NJD |
NJD World Chat Champion
Posted: 15:17 - 06 Dec 2020 Post subject: Fazer 600 - Cylinder #1 Issue |
Hi,
So will be phoning local shop tomorrow, but posting for ideas / more places to look.
My MK1 Fazer 600 has developed a running fault that has worsened over the past few rides. May be related to the damp weather as was fine before temperatures dropped below 5, but seems to be struggling since.
Started out as small lumpiness under throttle at random then progressed onto sounding like it wanted to stall at idle with the clutch pulled in if sat at lights for an average perid of time, and sounded funny after a ride (on one occasion) in neutral and is now causing the bike to bog down / struggle to pull away below 3,000 rpm or from a dead standstill. Bike requires a lot more throttle to pull away even close to smoothly and often jerks in the process like its going to cut out but doesn't and then gets going.
Exhaust #1 (sitting on bike, far left side) is the problem as its not as warm as the others after a ride (tested by spraying water on downpipes). Its getting warm, but not as warm as it should.
Bike runs fine above 3,000 rpm and starts fine first time on the button without issue. Gears changing fine. Clutch adjusted as it should be.
Spark plugs are fairly new, caps are original. Cap #1 fitted tight and golden part inside looks shiny (not rusted).
IMO based on the fact I've only had it a few months and was serviced by the shop before that (including going back to have the fuel sender replaced) its either something intermittent (coil, but not a complete failure since the one beside #1 is warm and runs fine?) or a slowing failure.
Any ideas? ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
Bhud |
Bhud World Chat Champion
Kawasaki Jimbo |
NJD |
Posted: 16:14 - 06 Dec 2020 Post subject: |
Photo of plug from problem cylinder.
I realise there are charts to compare to, but if someone could spell it out in layman's terms:
https://i.postimg.cc/Vk4yhbZh/20201206-144645-1702.jpg
edit:
There is a mark on the ceramic part, but I've never pulled them in the months I've owned it so cannot be sure if it was there before the problem / and if this is an indicator of a problem from the HT lead / damage?
https://i.postimg.cc/K8Gwt8cD/20201206-144842.jpg ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶
F18 |
F18 Renault 5 Driver
weasley |
weasley World Chat Champion
Nobby the Bastard |
Arfa__ |
Arfa__ Traffic Copper
Posted: 17:21 - 06 Dec 2020 Post subject: |
Had same symptoms on my FZS600 few years ago, turned out to be a crack in the spark plug cap.
Was hassle to replace HT leads in coils, so just trimmed original leads slightly then shoved them into some new NGK caps. Job done. ____________________ Beginner Biker Adventures Blog
Yamaha FZ6 S2 2007 |
NJD |
Posted: 17:25 - 06 Dec 2020 Post subject: |
Nobby the Bastard wrote: | I would assume a knackered carb rubber for stalling at the traffic lights. |
It hasn't actually stalled thus far, but sounds like it wants to if I find myself sitting at a set of lights at night for a period of time (where I can hear the bike the most). Sluggish to pull away and jerks in the process then gets going and is fine once on the move without issue.
The engine to carb rubbers are badly damaged, but (IIRC) I've had this bike since August and ran them in this condition. I have sprayed carb cleaner on them to see if the idle speed rises and didn't hear a change in the engine tone or notice anything on the needle.
Fazer rubbers, so I'm led to understand, are known for cracking so given that I don't believe there is an air leak I'm reluctant to pay for them to be changed. Shop sold them like this and have had it back since so despite how bad they look if it was the cause of an issue then I'd assume it would have been obvious straight away.
I realise you could look at the below photo and say "dur, get them replaced because even if it isn't that it can't be helping," but as I say the bikes ran fine since I got it with them like that.
The bike was fine one moment, and then has got progressively worse with change to how its set up / jobs done inbetween that could have caused issue.
https://i.postimg.cc/N0gs9cS3/20200814-155542.jpg
Arfa__ wrote: | Had same symptoms on my FZS600 few years ago, turned out to be a crack in the spark plug cap. |
Tempted to start with replacing the cap and plug and going from there. ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
oilyrag |
oilyrag Nova Slayer
NJD |
andys675 |
andys675 World Chat Champion
Nobby the Bastard |
Posted: 17:51 - 06 Dec 2020 Post subject: |
FACE PALM. ____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Sprint ST 1050 |
A100man |
A100man World Chat Champion
oilyrag |
oilyrag Nova Slayer
NJD |
Tdibs |
Tdibs Traffic Copper
Posted: 23:21 - 06 Dec 2020 Post subject: |
Yep my money is on tiny hairline split in plug cap. As other have said, trim 1cm off HT end, screw into new cap. You have already identified the problem cylinder.
