| Graham Thomas |
 Graham Thomas L Plate Warrior
| stinkwheel |
 Posted: 01:54 - 23 Nov 2020 Post subject: |
Can't be specific to your bike but in general, performance spannies on a 2t give you more top-end at a cost of midrange. The more top-end, the less midrange and without dynamic exhaust ports, that's what you'll be stuck with.
Needle profile, needle jet and slide cutaway, needle position and the relationship between them will be the main factors determining your low to mid range.
Slow running jet is only really a factor from idle to about 1/4 throttle opening. Main jet will be about 3/4 to wide open. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| redeem ouzzer |
 redeem ouzzer World Chat Champion
| A100man |
 A100man World Chat Champion
 Posted: 14:48 - 23 Nov 2020 Post subject: Re: Expansion chambers (Higgspeed) fitted on SuzukiGT250B |
| Graham Thomas wrote: | Has anyone else experienced the low end to mid range power reduction after fitting expansion chambers ? I believe I maybe need to increase the primary and main jet size and any pointers would be useful. I've tried lifting the needle a notch and didn't make much difference. |
Are you suggesting that fitting these pipes has had a detrimental effect on performance?
Higgspeed (AllSpeed?) are still operating aren't they? Can't you approach them for some guidance.
Failing that ride about a bit, if you hole a piston - too lean. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| redeem ouzzer |
| A100man |
 Posted: 16:17 - 23 Nov 2020 Post subject: Re: Expansion chambers (Higgspeed) fitted on SuzukiGT250B |
| Forced wrote: |
Higgspeed is a totally different company selling their own pipes. Variations on the old Allspeeds are sold via Gibson.
Common denominator is they are both shite compared to purpose made chambers. |
Ah gotcha  ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
The last post was made 5 years, 293 days ago. Instead of replying here, would creating a new thread be more useful? |
