the filter works
https://jtccc.files.wordpress.com/2019/12/blast-cabinet-filter.jpg |
| Back to top |
| buzzer1955 |
| Back to top |
| buzzer1955 |
| Back to top |
| buzzer1955 |
| Back to top |
| buzzer1955 |
 Posted: 19:30 - 08 Dec 2020 Post subject: |
Some bolts I just tighten… but critical components I always use a torque wrench… in the past I have used a long series a spanner and calculated the pull I need on a spring balance… but for some reason I could not get the spanner on I have used in the past and its part of an expensive set, so I didn’t want to modify it by grinding… , so had to make a tool… I knew that old spanner and socket would come in one day!
One tip I picked up years ago when I used to build Crossflow race engines was always mark the head nuts/bolts after the first stage torque. I would paint an arrow on them with tippex... then move on to the second stage torque, and then the final stage. then I would check all the arrows were facing the same direction, and if any weren't, I would give them an extra tweak until they did. the rational for this is that it takes much of the varying nut/bolt/washer friction out of the equation and you get an even clamping force.
Of course that's exactly what you do in effect on modern engines, but now in a more refined way with an angle gauge... on a BMW engine I recently worked on the bolts were torqued to 40 NM, then 90 degrees, then another 90... I still put arrows on them! the reason for that is its all to easy to get confused as they need to be puled down in sequence, and there are 20 bolts! its all too easy to forget where you are... and its not like a torque wrench where you give it a click to check! All too easy to give a bolt 90, 90 and another 90, at which point it pings!
https://jtccc.files.wordpress.com/2020/12/cylinder-head-tool-copy.jpg |
| Back to top |
| buzzer1955 |
 Posted: 14:44 - 09 Dec 2020 Post subject: |
When people ask me why Ducati bikes are expensive to maintain… I say try doing the valve clearances and adjusting them to the correct specification… its a fiddly job on the bench, let alone in the frame! and this is just the 2V!
https://jtccc.files.wordpress.com/2020/12/heads-4.jpg |
| Back to top |
| buzzer1955 |
| Back to top |
| struan80 |
 struan80 World Chat Champion
| Back to top |
| ThunderGuts |
 Posted: 16:32 - 11 Dec 2020 Post subject: |
I wish I had the time, tools and skills to do something like this (not missing much am I?). I manage basic restorations occasionally, but infrequent. Reading through the post and looking at the pictures is strangely satisfying. Looking forwards to seeing more updates.  ____________________ TG. |
| Back to top |
| P.addy |
 P.addy Red Rocket
| Back to top |
The last post was made 5 years, 175 days ago. Instead of replying here, would creating a new thread be more useful? |
