Bit of a specialised Nest thermostat question.
toby1
PostPosted: 11:28 - 09 Dec 2020    Post subject: Bit of a specialised Nest thermostat question. Reply with quote
Ok so picking the brains of any Nest thermostat installers.
Recently fitted a Nest learning thermostat to my boiler. Did away with the old wireless heat controller and the ancient hot water timer. All works fine.
My question (which I can't find an answer to ) is in eco mode it can tell when you've left the house and reduces the heat call. It then senses when you are coming home again and turns the heat on accordingly, they call it geofencing.
The thing is the nest app installs on your mobile and probably uses your sim card and location settings to geofence. So if you installed on two mobiles (mine and the wife's ) would it work with two or is it bound to one?
The situation being if I am away and the wife at home it wouldn't go into the eco mode because it would be aware of my wife's phone location. If we are both away it would go into eco mode, but would respond if either phone came back within range?
Thanks for any help Very Happy
Keithy
PostPosted: 12:50 - 09 Dec 2020    Post subject: Reply with quote
According to this
https://mashable.com/2016/03/10/nest-away-assist/?europe=true
You can add more than one device and the geofencing won’t shut off the heat.
toby1
PostPosted: 11:48 - 10 Dec 2020    Post subject: Reply with quote
Thanks for that. To work the google home app needs to be on any family member phone. The nest app alone won't work. Big brother Sad
The last post was made 5 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.68 - MySQL Queries: 14 - Page Size: 35.31 Kb
