Easy-X |
Easy-X Super Spammer
Posted: 12:40 - 09 Dec 2020 Post subject: Tell me all about... suspension :) |
Waiting for the planets to align till I can get me some XSR700 action. In the meantime I've watched some videos, know your enemy and all that And the recurring criticism is always...
Suspension
So in my usual spirit of "You know nothing, Jon Snow" I'd like figure out what's worth doing and what's just track day fluff.
Starting point for the XSR700/MT07 is pretty much a blank slate: boggest of bog standard non-adjustable front forks, basic pre-load adjustable rear shock. Assume a full rebuild or replacement of the front forks and/or their internals is perfectly feasible, rear shock will just be adjust or swap.
Option 1: Leave it alone. Oh dear, how boring! However, my elfin-like form does me a favour here as it places me in the "Japanese" sub-75kg category. I might therefore find the stock suspension acceptable.
Option 2: Trim 10~15mm from the fork spacers, up the oil weight from 10W to 15W. This seems to be the minimal modification touted.
Option 3: Replace fork top-caps to get pre-load adjustment. Seems a lot less "hacky" than the previous option. Usually this is coupled with replacement springs which leads to the question: linear or progressive?
Option 3a: I see "emulators" mentioned which seem to be a cheap but annoying way to add some regulation to the oil flow: hassle in that complete disassembly is required to fit them and more hassle to do the same again if they need adjustment.
Option 4: Drop in cartridges. Well, now you have all the spinny bits! But is all that necessary on a street bike?
For the rear shock I guess it's the simple case of "how much money would you like to burn?" but is it a case of upgrading in tandem with whatever's done to the forks or are the benefits independent?
Obviously all this stuff would need a proper set up or what's the point ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
A100man |
A100man World Chat Champion
Old Git Racing |
Old Git Racing World Chat Champion
redeem ouzzer |
wr6133 |
wr6133 World Chat Champion
Kris |
Kris World Chat Champion
chickenstrip |
chickenstrip Super Spammer
Posted: 14:36 - 09 Dec 2020 Post subject: |
Forced wrote: |
I'm shocked a Tracer 700 has piston rod forks as standard. Disgusting for a modern bike. |
The only thing I can think of is that they must be cheaper to produce. ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
THERE'S MILLIONS OF CHICKENSTRIPS OUT THERE! |
Robby |
Robby Dirty Old Man
Posted: 15:26 - 09 Dec 2020 Post subject: |
Ride it and see. Suspension is down to your weight, riding style, roads and personal preference.
So this means that even very crap suspension could be fine for you, if you're using the bike in the range where that suspension works. The minor tweaks you mentioned - preload and oil weight - provide a small amount of adjustment. The main problem is that with basic suspension you're stuck with a limited range of use cases where it works properly. Get outside of this range and it either too soft, too hard, too much or too little damping, or it just can't respond quickly enough.
I have had to learn about this in the last couple of years because, for the first time in my life, I got a bike where the suspension is just dangerously shit from the factory. The forks were saggy when ridden gently, but went rock solid when moving on a rough surface - not doing what suspension should do. The rear shocks just couldn't change direction quickly enough and were very hard, so I had the odd sensation of a firm rear end and plenty of punches in the kidneys, but the traction control light always coming on.
My solution has been new fork springs and cartridge emulators in the front, which sorted it. Could go further and fit full cartridges, but that's diminishing returns. New shocks on the back from the shock factory, which are pretty good but not incredible. Better than hagon, worse than I assume Ohlins would be. Messing around with spring rates is a thing, and gets expensive quickly. |
MCN |
MCN Super Spammer
Easy-X |
Polarbear |
Polarbear Super Spammer
wr6133 |
Fizzer Thou |
Posted: 22:02 - 09 Dec 2020 Post subject: |
I quickly found that the OEM rear shock on my 5JJ R1 was not as good as it could be,so opted for an Ohlins like I have on a few of my other bikes.This was fitted at an early stage of my ownership of the bike and was assured by the included documents that it was set up for my weight and for my intended use ie.not on the track.From the off the feedback through my backside suggested that there was something wrong.I had adjusted the SAG when the superior shock was fitted,but the clickers were miles out from the 'suggested' settings that the paperwork said they were.After going to the setup in the owners manual it made a world of difference and after a bit of fine tuning I am happy to stuff the bike in to a corner,knowing that the bike will not wobble and bounce half way through.The wear pattern on the tyre also shows that the suspension is working correctly,with the Michelin PR3 that was on there for 13,000 miles worn evenly across the width.