And yes, those boots wont last forever. Dog of a job, good luck ____________________ Previous : 09 Vanvan 125| 02' Sv650s || Current: 1999 Xj600n | 1992 DR650 RSE | 2005 Fazer 1000 |
oilyrag |
oilyrag Nova Slayer
NJD |
Posted: 23:20 - 07 Dec 2020 Post subject: |
Bingo.
Replaced the O.E.M cap with a brand new NGK SD05F cap and the exhaust got hot, as it should, straight away. Only realised how much power I'd lost when I attempted to pull away to test ride after fitting.
For what its worth the O.E.M cap looks to be in perfect condition and is crack free all over, and the gold bit that the HT lead screws into is shiny and free from debris or marks (bright gold). So it may be internal, or it may be that the HT lead was slightly mangled due to age / not forming a good connection. In either case I'm glad its a cheap fix, as I'd hoped, as the bike now continues to run like a dream in weather worse than what other bikes have left me at the side of the road.
Used the same spark plug so was definitely the cap or the HT lead needing cutting.
Will replace other three when I can go back and pick them up because why not. Assume their the ones that the bike rolled out the factory with so can't hurt.
Regards those cracked boots I've realised -- if it makes a difference -- that they're the "carb intake stubs" not the ones that go from carbs to airbox (rubbers). Still will need replacing at some point, but neither part looks to be particularly expensive via eBay second hand for average - good condition ones. A job for the future, but not yet.
Many thanks for all the advice. ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
oilyrag |
oilyrag Nova Slayer
weasley |
oilyrag |
oilyrag Nova Slayer
NJD |
Posted: 00:02 - 09 Dec 2020 Post subject: |
I've seen the el-cheapo twenty-pound ones on eBay, but have since purchased a job lot that had some genuine ones in from a bike that had been stripped for twenty quid. I can see one has a crack, and the other three look to be in good condition. For the price I can't complain at whatever turns up.
Wont be something I do anytime soon as the bikes running mint in this cold climate without fuss, and also is a lot of stripping parts just to replace something that -- for me at least -- is only a visual issue at the moment; but is worth chucking in a spares box.
You could probably build the bike for a tenner based on the mass cheap parts available via eBay. ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
NJD |
Posted: 20:21 - 24 Mar 2021 Post subject: |
[BUMP - Fazer 600 1999 MK1].
To recap: in December 2020 I had a running issue that turned out to be a coil related issue and appeared on #1 cylinder. I solved this issue by fitting new NGK spark plug caps to all four HT leads and trimming the original HT lead a little to give it a fresh lease of life.
Today, three months on, the poor running appeared again but this time was on #2 and #3 which is on a separate coil to last time. Both exhausts were running noticeably cooler than #1 and #4.
I fitted four new spark plugs, but that made little difference. I trimmed back the HT lead on the problem cylinders and they came back into life. They were tight to the cap before I trimmed them, but trimming them worked for whatever reason.
I went for a ride after trimming the HT leads on the problem cylinder (#2 and #3) and it ran as good as I'd expect it to. The exhausts were hot and spraying water on them caused the same amount of smoke as #1 and #4. So, for now, all four exhausts are at the same temp and it works (omitting that it will be one or two rides before I'll be convinced its fine and working as it should without issue).
I can't do anything but play the waiting game for now, but would replacing the coils be your next investment? I'm baffled by (a) why the other coil failed to last time, and (b) why trimming the lead fixed the issue when they were trimmed three months ago and have worked okay since.
I did also charge the battery today (removed it as I didn't want spilt fuel from removing tank hose to get on it) and it read 90% when the charger first started charging it. I can't be 100% sure that translates into anything as you can charge the battery and plug it in again straight after and it doesn't read 100% (Sealey branded charger).
Anything that may cause the coils to play up that trimming the HT leads solves?
Bit of an odd one to be honest. ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
Robby |
Robby Dirty Old Man
The last post was made 3 years, 31 days ago. Instead of replying here, would creating a new thread be more useful? |