The situation with upgrading the rear of the R1 showed up the low quality front springs,so they were replaced with Ohlins uprated springs and decent Ohlins grade 5 fork oil. The cartridge was flushed with some cheap fork oil and left to drain overnight and the air gap carefully measured.And what a world of difference they made.The information from the Haynes manual,which is the same to all intents and purposes as that from the genuine Yamaha document,was adhered to and the results were worth the effort ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
MarJay |
MarJay But it's British!
Posted: 22:17 - 09 Dec 2020 Post subject: |
https://www.bikechatforums.com/download.php?id=100711
Ignore any setup guide that says: "Street Triple: 2 clicks off of the front rebound, one off of compression..." etc
The guide linked to above is the closest thing to a generic suspension setup guide I've seen. There is literally nothing on Youtube unless you pay and precious little else on the internet at large that I can find. The above guide from a magazine circa 1999 is honestly the best I've found. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
Posted: 00:00 - 10 Dec 2020 Post subject: |
Set the sag, then tweak everything else.
If the sag is wrong, there is no point tweaking anything else, you're painting the bricks before you built the wall. Sag is determined by spring strength and preload.
From experience, if the spring rate and sag are correctly set, even if the damping fails totally, the bike will still be rideable (albeit a tad boingy).
Go to this page:
https://racetech.com/ProductSearch/12/Yamaha/XSR700/2019
Click on calculate spring rates, fill in the details, read what it suggests about spring rate, preload, fork oil (level and type) and (if you're made of money) valving.
If you do what they suggest there, you will be in the correct ballpark.
If there is no cable tie round your fork stanchion, you aren't setting up suspension, you are just randomly fiddling with things. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Easy-X |
Posted: 00:40 - 10 Dec 2020 Post subject: |
stinkwheel wrote: | Set the sag, then tweak everything else.
Go to this page:
If there is no cable tie round your fork stanchion, you aren't setting up suspension, you are just randomly fiddling with things. |
Very interesting If anything I might be too light for the stock springs Replacement springs or more pies... it's a tough one ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
sickpup |
sickpup Old Timer
MarJay |
chickenstrip |
Posted: 10:19 - 10 Dec 2020 Post subject: |
MarJay wrote: |
Nitron charge £462 for their most basic shock, always built to order to customer spec. I think the remote preload adjuster is not expensive either... |
That's not expensive?! I think I'm out of touch! and skint ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
MarJay |
chickenstrip |
Posted: 10:39 - 10 Dec 2020 Post subject: |
MarJay wrote: |
Nope, that's a great deal. Nitron are spoken of in the same breath as Ohlins, yet they are made right here in the UK and their basic model costs half of what a second hand ohlins shock would probably fetch on ebay. |
What's a good budget if you're buying a bike? Now what proportion of that is nearly £500?
Ok, I get that good suspension makes or breaks the riding experience. But manufacturers should be providing that as part of their finished bikes anyway. You shouldn't have to spend that big chunk extra. But I suppose it depends on whether you're talking of bikes that are perfectly ok for everyday use, or something you want to rag the arse out of on track.
Fortunately on mine I had the option of used, well-doctored (K-Tech internals) forks in a conversion to USD (parts about £300, ready to bung on and go), and a low mileage or refurbished rear shock from a better handling bike that was well known to work with this model for even less than that ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
A100man |
Posted: 11:12 - 10 Dec 2020 Post subject: |
MCN wrote: | Follow the guidance online. Fast Bikes mag and such aye have a skit on spension set-up.
It's not rocket surgery to get it reasonably adjusted for general riding.
As mentioned up there, /\ the only real need to get purnikerty about it is if you intend to push the hoowur to it's/your limits. |
Yes, and this month Practical Sportsbike also have an article on setting up on an MT09.. In summary they say setting sag correctly will get you a long way or go to an expert and spend 750 quid for some new bits (pistons, springs, shock) ____________________ Now: A100, GT250A, XJ598, FZ750
wr6133 |
trevor saxe-coburg-gotha |
Old Git Racing |
The last post was made 3 years, 138 days ago. Instead of replying here, would creating a new thread be more useful? |
